madtulip
- Mar 28, 2015
Hello guys. i keep getting these emails:
"SMART error (FailedReadSmartSelfTestLog) detected on host: nas"
I get this for all 4 drives every now and then. sometimes all, sometimes only some of them. The HDDs are rather new and im triing to figure out if some have factory faults and need to be replaced or why this errors keep comming. I triied to take a look at the syslogs but could locate it in the filesystem. So i used smartctl "for further investigation".
If anybody with experience could please take a look and tell me whats wrong or what other information you would need? Thanks!
I did run a long scan with smartctl -t long /dev/adaXX and did run smartctl -a /dev/adaXX afterwards resulting in this for HDD0 (i replaced some information with "BLABLABLA").:
HDD1 (same hardware, ill paste only the last parts):
HDD2 (same hardware, ill paste only the last parts):
HDD3 (same hardware, ill paste only the last parts):
This message was generated by the smartd daemon running on: host name: nas DNS domain: bla@bla.org The following warning/error was logged by the smartd daemon: Device: /dev/ada3, Read SMART Self-Test Log Failed Device info: WDC WD40EFRX-68WT0N0, S/N:WD-BLABLA, WWN:5-0014ee-BLABLABLA, FW:82.00A82, 4.00 TB For details see host's SYSLOG. You can also use the smartctl utility for further investigation. No additional messages about this problem will be sent.
smartctl -a /dev/ada0
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p12 amd64] (local build)
Model Family: Western Digital Red
Device Model: WDC WD40EFRX-68WT0N0
Serial Number: WD-BLABLABLA
LU WWN Device Id: 5 0014ee BLABLABLA
Firmware Version: 82.00A82
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sun Apr 12 08:42:09 2015 CEST
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: (52380) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 524) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 196 195 021 Pre-fail Always - 7200
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 8
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 255
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 8
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 4
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 12
194 Temperature_Celsius 0x0022 127 122 000 Old_age Always - 25
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 248 -
# 2 Extended offline Completed without error 00% 244 -
# 3 Short offline Completed without error 00% 224 -
# 4 Short offline Completed without error 00% 200 -
# 5 Short offline Completed without error 00% 176 -
# 6 Short offline Completed without error 00% 152 -
# 7 Short offline Completed without error 00% 128 -
# 8 Short offline Completed without error 00% 104 -
# 9 Short offline Completed without error 00% 80 -
#10 Short offline Completed without error 00% 56 -
#11 Short offline Completed without error 00% 45 -
#12 Short offline Completed without error 00% 44 -
#13 Short offline Completed without error 00% 43 -
#14 Short offline Completed without error 00% 42 -
#15 Short offline Completed without error 00% 41 -
#16 Short offline Completed without error 00% 40 -
#17 Short offline Completed without error 00% 39 -
#18 Short offline Completed without error 00% 38 -
#19 Short offline Completed without error 00% 37 -
#20 Short offline Completed without error 00% 36 -
#21 Short offline Completed without error 00% 35 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
3 Spin_Up_Time 0x0027 195 194 021 Pre-fail Always - 7241
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 256
194 Temperature_Celsius 0x0022 126 121 000 Old_age Always - 26
No Errors Logged
# 2 Extended offline Completed without error 00% 245 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay.HDD2 (same hardware, ill paste only the last parts):
3 Spin_Up_Time 0x0027 198 198 021 Pre-fail Always - 7083
194 Temperature_Celsius 0x0022 126 120 000 Old_age Always - 26
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
3 Spin_Up_Time 0x0027 195 195 021 Pre-fail Always - 7216
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 13
194 Temperature_Celsius 0x0022 126 122 000 Old_age Always - 26
No Errors Logged
#17 Short offline Completed without error 00% 38 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
