AlpineM345
- Jul 25, 2015
Hi all,
I have two drives running in mirror. One of drives is showing intermittent short test failures, but it passes extended tests. See below for the smartctl output. It is just outside of warranty, so I cannot send it back for a replacement either. Do you think this hard drive is failing? I am running FreeNAS 9.10 by the way. Any comments would be appreciated.
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD40EFRX-68WT0N0 Serial Number: WD-WCC4E3FAELPR LU WWN Device Id: 5 0014ee 20bd64d08 Firmware Version: 82.00A82 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2 (minor revision not indicated) SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Tue Jul 17 21:40:16 2018 PDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (52560) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 526) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x703d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 174 174 021 Pre-fail Always - 8266 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 66 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 064 064 000 Old_age Always - 26705 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 66 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 43 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 291 194 Temperature_Celsius 0x0022 119 112 000 Old_age Always - 33 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 6 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 26700 - # 2 Short offline Completed: read failure 60% 26685 1512352 # 3 Short offline Completed without error 00% 26637 - # 4 Short offline Completed without error 00% 26589 - # 5 Short offline Completed without error 00% 26541 - # 6 Short offline Completed without error 00% 26493 - # 7 Extended offline Completed without error 00% 26480 - # 8 Short offline Completed without error 00% 26445 - # 9 Short offline Completed without error 00% 26397 - #10 Short offline Completed without error 00% 26351 - #11 Short offline Completed without error 00% 26303 - #12 Short offline Completed without error 00% 26255 - #13 Extended offline Completed without error 00% 26224 - #14 Short offline Completed: read failure 60% 26207 1512352 #15 Short offline Completed without error 00% 26159 - #16 Short offline Completed without error 00% 26111 - #17 Extended offline Completed without error 00% 26098 - #18 Short offline Completed without error 00% 26063 - #19 Short offline Completed without error 00% 26015 - #20 Short offline Completed without error 00% 25967 - #21 Short offline Completed without error 00% 25919 - 2 of 2 failed self-tests are outdated by newer successful extended offline self-test # 1 SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
