I currently have two 1TB drives mirror'd in my server, both of which are on their way out. Rather than just throwing the two drives out, my plan was to backup some data onto one/both drives and throw it/them in a fire safe. But I was wondering if there is an easy way to copy the data to the drive/s without having to remove the drive from the server so that it's readable if I plugged it directly into a windows pc.
I know using dying drives as a backup isn't a great idea, but I figure I either use them or they go in the garbage. So it's better than nothing. One of the drives was throwing CAM errors the other day, and the other one just threw an "unreadable (pending) sector" error and an "offline uncorrectable sector" error. I assume the latter is the lesser of the two evils?
The smart report for the two drives (the WD Green through the unreadable sector error and the Barracuda the CAM error):
[root@freenas] ~# smartctl -a /dev/ada4
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p31 amd64] (local build)
Model Family: Western Digital Caviar Green (AF)
Device Model: WDC WD10EARS-00MVWB0
Serial Number: WD-WCAZA0709278
LU WWN Device Id: 5 0014ee 25a4a1057
Firmware Version: 51.0AB51
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Sector Size: 512 bytes logical/physical
ATA Version is: ATA8-ACS (minor revision not indicated)
SATA Version is: SATA 2.6, 3.0 Gb/s
Local Time is: Fri Feb 26 10:19:04 2016 EST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82)Offline data collection activity
was completed without error.
Self-test execution status: ( 0)The previous self-test routine completed
been run.
data collection: (17880) seconds.
command.
Self-test supported.
SMART capabilities: (0x0003)Saves SMART data before entering
power-saving mode.
Error logging capability: (0x01)Error logging supported.
Short self-test routine
Extended self-test routine
recommended polling time: ( 175) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x3035)SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 24
3 Spin_Up_Time 0x0027 170 163 021 Pre-fail Always - 6483
4 Start_Stop_Count 0x0032 088 088 000 Old_age Always - 12650
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 055 055 000 Old_age Always - 33033
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 127
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 74
193 Load_Cycle_Count 0x0032 001 001 000 Old_age Always - 1248695
194 Temperature_Celsius 0x0022 122 089 000 Old_age Always - 28
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 1
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 1
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 18
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 33026 -
# 2 Extended offline Completed without error 00% 32950 -
# 3 Short offline Completed without error 00% 32874 -
# 4 Short offline Completed without error 00% 32707 -
# 5 Extended offline Completed without error 00% 32615 -
# 6 Short offline Completed without error 00% 32539 -
# 7 Extended offline Completed without error 00% 32340 -
# 8 Short offline Completed without error 00% 32264 -
# 9 Short offline Completed without error 00% 32096 -
#10 Extended offline Completed without error 00% 32004 -
#11 Short offline Completed without error 00% 31929 -
#12 Extended offline Completed without error 00% 31764 -
#13 Extended offline Completed without error 00% 31597 -
#14 Extended offline Completed without error 00% 31429 -
#15 Extended offline Completed without error 00% 31262 -
#16 Extended offline Completed without error 00% 31094 -
#17 Extended offline Completed without error 00% 31046 -
#18 Extended offline Completed without error 00% 30878 -
#19 Extended offline Completed without error 00% 30710 -
#20 Extended offline Completed without error 00% 30375 -
#21 Extended offline Completed without error 00% 30302 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
[root@freenas] ~# smartctl -a /dev/ada5
Model Family: Seagate Barracuda 7200.12
Device Model: ST31000528AS
Serial Number: 5VP253Z9
LU WWN Device Id: 5 000c50 01c4ee5d6
Firmware Version: CC38
Rotation Rate: 7200 rpm
ATA Version is: ATA8-ACS T13/1699-D revision 4
Local Time is: Fri Feb 26 10:22:16 2016 EST
==> WARNING: A firmware update for this drive may be available,
see the following Seagate web pages:
http://knowledge.seagate.com/articles/en_US/FAQ/207931en
http://knowledge.seagate.com/articles/en_US/FAQ/213891en
See vendor-specific Attribute list for marginal Attributes.
been run.
data collection: ( 609) seconds.
command.
power-saving mode.
recommended polling time: ( 184) minutes.
SCT capabilities: (0x103f)SCT Status supported.
1 Raw_Read_Error_Rate 0x000f 114 099 006 Pre-fail Always - 71664840
3 Spin_Up_Time 0x0003 095 094 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 605
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 061 055 030 Pre-fail Always - 107404513924
9 Power_On_Hours 0x0032 090 090 000 Old_age Always - 9392
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 136
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 099 000 Old_age Always - 55835426829
189 High_Fly_Writes 0x003a 098 098 000 Old_age Always - 2
190 Airflow_Temperature_Cel 0x0022 074 043 045 Old_age Always In_the_past 26 (0 5 28 26 0)
194 Temperature_Celsius 0x0022 026 057 000 Old_age Always - 26 (0 15 0 0 0)
195 Hardware_ECC_Recovered 0x001a 028 024 000 Old_age Always - 71664840
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 6284 (130 100 0)
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 2741848620
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 1206011172
No Errors Logged
# 1 Short offline Completed without error 00% 9385 -
# 2 Extended offline Completed without error 00% 9309 -
# 3 Short offline Completed without error 00% 9233 -
# 4 Short offline Completed without error 00% 9065 -
# 5 Extended offline Completed without error 00% 8973 -
# 6 Short offline Completed without error 00% 8897 -
# 7 Extended offline Completed without error 00% 8697 -
# 8 Short offline Completed without error 00% 8622 -
# 9 Short offline Completed without error 00% 8454 -
#10 Extended offline Completed without error 00% 8362 -
#11 Short offline Completed without error 00% 8286 -
#12 Extended offline Completed without error 00% 8121 -
#13 Extended offline Completed without error 00% 7954 -
#14 Extended offline Completed without error 00% 7786 -
#15 Extended offline Completed without error 00% 7618 -
#16 Extended offline Completed without error 00% 7449 -
#17 Extended offline Completed without error 00% 7401 -
#18 Extended offline Completed without error 00% 7233 -
#19 Extended offline Completed without error 00% 7065 -
#20 Extended offline Interrupted (host reset) 00% 6897 -
#21 Extended offline Completed without error 00% 6729 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
