X10SL7-F Front Panel USB Connectors - Dual or Single???
coolspot
Hi all,
I built a new server with the popular X10SL7-F board and a Fractal Node 804 case. Like many current cases, it has dual front-panel USB 3.0 ports.
However, only one of the two front-panel USB 3.0 ports seem to function correctly.
Based on the X10SL7 documentation, it *seems* that the internal USB header only supports one port? Is this the case even tho all 19 pins are present?
Can anyone confirm if the X10SL7-F supports dual front-panel USB 3.0 connectors via the internal header?
Thanks!
Only one of the USB 3.0 ports is routed to the header. The other one is routed to the USB type A connector mid-board.
coolspot
Be careful if you remove the connector at it will likely remove the light blue plastic female seat on the motherboard leaving the pins behind :confused:
I noticed, I was shocked that the whole plastic shield popped off - really surprised it wasn't glued down. I thought I broke my new board within 30 minutes :D
