Reset Configuration then upgraded from 11.2 to 11.2U4.1. Pools and data are fine, but disks don't show under storage/disks
kjsdad
Basically I ended up installing a brand new 11.2u4.1. It didn't show my disks. I had to unplug my disks boot up then shutdown. Plug in my disks boot up and then I was able to import my pool. On the dashboard it shows my disks, but says disk details not available. When I look under storage/disks there are none. What is up?
kjsdad
Marvell 9230 sata3 and Marvell 9172 stat3. FYI the disks showed up fine before the reset.
kjsdad
FYI when I try to turn on s.m.a.r.t. : freeness smart[9684]: Configuration file /usr/local/etc/smartd.conf parsed but has no entries.
When trying to look at my available plugins:
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 166, in call_method
result = await self.middleware.call_method(self, message)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1097, in call_method
return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1042, in _call
return await self._call_worker(name, *args)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1062, in _call_worker
return await self.run_in_proc(main_worker, name, args, job)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 996, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 972, in run_in_executor
RuntimeError: <urlopen error [Errno 8] hostname nor servname provided, or not known>
D
dlavigne
Guest
If the issue persists for you, please create a report at bugs.ixsystems.com and post the issue number here.
