I know there is lots of information in similar threads, and have gone through them, but as I am not 100% sure of what all the output of my smartctl tests means, I thought I would ask for help here as well. I think my drive is going bad and needs to be replaced, but can anyone help with the interpretation of the data? Thanks!
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p28 amd64] (local build) Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD20EFRX-68AX9N0 Serial Number: WD-WMC301661066 LU WWN Device Id: 5 0014ee 6589df4a0 Firmware Version: 80.00A80 User Capacity: 2,000,398,934,016 bytes [2.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2 (minor revision not indicated) SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Tue May 3 17:30:13 2016 EDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 121) The previous self-test completed having the read element of the test failed. Total time to complete Offline data collection: (27060) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 273) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x70bd) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 6482 3 Spin_Up_Time 0x0027 177 177 021 Pre-fail Always - 4125 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 79 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 13 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 066 066 000 Old_age Always - 25120 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 78 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 58 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 20 194 Temperature_Celsius 0x0022 106 095 000 Old_age Always - 41 196 Reallocated_Event_Count 0x0032 187 187 000 Old_age Always - 13 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 5 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed: read failure 90% 25109 14234200 # 2 Extended offline Completed: read failure 90% 25103 14234168 # 3 Extended offline Completed: read failure 90% 25085 14290216 # 4 Extended offline Completed: read failure 90% 25061 89084648 # 5 Extended offline Completed without error 00% 25043 - # 6 Extended offline Completed without error 00% 25019 - # 7 Extended offline Completed without error 00% 24995 - # 8 Extended offline Completed without error 00% 24971 - # 9 Extended offline Completed without error 00% 24947 - #10 Extended offline Completed without error 00% 24923 - #11 Extended offline Completed without error 00% 24899 - #12 Extended offline Completed without error 00% 24875 - #13 Extended offline Completed without error 00% 24851 - #14 Extended offline Completed without error 00% 24827 - #15 Extended offline Completed: read failure 90% 24798 74762880 #16 Extended offline Completed without error 00% 24779 - #17 Extended offline Completed without error 00% 24755 - #18 Extended offline Completed without error 00% 24739 - #19 Extended offline Completed without error 00% 24707 - #20 Extended offline Completed without error 00% 24683 - #21 Extended offline Completed without error 00% 24659 - 1 of 5 failed self-tests are outdated by newer successful extended offline self-test # 5 SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
