MauricioU
 - May 22, 2017
*EDIT----------
I took a crack at question 2 and seemed to have figured it out. Only outstanding question is it seems like the script did NOT set up a cron job for updating plex—at least as reflected in the WebGUI under tasks. Is there a way to check this?
Hi all,
I have 2 questions I am hoping someone can help with.
1. When I run Danb's script for installing plex, it seems like it is working, but I am not seeing the additional cron job that updates the plex server added in my tasks? Is this normal?
2. I am following these instructions to upgrade one of my jails just to try it:
I am running into this problem:
I have no idea what to modify to "Resolve the conflicts". Some preliminary research, without going down the rabbit hole, has led me to understand everything between <<< and === is the current version and everything after === and before >>> is the new version of the file that is unable to merge. Should I delete everything that is the "current version"? Not a super important jail I'm trying this on, but thought I'd ask here first. Looking forward to the help!
Hi all,
In a nutshell, yes. The steps, from memory, are:
- Upgrade to TrueNAS 12.0-U5 or later
- On SSH session to TrueNAS,iocage fetchand grab 12.2-RELEASE
-iocage list -land theniocage upgrade -r 12.2-RELEASE jailnamefor one of the base jails, and every clone jail
- For each jail:iocage console jailnamethenpkg-static install -f -y pkgand thenpkg upgrade -y
And that should do it. All jails upgraded to 12.2 and in line with TrueNAS Core 12.0, which runs FreeBSD 12.2.
Attempting to automatically merge changes in files... done. The following file could not be merged automatically: /etc/mail/mailer.conf Press Enter to edit this file in /usr/bin/vi and resolve the conflicts manually... <<<<<<< current version # $FreeBSD: releng/12.3/etc/mail/mailer.conf 363973 2020-08-06 18:13:45Z kevans $ # # Execute the "real" sendmail program, named /usr/libexec/sendmail/sendmail # #sendmail /usr/libexec/sendmail/sendmail #mailq /usr/libexec/sendmail/sendmail #newaliases /usr/libexec/sendmail/sendmail #hoststat /usr/libexec/sendmail/sendmail #purgestat /usr/libexec/sendmail/sendmail # # Execute the Postfix sendmail program, named /usr/local/sbin/sendmail # sendmail /usr/local/sbin/sendmail send-mail /usr/local/sbin/sendmail mailq /usr/local/sbin/sendmail newaliases /usr/local/sbin/sendmail ======= # $FreeBSD$ # # Execute the "real" sendmail program, named /usr/libexec/sendmail/sendmail # # If dma(8) is installed, an example mailer.conf that uses dma(8) instead can # can be found in /usr/share/examples/dma. # sendmail /usr/libexec/sendmail/sendmail mailq /usr/libexec/sendmail/sendmail newaliases /usr/libexec/sendmail/sendmail purgestat /usr/libexec/sendmail/sendmail >>>>>>> 13.2-RELEASE ~
