smartctl -l selftest /dev/ada0
smartctl -a /dev/YourDrive
the configuration database and will be reset on reboot. root@Atlas[~]# smartctl -a /dev/da2 smartctl 7.1 2019-12-30 r5022 [FreeBSD 12.2-RELEASE-p2 amd64] (local build) Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Seagate IronWolf Device Model: ST4000VN008-2DR166 Serial Number: ZGY58MX5 LU WWN Device Id: 5 000c50 0b689d6e8 Firmware Version: SC60 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5980 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-3 T13/2161-D revision 5 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Thu Jan 7 13:38:22 2021 EST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 581) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 595) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x50bd) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 080 064 044 Pre-fail Always - 99000064 3 Spin_Up_Time 0x0003 093 093 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 16 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 090 060 045 Pre-fail Always - 923960578 9 Power_On_Hours 0x0032 087 087 000 Old_age Always - 11702 (120 229 0) 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 16 184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0022 074 059 040 Old_age Always - 26 (Min/Max 25/29) 191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 45 193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 100 194 Temperature_Celsius 0x0022 026 041 000 Old_age Always - 26 (0 8 0 0 0) 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 11701 (82 63 0) 241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 65011101522 242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 15920989286 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 11695 - # 2 Short offline Completed without error 00% 11671 - # 3 Short offline Completed without error 00% 11623 - # 4 Short offline Completed without error 00% 11575 - # 5 Short offline Completed without error 00% 11455 - # 6 Short offline Completed without error 00% 11408 - # 7 Short offline Completed without error 00% 11360 - # 8 Short offline Completed without error 00% 11312 - # 9 Short offline Completed without error 00% 11264 - #10 Short offline Completed without error 00% 11216 - #11 Short offline Completed without error 00% 11168 - #12 Short offline Completed without error 00% 11120 - #13 Short offline Completed without error 00% 11072 - #14 Short offline Completed without error 00% 11024 - #15 Short offline Completed without error 00% 10976 - #16 Extended offline Completed without error 00% 10952 - #17 Short offline Completed without error 00% 10928 - #18 Short offline Completed without error 00% 10880 - #19 Short offline Completed without error 00% 10832 - #20 Short offline Completed without error 00% 10736 - #21 Short offline Completed without error 00% 10688 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing
Call me crazy, but something listed as "S.M.A.R.T. Test Results", I would expect to see S.M.A.R.T. test...... results.As long as the test does not return any warning or error, they are silent. So here, you can consider that "no news is good news".
Call me crazy,
And where did you saw that ? Here, I reviewed my new-to-me TrueNAS interface and I found SMART Test Tasks but nothing named Smart tests results...
Did you see my post with the screenshot?
That's an issue I have with some of the UI design and documentation. The user should not "expect" anything when it comes to these features. If the GUI presents a section with a particular name or description, it needs to abide by that and give a clear explanation for its function.But as I said, FreeNAS returns the results of failed tests, so I expect you will see only failure there.
This problem has been brought up several times since TrueNAS 12 hit the streets and the problem will eventually be fixed but I would not consider this a high priority problem as there are other problems which need to be addressed first. For now just look at SMART results the way we have been ever since FreeNAS was created. I don't particularly like AGILE programming but that is how things have migrated in the world of software, build something that provides some functionality and publish it. The code may not be perfect so long as it isn't harmful then you take the next step and AGILE mentality will get the next piece of the puzzle going. It can take a long time using this process vs the old way of creating a full product that has been fully tested and is fully functional. Again, I'm not a fan of AGILE but it's here.They might as well remove the section of "S.M.A.R.T. Test Results" if the only way to really review the results is through the command-line.
