I'm trying to build a new FreeNAS box using a Fractal Design Node 304 case, a Corsair RM650 PSU and a Commell LV-67M motherboard .
The case and PSU were bought several years ago and have not been used yet. I've been running FreeNAS on a Lenovo ThinkCentre M93 Tiny for the last few years, but have decided to build a new system. The problem I'm having is wiring up the motherboard!
I've looked at the http://www.commell.com.tw/Download/Manual/LV-67M_Manual_V14.pdf but am not clear where the cables from the case should be connected. There are three cables with red and black wires, marked POWER SW, POWER LED and HDD LED. One cable has several wires and a block connector marked HD AUDIO (CN_AUDIO) and there is also a cable with a blue 2x10 socket block connector for USB 3.0, which I've just identified as CN_USB3.
Apologies for such a newbie type question, but it's a long time since I last built my own system and things have changed quite a bit, so I'd appreciate it if someone could identify which pins I need to attach the case wires to.
