I currently have two 1TB drives mirror'd in my server, both of which are on their way out. Rather than just throwing the two drives out, my plan was to backup some data onto one/both drives and throw it/them in a fire safe. But I was wondering if there is an easy way to copy the data to the drive/s without having to remove the drive from the server so that it's readable if I plugged it directly into a windows pc.
I know using dying drives as a backup isn't a great idea, but I figure I either use them or they go in the garbage. So it's better than nothing. One of the drives was throwing CAM errors the other day, and the other one just threw an "unreadable (pending) sector" error and an "offline uncorrectable sector" error. I assume the latter is the lesser of the two evils?
The smart report for the two drives (the WD Green through the unreadable sector error and the Barracuda the CAM error):
[root@freenas] ~# smartctl -a /dev/ada4 smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p31 amd64] (local build) Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Caviar Green (AF) Device Model: WDC WD10EARS-00MVWB0 Serial Number: WD-WCAZA0709278 LU WWN Device Id: 5 0014ee 25a4a1057 Firmware Version: 51.0AB51 User Capacity: 1,000,204,886,016 bytes [1.00 TB] Sector Size: 512 bytes logical/physical Device is: In smartctl database [for details use: -P show] ATA Version is: ATA8-ACS (minor revision not indicated) SATA Version is: SATA 2.6, 3.0 Gb/s Local Time is: Fri Feb 26 10:19:04 2016 EST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82)Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0)The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (17880) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003)Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01)Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 175) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x3035)SCT Status supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 24 3 Spin_Up_Time 0x0027 170 163 021 Pre-fail Always - 6483 4 Start_Stop_Count 0x0032 088 088 000 Old_age Always - 12650 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 055 055 000 Old_age Always - 33033 10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 127 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 74 193 Load_Cycle_Count 0x0032 001 001 000 Old_age Always - 1248695 194 Temperature_Celsius 0x0022 122 089 000 Old_age Always - 28 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 1 198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 1 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 18 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 33026 - # 2 Extended offline Completed without error 00% 32950 - # 3 Short offline Completed without error 00% 32874 - # 4 Short offline Completed without error 00% 32707 - # 5 Extended offline Completed without error 00% 32615 - # 6 Short offline Completed without error 00% 32539 - # 7 Extended offline Completed without error 00% 32340 - # 8 Short offline Completed without error 00% 32264 - # 9 Short offline Completed without error 00% 32096 - #10 Extended offline Completed without error 00% 32004 - #11 Short offline Completed without error 00% 31929 - #12 Extended offline Completed without error 00% 31764 - #13 Extended offline Completed without error 00% 31597 - #14 Extended offline Completed without error 00% 31429 - #15 Extended offline Completed without error 00% 31262 - #16 Extended offline Completed without error 00% 31094 - #17 Extended offline Completed without error 00% 31046 - #18 Extended offline Completed without error 00% 30878 - #19 Extended offline Completed without error 00% 30710 - #20 Extended offline Completed without error 00% 30375 - #21 Extended offline Completed without error 00% 30302 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
[root@freenas] ~# smartctl -a /dev/ada5 smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p31 amd64] (local build) Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Seagate Barracuda 7200.12 Device Model: ST31000528AS Serial Number: 5VP253Z9 LU WWN Device Id: 5 000c50 01c4ee5d6 Firmware Version: CC38 User Capacity: 1,000,204,886,016 bytes [1.00 TB] Sector Size: 512 bytes logical/physical Rotation Rate: 7200 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 2.6, 3.0 Gb/s Local Time is: Fri Feb 26 10:22:16 2016 EST ==> WARNING: A firmware update for this drive may be available, see the following Seagate web pages: http://knowledge.seagate.com/articles/en_US/FAQ/207931en http://knowledge.seagate.com/articles/en_US/FAQ/213891en SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED See vendor-specific Attribute list for marginal Attributes. General SMART Values: Offline data collection status: (0x82)Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0)The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 609) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003)Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01)Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 184) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x103f)SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 114 099 006 Pre-fail Always - 71664840 3 Spin_Up_Time 0x0003 095 094 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 605 5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 061 055 030 Pre-fail Always - 107404513924 9 Power_On_Hours 0x0032 090 090 000 Old_age Always - 9392 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 136 183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0 184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 099 000 Old_age Always - 55835426829 189 High_Fly_Writes 0x003a 098 098 000 Old_age Always - 2 190 Airflow_Temperature_Cel 0x0022 074 043 045 Old_age Always In_the_past 26 (0 5 28 26 0) 194 Temperature_Celsius 0x0022 026 057 000 Old_age Always - 26 (0 15 0 0 0) 195 Hardware_ECC_Recovered 0x001a 028 024 000 Old_age Always - 71664840 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 6284 (130 100 0) 241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 2741848620 242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 1206011172 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 9385 - # 2 Extended offline Completed without error 00% 9309 - # 3 Short offline Completed without error 00% 9233 - # 4 Short offline Completed without error 00% 9065 - # 5 Extended offline Completed without error 00% 8973 - # 6 Short offline Completed without error 00% 8897 - # 7 Extended offline Completed without error 00% 8697 - # 8 Short offline Completed without error 00% 8622 - # 9 Short offline Completed without error 00% 8454 - #10 Extended offline Completed without error 00% 8362 - #11 Short offline Completed without error 00% 8286 - #12 Extended offline Completed without error 00% 8121 - #13 Extended offline Completed without error 00% 7954 - #14 Extended offline Completed without error 00% 7786 - #15 Extended offline Completed without error 00% 7618 - #16 Extended offline Completed without error 00% 7449 - #17 Extended offline Completed without error 00% 7401 - #18 Extended offline Completed without error 00% 7233 - #19 Extended offline Completed without error 00% 7065 - #20 Extended offline Interrupted (host reset) 00% 6897 - #21 Extended offline Completed without error 00% 6729 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
