Setting up Plex to auto-update within iocage jail using cron
Mark Holtz
I am currently running TrueNAS-13.0-U5.3 with Plex set up in a jail and the following configuration:
Version: 1.32.5.7328
Plugin: plexmediaserver-plexpass
Release: 13.1-RELEASE-p9
Collection: https://github.com/freenas/iocage-ix-plugins.git
I have been utilizing a script at https://github.com/mstinaff/PMS_Updater to update the server, and have it set up to run as a cron job with the iocage as follows:
# Run the Plex update job weekly on Sundays at 23:00 (11:00 PM)
0 23 * * 0      $HOME/backupplex.sh
# Run the PMS Updater on a daily basis at 06:00 (6:00 AM)
#0 6 * * *      $HOME/PMS_Updater.sh
Unfortunately, a bad update took my Plex server down. Apparently, the incorrect token is now being passed, so I had to comment out that cron. Are they any suggestions for a better script that I can run to update Plex?
cdiddy
Did you check my signature?
There is a full plex install that updates itself included there.
where is your signature? I don't see it at the bottom of that post...
Davvo
From mobile view you can't see signatures. Switch to dekstop view.
victort
Or zoom out…
