VictorR
- Dec 9, 2015
FreeNAS-11.1-U4
45 Drives Q30
SuperMicro X10DRL
2x E52620 v3 CPU
2x 120GB SSD Boot Drive
256GB RAM
2x LSI 9201 HBA
30x WD Re 4TB drives
3x X540T2BLK Intel X540 DA2
Our 3 year old, 120TB/30-drive(RAID Z2), NAS recently started showing critical alerts for multiple drives. We've had single drives(5) develop 8-10 bad sectors over the years, and replaced them under warranty. These drives are getting long in the tooth, so this is no surprise. I'm just wondering if any of these errors are worthy of concern?
I have short and long SMART tests set to once a week, and bi-weekly, respectively. The most recent "freenas.local daily run output" returned:
Scrub runs with no errors or repairs.
My concern is about the "DEGRADED da26p1" drive. Although, its SMART test finds no errors. While the other drives do
45 Drives Q30
SuperMicro X10DRL
2x E52620 v3 CPU
256GB RAM
2x LSI 9201 HBA
CRITICAL: April 18, 2018, 4:45 p.m. - Device: /dev/da11 [SAT], 2 Currently unreadable (pending) sectors
CRITICAL: April 18, 2018, 4:45 p.m. - Device: /dev/da11 [SAT], 1 Offline uncorrectable sectors
CRITICAL: April 19, 2018, 4:55 p.m. - Device: /dev/da11 [SAT], Self-Test Log error count increased from 0 to 1
CRITICAL: April 20, 2018, 3:54 p.m. - Device: /dev/da11 [SAT], Self-Test Log error count increased from 1 to 2
CRITICAL: April 18, 2018, 4:45 p.m. - Device: /dev/da7 [SAT], 1 Currently unreadable (pending) sectors
CRITICAL: April 18, 2018, 4:45 p.m. - Device: /dev/da7 [SAT], 1 Offline uncorrectable sectors
CRITICAL: April 20, 2018, 6:56 p.m. - Device: /dev/da7 [SAT], Self-Test Log error count increased from 0 to 1
CRITICAL: April 18, 2018, 4:45 p.m. - Device: /dev/da27 [SAT], 1 Currently unreadable (pending) sectors
Checking status of gmirror(8) devices:
Name Status Components
mirror/swap0 COMPLETE da29p1 (ACTIVE)
da28p1 (ACTIVE)
mirror/swap1 DEGRADED da26p1 (ACTIVE)
mirror/swap2 COMPLETE da25p1 (ACTIVE)
da24p1 (ACTIVE)
mirror/swap3 COMPLETE da23p1 (ACTIVE)
da22p1 (ACTIVE)
mirror/swap4 COMPLETE da21p1 (ACTIVE)
da20p1 (ACTIVE)
-- End of daily output --
[root@freenas ~]# smartctl -a /dev/da26 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Re Device Model: WDC WD4000FYYZ-01UL1B2 Serial Number: WD-WCC134xxxxx LU WWN Device Id: 5 0014ee 2b75a8f52 Firmware Version: 01.01K03 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Sector Size: 512 bytes logical/physical Rotation Rate: 7200 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ATA8-ACS (minor revision not indicated) SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Mon Apr 23 21:09:55 2018 PDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (48240) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 521) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x70bd) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 211 158 021 Pre-fail Always - 8425 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 107 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0 9 Power_On_Hours 0x0032 074 074 000 Old_age Always - 19030 10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 107 183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 105 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 1 194 Temperature_Celsius 0x0022 117 107 000 Old_age Always - 35 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 18960 - # 2 Short offline Completed without error 00% 18959 - # 3 Short offline Completed without error 00% 18958 - # 4 Short offline Completed without error 00% 18957 - # 5 Short offline Completed without error 00% 18956 - # 6 Short offline Completed without error 00% 18955 - # 7 Short offline Completed without error 00% 18954 - # 8 Short offline Completed without error 00% 18953 - # 9 Short offline Completed without error 00% 18952 - #10 Short offline Completed without error 00% 18951 - #11 Short offline Completed without error 00% 18950 - #12 Extended offline Completed without error 00% 18937 - #13 Short offline Completed without error 00% 18928 - #14 Extended offline Completed without error 00% 18918 - #15 Short offline Completed without error 00% 18909 - #16 Short offline Completed without error 00% 14426 - #17 Short offline Completed without error 00% 14425 - #18 Short offline Completed without error 00% 14424 - #19 Short offline Completed without error 00% 14423 - #20 Short offline Completed without error 00% 14422 - #21 Short offline Completed without error 00% 14421 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
[root@freenas ~]# smartctl -a /dev/da11 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Re Device Model: WDC WD4000FYYZ-01UL1B2 Serial Number: WD-WCC130ADRTTJ LU WWN Device Id: 5 0014ee 20cb0a76e Firmware Version: 01.01K03 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Sector Size: 512 bytes logical/physical Rotation Rate: 7200 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ATA8-ACS (minor revision not indicated) SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Mon Apr 23 20:54:51 2018 PDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (47100) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 509) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x70bd) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 188 159 021 Pre-fail Always - 9566 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 101 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0 9 Power_On_Hours 0x0032 074 074 000 Old_age Always - 19028 10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 101 183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 99 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 1 194 Temperature_Celsius 0x0022 122 111 000 Old_age Always - 30 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 2 198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 1 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 8 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 18959 - # 2 Short offline Completed without error 00% 18958 - # 3 Short offline Completed without error 00% 18957 - # 4 Short offline Completed without error 00% 18956 - # 5 Short offline Completed without error 00% 18955 - # 6 Short offline Completed without error 00% 18954 - # 7 Short offline Completed without error 00% 18953 - # 8 Short offline Completed without error 00% 18952 - # 9 Short offline Completed: read failure 90% 18951 28449989 #10 Short offline Completed without error 00% 18950 - #11 Short offline Completed without error 00% 18949 - #12 Extended offline Completed: read failure 90% 18928 28357609 #13 Short offline Completed without error 00% 18927 - #14 Extended offline Completed without error 00% 18917 - #15 Short offline Completed without error 00% 18908 - #16 Short offline Completed without error 00% 17393 - #17 Short offline Completed without error 00% 17392 - #18 Short offline Completed without error 00% 17391 - #19 Short offline Completed without error 00% 17353 - #20 Short offline Completed without error 00% 17352 - #21 Short offline Completed without error 00% 17351 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
