Soloam
- Feb 14, 2014
I've been getting errors from a drive, can any one help me analise it? What should I look at when looking at a SMART test? Please advise and if possible explain what should I look for on this test to anticipate this problems.
Thank You
root@freenas:~ # smartctl /dev/da1 smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.1-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org ATA device successfully opened Use 'smartctl -a' (or '-x') to print SMART (and more) information root@freenas:~ # clear root@freenas:~ # smartctl -a /dev/da1 smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.1-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD20EFRX-68EUZN0 Serial Number: WD-WCC4M6NJ37C0 LU WWN Device Id: 5 0014ee 261ea1d81 Firmware Version: 82.00A82 User Capacity: 2,000,398,934,016 bytes [2.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2 (minor revision not indicated) SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Fri Apr 20 20:28:08 2018 WEST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (25980) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 263) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x703d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 198 198 051 Pre-fail Always - 91345 3 Spin_Up_Time 0x0027 175 175 021 Pre-fail Always - 4208 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 67 5 Reallocated_Sector_Ct 0x0033 184 184 140 Pre-fail Always - 481 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 078 078 000 Old_age Always - 16732 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 67 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 65 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 641 194 Temperature_Celsius 0x0022 106 096 000 Old_age Always - 41 196 Reallocated_Event_Count 0x0032 001 001 000 Old_age Always - 327 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 15 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 199 000 Old_age Offline - 10 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 16696 - # 2 Short offline Completed without error 00% 16528 - # 3 Extended offline Completed: read failure 90% 16432 298136 # 4 Short offline Completed without error 00% 16357 - # 5 Short offline Completed without error 00% 16123 - # 6 Extended offline Completed: read failure 80% 16025 27490176 # 7 Short offline Completed without error 00% 15952 - # 8 Short offline Completed without error 00% 15782 - # 9 Short offline Completed without error 00% 15616 - #10 Short offline Completed without error 00% 15451 - #11 Extended offline Completed without error 00% 15357 - #12 Short offline Completed without error 00% 15280 - #13 Short offline Completed without error 00% 15112 - #14 Extended offline Completed without error 00% 15023 - #15 Short offline Completed without error 00% 14949 - #16 Short offline Completed without error 00% 14708 - #17 Extended offline Completed: read failure 90% 14609 72814392 #18 Short offline Completed without error 00% 14382 - #19 Extended offline Completed without error 00% 14293 - #20 Short offline Completed without error 00% 14214 - #21 Short offline Completed without error 00% 13976 - 1 of 3 failed self-tests are outdated by newer successful extended offline self-test #11 SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
Thank You
