Help with SMART results (pre-fail)
flyinfitz1
Just need a little help with a my results on SMART tests. A few elements show pre-fail but the raw counts on the big ticket items are 0. Drives are a few years old and are close to out of warranty I believe.
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x002f   200   200   051	Pre-fail  Always	   -	   0
  3 Spin_Up_Time			0x0027   183   180   021	Pre-fail  Always	   -	   5808
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   28
  5 Reallocated_Sector_Ct   0x0033   200   200   140	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x002e   200   200   000	Old_age   Always	   -	   0
  9 Power_On_Hours		  0x0032   075   075   000	Old_age   Always	   -	   18680
10 Spin_Retry_Count		0x0032   100   253   000	Old_age   Always	   -	   0
11 Calibration_Retry_Count 0x0032   100   253   000	Old_age   Always	   -	   0
12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   28
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   17
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   1482
194 Temperature_Celsius	 0x0022   114   109   000	Old_age   Always	   -	   36
196 Reallocated_Event_Count 0x0032   200   200   000	Old_age   Always	   -	   0
197 Current_Pending_Sector  0x0032   200   200   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0030   100   253   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x0032   200   200   000	Old_age   Always	   -	   0
200 Multi_Zone_Error_Rate   0x0008   200   200   000	Old_age   Offline	  -	   0
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline	   Completed without error	   00%	 18576		 -
# 2  Extended offline	Completed without error	   00%	 18490		 -
# 3  Short offline	   Completed without error	   00%	 18408		 -
# 4  Short offline	   Completed without error	   00%	 18192		 -
# 5  Extended offline	Completed without error	   00%	 18106		 -
# 6  Short offline	   Completed without error	   00%	 18024		 -
# 7  Short offline	   Completed without error	   00%	 17856		 -
# 8  Extended offline	Completed without error	   00%	 17770		 -
# 9  Short offline	   Completed without error	   00%	 17689		 -
#10  Short offline	   Completed without error	   00%	 17449		 -
#11  Extended offline	Completed without error	   00%	 17363		 -
#12  Short offline	   Completed without error	   00%	 17281		 -
#13  Short offline	   Completed without error	   00%	 17114		 -
#14  Extended offline	Completed without error	   00%	 17027		 -
#15  Short offline	   Completed without error	   00%	 16946		 -
#16  Extended offline	Completed without error	   00%	 16740		 -
#17  Short offline	   Completed without error	   00%	 16658		 -
#18  Extended offline	Completed without error	   00%	 16437		 -
#19  Short offline	   Completed without error	   00%	 16355		 -
#20  Short offline	   Completed without error	   00%	 16115		 -
#21  Extended offline	Completed without error	   00%	 16029		 -
Bidule0hm
Server Electronics Sorcerer
Pre fail is the type of the field, not the status of the field. I don't see any problem with this drive.
flyinfitz1
Much appreciated, thanks!
DrKK
FreeNAS Generalissimo
Indeed. If you'd like sir, you can give us the full output of
smartctl -x /dev/ada0
(replacing the ada0 with each of your drive designators), preferably in "code" tags, or in pastebin, and we'll be happy to take a look at the drive and its history and give you an analysis. The drive is nearing 20000 hours of operation, so now is a good time to have someone that knows what they're doing take a look at the full info.
flyinfitz1
Sorry for the late response. Here is the full read out.
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:	 Western Digital Red
Device Model:	 WDC WD30EFRX-68EUZN0
Serial Number:	WD-WCC4NDRX32KS
LU WWN Device Id: 5 0014ee 20ad3a331
Firmware Version: 82.00A82
User Capacity:	3,000,592,982,016 bytes [3.00 TB]
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Rotation Rate:	5400 rpm
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:	Wed Jul 26 17:43:45 2017 PDT
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Unavailable
Rd look-ahead is: Enabled
Write cache is:   Enabled
ATA Security is:  Disabled, frozen [SEC2]
Wt Cache Reorder: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
										was never started.
Self-test execution status:	  (   0) The previous self-test routine completed
										been run.
data collection:				(39540) seconds.
capabilities:					(0x7b) SMART execute Offline immediate.
										Auto Offline data collection on/off supp																															   ort.
										command.
										Self-test supported.
SMART capabilities:			(0x0003) Saves SMART data before entering
										power-saving mode.
Error logging capability:		(0x01) Error logging supported.
Short self-test routine
recommended polling time:		(   2) minutes.
Extended self-test routine
recommended polling time:		( 397) minutes.
Conveyance self-test routine
recommended polling time:		(   5) minutes.
SCT capabilities:			  (0x703d) SCT Status supported.
										SCT Data Table supported.
ID# ATTRIBUTE_NAME		  FLAGS	VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate	 POSR-K   200   200   051	-	0
  3 Spin_Up_Time			POS--K   181   176   021	-	5908
  4 Start_Stop_Count		-O--CK   100   100   000	-	105
  5 Reallocated_Sector_Ct   PO--CK   200   200   140	-	0
  7 Seek_Error_Rate		 -OSR-K   200   200   000	-	0
  9 Power_On_Hours		  -O--CK   074   074   000	-	18991
 10 Spin_Retry_Count		-O--CK   100   100   000	-	0
 11 Calibration_Retry_Count -O--CK   100   253   000	-	0
 12 Power_Cycle_Count	   -O--CK   100   100   000	-	74
192 Power-Off_Retract_Count -O--CK   200   200   000	-	19
193 Load_Cycle_Count		-O--CK   200   200   000	-	1613
194 Temperature_Celsius	 -O---K   114   109   000	-	36
196 Reallocated_Event_Count -O--CK   200   200   000	-	0
197 Current_Pending_Sector  -O--CK   200   200   000	-	0
198 Offline_Uncorrectable   ----CK   100   253   000	-	0
199 UDMA_CRC_Error_Count	-O--CK   200   200   000	-	0
200 Multi_Zone_Error_Rate   ---R--   200   200   000	-	0
							||||||_ K auto-keep
							|||||__ C event count
							||||___ R error rate
							|||____ S speed/performance
							||_____ O updated online
							|______ P prefailure warning
General Purpose Log Directory Version 1
SMART		   Log Directory Version 1 [multi-sector log support]
Address	Access  R/W   Size  Description
0x00	   GPL,SL  R/O	  1  Log Directory
0x01		   SL  R/O	  1  Summary SMART error log
0x02		   SL  R/O	  5  Comprehensive SMART error log
0x03	   GPL	 R/O	  6  Ext. Comprehensive SMART error log
0x06		   SL  R/O	  1  SMART self-test log
0x07	   GPL	 R/O	  1  Extended self-test log
0x09		   SL  R/W	  1  Selective self-test log
0x10	   GPL	 R/O	  1  SATA NCQ Queued Error log
0x11	   GPL	 R/O	  1  SATA Phy Event Counters log
0x21	   GPL	 R/O	  1  Write stream error log
0x22	   GPL	 R/O	  1  Read stream error log
0x80-0x9f  GPL,SL  R/W	 16  Host vendor specific log
0xa0-0xa7  GPL,SL  VS	  16  Device vendor specific log
0xa8-0xb7  GPL,SL  VS	   1  Device vendor specific log
0xbd	   GPL,SL  VS	   1  Device vendor specific log
0xc0	   GPL,SL  VS	   1  Device vendor specific log
0xc1	   GPL	 VS	  93  Device vendor specific log
0xe0	   GPL,SL  R/W	  1  SCT Command/Status
0xe1	   GPL,SL  R/W	  1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA																															   _of_first_error
# 1  Short offline	   Completed without error	   00%	 18977		 -
# 2  Extended offline	Completed without error	   00%	 18890		 -
# 3  Short offline	   Completed without error	   00%	 18809		 -
# 4  Short offline	   Completed without error	   00%	 18641		 -
# 5  Extended offline	Completed without error	   00%	 18554		 -
# 6  Short offline	   Completed without error	   00%	 18473		 -
# 7  Short offline	   Completed without error	   00%	 18257		 -
# 8  Extended offline	Completed without error	   00%	 18170		 -
# 9  Short offline	   Completed without error	   00%	 18089		 -
#10  Short offline	   Completed without error	   00%	 17921		 -
#11  Extended offline	Completed without error	   00%	 17835		 -
#12  Short offline	   Completed without error	   00%	 17754		 -
#13  Short offline	   Completed without error	   00%	 17514		 -
#14  Extended offline	Completed without error	   00%	 17427		 -
#15  Short offline	   Completed without error	   00%	 17346		 -
#16  Short offline	   Completed without error	   00%	 17178		 -
#17  Extended offline	Completed without error	   00%	 17092		 -
#18  Short offline	   Completed without error	   00%	 17011		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
SCT Status Version:				  3
SCT Version (vendor specific):	   258 (0x0102)
SCT Support Level:				   1
Device State:						Active (0)
Current Temperature:					36 Celsius
Power Cycle Min/Max Temperature:	 22/41 Celsius
Lifetime	Min/Max Temperature:	  2/41 Celsius
Under/Over Temperature Limit Count:   0/0
Vendor specific:
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version:	 2
Temperature Sampling Period:		 1 minute
Temperature Logging Interval:		1 minute
Min/Max recommended Temperature:	  0/60 Celsius
Min/Max Temperature Limit:		   -41/85 Celsius
Temperature History Size (Index):	478 (163)
Index	Estimated Time   Temperature Celsius
 164	2017-07-26 09:46	37  ******************
 ...	..( 97 skipped).	..  ******************
 262	2017-07-26 11:24	37  ******************
 263	2017-07-26 11:25	38  *******************
 ...	..( 29 skipped).	..  *******************
 293	2017-07-26 11:55	38  *******************
 294	2017-07-26 11:56	37  ******************
 ...	..( 85 skipped).	..  ******************
 380	2017-07-26 13:22	37  ******************
 381	2017-07-26 13:23	36  *****************
 ...	..(252 skipped).	..  *****************
 156	2017-07-26 17:36	36  *****************
 157	2017-07-26 17:37	37  ******************
 ...	..(  5 skipped).	..  ******************
 163	2017-07-26 17:43	37  ******************
SCT Error Recovery Control:
		   Read:	 70 (7.0 seconds)
		  Write:	 70 (7.0 seconds)
Device Statistics (GP/SMART Log 0x04) not supported
SATA Phy Event Counters (GP Log 0x11)
ID	  Size	 Value  Description
0x0001  2			0  Command failed due to ICRC error
0x0002  2			0  R_ERR response for data FIS
0x0003  2			0  R_ERR response for device-to-host data FIS
0x0004  2			0  R_ERR response for host-to-device data FIS
0x0005  2			0  R_ERR response for non-data FIS
0x0006  2			0  R_ERR response for device-to-host non-data FIS
0x0007  2			0  R_ERR response for host-to-device non-data FIS
0x0008  2			0  Device-to-host non-data FIS retries
0x0009  2		   21  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2		   21  Device-to-host register FISes sent due to a COMRESET
0x000b  2			0  CRC errors within host-to-device FIS
0x000f  2			0  R_ERR response for host-to-device data FIS, CRC
0x0012  2			0  R_ERR response for host-to-device non-data FIS, CRC
0x8000  4	  7587790  Vendor specific
Temperature is on the high side, but everything else looks good.
flyinfitz1
And one year later it looks like all is well. Any thoughts?
Local Time is:	Sun Aug 19 08:43:15 2018 PDT
DSN feature is:   Unavailable
										was never started.
										without error or no self-test has e
										been run.
										Auto Offline data collection on/offort.
										command.
										power-saving mode.
										SCT Error Recovery Control supporte
  3 Spin_Up_Time			POS--K   181   176   021	-	5933
  4 Start_Stop_Count		-O--CK   100   100   000	-	113
  9 Power_On_Hours		  -O--CK   062   062   000	-	28306
 12 Power_Cycle_Count	   -O--CK   100   100   000	-	82
192 Power-Off_Retract_Count -O--CK   200   200   000	-	25
193 Load_Cycle_Count		-O--CK   200   200   000	-	1681
194 Temperature_Celsius	 -O---K   115   109   000	-	35
							||||||_ K auto-keep
							|||||__ C event count
							||||___ R error rate
0x10	   GPL	 R/O	  1  NCQ Command Error log
No Errors Logged
Num  Test_Description	Status				  Remaining  LifeTime(hours)_of_first_error
# 1  Short offline	   Completed without error	   00%	 27725
# 2  Extended offline	Completed without error	   00%	 27639
# 3  Short offline	   Completed without error	   00%	 27557
# 4  Short offline	   Completed without error	   00%	 27390
# 5  Extended offline	Completed without error	   00%	 27303
# 6  Short offline	   Completed without error	   00%	 27222
# 7  Short offline	   Completed without error	   00%	 27006
# 8  Extended offline	Completed without error	   00%	 26919
# 9  Short offline	   Completed without error	   00%	 26838
#10  Short offline	   Completed without error	   00%	 26670
#11  Extended offline	Completed without error	   00%	 26584
#12  Short offline	   Completed without error	   00%	 26503
#13  Short offline	   Completed without error	   00%	 26263
#14  Extended offline	Completed without error	   00%	 26176
#15  Short offline	   Completed without error	   00%	 26095
#16  Short offline	   Completed without error	   00%	 25927
#17  Extended offline	Completed without error	   00%	 25841
#18  Short offline	   Completed without error	   00%	 25759
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
Current Temperature:					35 Celsius
Power Cycle Min/Max Temperature:	 34/36 Celsius
Vendor specific:
Temperature History Size (Index):	478 (363)
 364	2018-08-19 00:46	35  ****************
 ...	..(292 skipped).	..  ****************
 179	2018-08-19 05:39	35  ****************
 180	2018-08-19 05:40	34  ***************
 ...	..(  9 skipped).	..  ***************
 190	2018-08-19 05:50	34  ***************
 191	2018-08-19 05:51	35  ****************
 ...	..(127 skipped).	..  ****************
 319	2018-08-19 07:59	35  ****************
 320	2018-08-19 08:00	36  *****************
 321	2018-08-19 08:01	36  *****************
 322	2018-08-19 08:02	36  *****************
 323	2018-08-19 08:03	35  ****************
 ...	..( 12 skipped).	..  ****************
 336	2018-08-19 08:16	35  ****************
 337	2018-08-19 08:17	36  *****************
 ...	..( 22 skipped).	..  *****************
 360	2018-08-19 08:40	36  *****************
 361	2018-08-19 08:41	35  ****************
 362	2018-08-19 08:42	35  ****************
 363	2018-08-19 08:43	35  ****************
Pending Defects log (GP Log 0x0c) not supported
0x0009  2		   12  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2		   12  Device-to-host register FISes sent due to a COMRESE
0x8000  4		38307  Vendor specific
Everything seems fine.
flyinfitz1
much appreciated. Since these have a 3 year warranty and Im at about 3 years of use, should I start replacing them?
Not unless they start failing.
DrKK
Your drives are nearing 30000 hours. Every month a drive is in service, it's like a human aging one year. That's my rule of thumb. If you concur with the DrKK drive-life analysis: If this were a person, they'd be just about 40 years old. Just like a 40 year old person, if they've always taken care of themselves and there are no underlying issues, everything should be fine for quite some time. But also like a 40 year old person, if they've been drinking and smoking and eating hot pockets their whole life, then it's a crapshoot at 40.
Your drive shows that it's been cared for extremely well. In fact, the only thing not "awesome" is it's been run at a temperature near what I consider to be close to the cutoff on the high end.
There is over an 80% chance that your drive will last another 30000 hours, in my experience.
I concur with the Portuguese Grandmaster, @Ericloewe
