Possible drive failure in progress?
djdwosk97
I tried backing up a few files (<1GB) to my NAS but each time I got an read/write error. The issue is only occurring on my Raid1 array and I'm having no issues copying the same data to another drive on my NAS -- leading me to believe one or both of my RAID1 drives are failing although I haven't gotten any reports from a failed smart test (and I am running them regularly).
Here's the SMART output for the first drive in the array (it's a WD Green that I ran without WDIDLE for years, and thus the load cycle count is dangerously high): (Yes, I know I should be replacing the drive/s even if they aren't failing right now).
[root@freenas ~]# smartctl -a -q noserial /dev/ada0 |less
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p13 amd64] (local build)
Model Family: Western Digital Caviar Green (AF)
Device Model: WDC WD10EARS-00MVWB0
Firmware Version: 51.0AB51
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Sector Size: 512 bytes logical/physical
ATA Version is: ATA8-ACS (minor revision not indicated)
SATA Version is: SATA 2.6, 3.0 Gb/s
Local Time is: Wed Feb 10 17:20:49 2016 EST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: (17880) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 175) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x3035) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 21
3 Spin_Up_Time 0x0027 171 163 021 Pre-fail Always - 6408
4 Start_Stop_Count 0x0032 088 088 000 Old_age Always - 12645
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 056 056 000 Old_age Always - 32673
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 122
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 72
193 Load_Cycle_Count 0x0032 001 001 000 Old_age Always - 1237504
194 Temperature_Celsius 0x0022 120 089 000 Old_age Always - 30
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 9
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed without error 00% 32615 -
# 2 Short offline Completed without error 00% 32539 -
# 3 Extended offline Completed without error 00% 32340 -
# 4 Short offline Completed without error 00% 32264 -
# 5 Short offline Completed without error 00% 32096 -
# 6 Extended offline Completed without error 00% 32004 -
# 7 Short offline Completed without error 00% 31929 -
# 8 Extended offline Completed without error 00% 31764 -
# 9 Extended offline Completed without error 00% 31597 -
#10 Extended offline Completed without error 00% 31429 -
#11 Extended offline Completed without error 00% 31262 -
#12 Extended offline Completed without error 00% 31094 -
#13 Extended offline Completed without error 00% 31046 -
#14 Extended offline Completed without error 00% 30878 -
#15 Extended offline Completed without error 00% 30710 -
#16 Extended offline Completed without error 00% 30375 -
#17 Extended offline Completed without error 00% 30302 -
#18 Extended offline Completed without error 00% 30134 -
#19 Extended offline Completed without error 00% 29966 -
#20 Extended offline Completed without error 00% 29799 -
#21 Extended offline Completed without error 00% 29700 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
(END)
Drive #2:
[root@freenas ~]# smartctl -a -q noserial /dev/ada1 |less
Model Family: Seagate Barracuda 7200.12
Device Model: ST31000528AS
Firmware Version: CC38
Rotation Rate: 7200 rpm
ATA Version is: ATA8-ACS T13/1699-D revision 4
Local Time is: Wed Feb 10 17:32:09 2016 EST
==> WARNING: A firmware update for this drive may be available,
see the following Seagate web pages:
http://knowledge.seagate.com/articles/en_US/FAQ/207931en
http://knowledge.seagate.com/articles/en_US/FAQ/213891en
See vendor-specific Attribute list for marginal Attributes.
been run.
data collection: ( 609) seconds.
command.
power-saving mode.
recommended polling time: ( 184) minutes.
SCT capabilities: (0x103f) SCT Status supported.
1 Raw_Read_Error_Rate 0x000f 117 099 006 Pre-fail Always - 127251839
3 Spin_Up_Time 0x0003 095 094 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 595
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 062 055 030 Pre-fail Always - 98813702107
9 Power_On_Hours 0x0032 090 090 000 Old_age Always - 9032
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 131
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 099 000 Old_age Always - 51540393996
189 High_Fly_Writes 0x003a 098 098 000 Old_age Always - 2
190 Airflow_Temperature_Cel 0x0022 071 043 045 Old_age Always In_the_past 29 (0 5 32 24 0)
194 Temperature_Celsius 0x0022 029 057 000 Old_age Always - 29 (0 15 0 0 0)
195 Hardware_ECC_Recovered 0x001a 032 024 000 Old_age Always - 127251839
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 5908 (173 188 0)
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 365777625
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 2419108026
No Errors Logged
# 1 Extended offline Completed without error 00% 8973 -
# 2 Short offline Completed without error 00% 8897 -
# 3 Extended offline Completed without error 00% 8697 -
# 4 Short offline Completed without error 00% 8622 -
# 5 Short offline Completed without error 00% 8454 -
# 6 Extended offline Completed without error 00% 8362 -
# 7 Short offline Completed without error 00% 8286 -
# 8 Extended offline Completed without error 00% 8121 -
# 9 Extended offline Completed without error 00% 7954 -
#10 Extended offline Completed without error 00% 7786 -
#11 Extended offline Completed without error 00% 7618 -
#12 Extended offline Completed without error 00% 7449 -
#13 Extended offline Completed without error 00% 7401 -
#14 Extended offline Completed without error 00% 7233 -
#15 Extended offline Completed without error 00% 7065 -
#16 Extended offline Interrupted (host reset) 00% 6897 -
#17 Extended offline Completed without error 00% 6729 -
#18 Extended offline Completed without error 00% 6656 -
#19 Extended offline Completed without error 00% 6488 -
#20 Extended offline Completed without error 00% 6320 -
#21 Extended offline Completed without error 00% 6152 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
(END)
Bidule0hm
Server Electronics Sorcerer
I don't see anything wrong ;)
Waow, 1.2M LCC, that must be the record here :)
djdwosk97
Waow, 1.2 M LCC, that must be the record here :)
Any idea what else would cause a file to consistently fail to copy (but have no issues copying to a different drive on the NAS?)
Yeah, I was using it in a MyBook Live for a few years before ripping it out and throwing it in my NAS.
Bidule0hm
Permissions maybe?
djdwosk97
Permissions maybe?
Nope. Plus I've never had an issue with the drives before (and I haven't changed anything).
Of the three different files I tried copying all copied a bit before failing (10-40%~).
D
dlavigne
Guest
Post the output of ifconfig. Also, anything in /var/log/messages when the copy fails?
djdwosk97
[root@freenas ~]# ifconfig
em0: flags=8c02<BROADCAST,OACTIVE,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=4219b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,TSO4,WOL_MAGIC,VLAN_HWTSO>
ether 00:25:90:d8:5e:b3
media: Ethernet autoselect
status: no carrier
em1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether 00:25:90:d8:5e:b2
inet 192.168.20.15 netmask 0xffffff00 broadcast 192.168.20.255
inet 192.168.20.16 netmask 0xffffff00 broadcast 192.168.20.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
ipfw0: flags=8801<UP,SIMPLEX,MULTICAST> metric 0 mtu 65536
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x6
[root@freenas ~]#
How would I access /var/log?
D
dlavigne
Guest
Type more /var/log/messages from the CLI and use the spacebar to scroll through it.
djdwosk97
Feb 10 00:00:00 freenas syslog-ng[1918]: Configuration reload request received, reloading configuration;
Feb 10 07:34:50 freenas winbindd[2837]: STATUS=daemon 'winbindd' finished starting up and ready to serve connectionssam_rids_to_na
mes: possible deadlock - trying to lookup SID S-1-5-21-1575378786-3262691528-39914409
Feb 10 07:34:52 freenas smbd[62121]: STATUS=daemon 'smbd' finished starting up and ready to serve connectionsFailed to fetch recor
d!
Feb 10 07:34:56 freenas winbindd[2837]: [2016/02/10 07:34:56.397107, 0] ../source3/winbindd/winbindd_samr.c:769(sam_rids_to_names)
Feb 10 07:34:56 freenas winbindd[2837]: sam_rids_to_names: possible deadlock - trying to lookup SID S-1-5-21-1575378786-3262691528
-39914409
Feb 10 09:21:48 freenas smbd[66541]: STATUS=daemon 'smbd' finished starting up and ready to serve connectionsmatchname: host name/
name mismatch: 192.168.20.229 != (NULL)
Feb 10 09:21:48 freenas smbd[66541]: [2016/02/10 09:21:48.132708, 0] ../source3/lib/util_sock.c:1199(get_remote_hostname)
Feb 10 09:21:48 freenas smbd[66541]: matchname failed on 192.168.20.229
Feb 10 09:21:48 freenas winbindd[2837]: [2016/02/10 09:21:48.191595, 0] ../source3/winbindd/winbindd_samr.c:769(sam_rids_to_names)
Feb 10 09:21:48 freenas winbindd[2837]: sam_rids_to_names: possible deadlock - trying to lookup SID S-1-5-21-1575378786-3262691528
-39914409
Feb 10 13:05:19 freenas smbd[74584]: STATUS=daemon 'smbd' finished starting up and ready to serve connectionsmatchname: host name/
Feb 10 13:05:19 freenas smbd[74584]: [2016/02/10 13:05:19.535021, 0] ../source3/lib/util_sock.c:1199(get_remote_hostname)
Feb 10 13:05:19 freenas smbd[74584]: matchname failed on 192.168.20.229
Feb 10 13:05:19 freenas winbindd[2837]: [2016/02/10 13:05:19.590797, 0] ../source3/winbindd/winbindd_samr.c:769(sam_rids_to_names)
Feb 10 13:05:19 freenas winbindd[2837]: sam_rids_to_names: possible deadlock - trying to lookup SID S-1-5-21-1575378786-3262691528
-39914409
Feb 10 16:46:20 freenas smbd[83643]: STATUS=daemon 'smbd' finished starting up and ready to serve connectionsFailed to fetch recor
d!
Feb 10 16:47:55 freenas winbindd[2837]: [2016/02/10 16:47:55.104058, 0] ../source3/winbindd/winbindd_samr.c:769(sam_rids_to_names)
Feb 10 16:47:55 freenas winbindd[2837]: sam_rids_to_names: possible deadlock - trying to lookup SID S-1-5-21-1575378786-3262691528
-39914409
Feb 10 16:47:56 freenas smbd[83706]: STATUS=daemon 'smbd' finished starting up and ready to serve connectionsFailed to fetch recor
d!
Feb 10 16:47:58 freenas winbindd[2837]: [2016/02/10 16:47:58.817358, 0] ../source3/winbindd/winbindd_samr.c:769(sam_rids_to_names)
Feb 10 16:47:58 freenas winbindd[2837]: sam_rids_to_names: possible deadlock - trying to lookup SID S-1-5-21-1575378786-3262691528
-39914409
Feb 10 16:55:48 freenas winbindd[2837]: [2016/02/10 16:55:48.975397, 0] ../source3/winbindd/winbindd_samr.c:769(sam_rids_to_names)
Feb 10 16:55:48 freenas winbindd[2837]: sam_rids_to_names: possible deadlock - trying to lookup SID S-1-5-21-1575378786-3262691528
-39914409
Feb 10 16:56:22 freenas winbindd[2837]: [2016/02/10 16:56:22.022224, 0] ../source3/winbindd/winbindd_samr.c:769(sam_rids_to_names)
Feb 10 16:56:22 freenas winbindd[2837]: sam_rids_to_names: possible deadlock - trying to lookup SID S-1-5-21-1575378786-3262691528
-39914409
Feb 10 16:56:22 freenas smbd[84845]: STATUS=daemon 'smbd' finished starting up and ready to serve connectionsdaniels-rmbp (ipv4:19
2.168.20.211:63024) closed connection to service Photos
Feb 10 16:57:37 freenas smbd[84874]: STATUS=daemon 'smbd' finished starting up and ready to serve connectionsdaniels-rmbp (ipv4:19
2.168.20.211:63030) closed connection to service Photos
Feb 10 16:57:37 freenas winbindd[2837]: [2016/02/10 16:57:37.891971, 0] ../source3/winbindd/winbindd_samr.c:769(sam_rids_to_names)
Feb 10 16:57:37 freenas winbindd[2837]: sam_rids_to_names: possible deadlock - trying to lookup SID S-1-5-21-1575378786-3262691528
-39914409
Feb 10 16:57:37 freenas smbd[84899]: STATUS=daemon 'smbd' finished starting up and ready to serve connectionsdaniels-rmbp (ipv4:19
2.168.20.211:63059) closed connection to service Photos
Feb 10 16:57:37 freenas winbindd[2837]: [2016/02/10 16:57:37.976008, 0] ../source3/winbindd/winbindd_samr.c:769(sam_rids_to_names)
-39914409
Feb 10 16:57:37 freenas smbd[84900]: STATUS=daemon 'smbd' finished starting up and ready to serve connectionsFailed to fetch recor
d!
Feb 10 17:08:21 freenas winbindd[2837]: [2016/02/10 17:08:21.190505, 0] ../source3/winbindd/winbindd_samr.c:769(sam_rids_to_names)
Feb 10 17:08:21 freenas winbindd[2837]: sam_rids_to_names: possible deadlock - trying to lookup SID S-1-5-21-1575378786-3262691528
-39914409
Feb 10 17:08:22 freenas smbd[85928]: STATUS=daemon 'smbd' finished starting up and ready to serve connectionsFailed to fetch recor
d!
Feb 10 17:08:25 freenas winbindd[2837]: [2016/02/10 17:08:25.078979, 0] ../source3/winbindd/winbindd_samr.c:769(sam_rids_to_names)
Feb 10 17:08:25 freenas winbindd[2837]: sam_rids_to_names: possible deadlock - trying to lookup SID S-1-5-21-1575378786-3262691528
-39914409
Is there something wrong with my permissions maybe? (looking through the log I seem to get one or two of these a day with a bunch on the 10th -- the day I was trying to copy stuff up to the drives I thought were failing).
Here are my permissions for all of the datasets (I'm using CIFS and AFP).
DrKK
FreeNAS Generalissimo
He's got a very high Hardware ECC correct number in the SMART data...
