Hi everyone!
First of all, noob poster here so I'm not sure if the bug reporting workflow is to post here first, discuss it, confirm it's a bug then open a Jira ticket or to just go into jira directly
So, I did a fresh install of 22.02.2 on a server with an fusion-io ioDrive duo (2 ssd disks on 1 pcie card) and after installing the drivers and fio-util linux packages I can see and use the disks via the shell no problem but these disks no longer show up under `Storage > Disks` in the web GUI.
I think the cause of this bug is the NAS-116433 optimization since they show up and work on 22.02.1.
Side note regarding 22.02.1 & fusion devices: I ran into another snag when trying to add 2 fio drives as mirrored slog devices to an existing pool but managed to figure out a workaround; for anyone interested, here's a link to my quick guide).
Maybe related: the fusion cards don't expose the disk serial number like a regular ssd would. They also don't support SMART yet the GUI says smart is enabled?
The disks have serial numbers which I can get via a fio-utils command: `fio-status --field iom.fio_serial_number /dev/fioa` (which returns just the numeric serial of the device)...so I'm wondering:
What do you guys think?
Thanks for reading!
- Does anyone know what command is called that gets the disk list + serial number data (maybe `smartctl`)? I'm able to write a custom wrapper command so that it'll use the fio-status to get the serial for fusion devices.
- If the above won't be possible, am I able to somehow tell truenas what an alternative serial number command to use? I don't mind getting my hands dirty since I'm a dev.
- Maybe a better solution to the above is to use the devlink values as a fallback serial number placeholder? e.g. there's unique entries for both fusion cards under: `/dev/disk/by-id` and `/dev/disk/by-path`.
Thanks for reading!
