Bhoot
- Mar 28, 2015
Just checked I had a "CRITICAL: Device: /dev/ada3, Self-Test Log error count increased from 0 to 1" which I thought was pretty strange.
Nevertheless I did SSH and get the smartctl
in which I am guessing
# 1 Extended offline Completed: read failure 80% 8354 880016000
indicated that I have an issue. Is this the only parameter that shows the disk has a SMART error? Please help me decipher this report. Thank you. :)
I also see a parameter called remaining shown as 80% which was 00% previously. Could someone help me with that as well?
[root@freenas] ~# smartctl -a /dev/ada3 | more smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p31 amd64] (local build) Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD40EFRX-68WT0N0 Serial Number: WD-WCC4E0ESU744 LU WWN Device Id: 5 0014ee 2623ee4e2 Firmware Version: 82.00A82 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2 (minor revision not indicated) SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Thu Feb 9 22:03:10 2017 IST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 120) The previous self-test completed having the read element of the test failed. Total time to complete Offline data collection: (52560) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 526) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x703d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 187 178 021 Pre-fail Always - 7633 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 35 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 089 089 000 Old_age Always - 8393 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 34 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 11 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 841 194 Temperature_Celsius 0x0022 113 107 000 Old_age Always - 39 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed: read failure 80% 8354 880016000 # 2 Short offline Completed without error 00% 8297 - # 3 Short offline Completed without error 00% 8038 - # 4 Extended offline Completed without error 00% 7962 - # 5 Short offline Completed without error 00% 7876 - # 6 Short offline Completed without error 00% 7707 - # 7 Extended offline Completed without error 00% 7628 - # 8 Short offline Completed without error 00% 7576 - # 9 Short offline Completed without error 00% 7301 - #10 Extended offline Completed without error 00% 7219 - #11 Short offline Completed without error 00% 7137 - #12 Short offline Completed without error 00% 6968 - #13 Extended offline Completed without error 00% 6880 - #14 Short offline Completed without error 00% 6803 - #15 Short offline Completed without error 00% 6581 - #16 Extended offline Completed without error 00% 6494 - #17 Short offline Completed without error 00% 6413 - #18 Short offline Completed without error 00% 6247 - #19 Extended offline Completed without error 00% 6164 - #20 Short offline Completed without error 00% 6085 - #21 Short offline Completed without error 00% 5836 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
