NVMe drives in USB case show same Serial Number
pvries86
I have attached to NVMe drives in USB cases to my HPE Microserver Gen10+.
In the GUI in can only see one. The serial number for both drives shows as "0123456789ABCDEF" which is probably the cause for this.
Is there a way to to make the GUI read the correct serial number? Or change the serial number shown in the GUI?
If I use smartctl to check the drive info, the correct serial number is shown:
Drive 1:
smartctl -a /dev/sdf
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.10.18+truenas] (local build)
Model Number:                       MTFDHBA256TCK-1AS1AABHA
Serial Number:                      UHPVN01ZRCD12Q
Firmware Version:                   HPS0V23
PCI Vendor/Subsystem ID:            0x1344
IEEE OUI Identifier:                0x00a075
Controller ID:                      0
NVMe Version:                       1.2.1
Drive 2:
smartctl -a /dev/sdg
Serial Number:                      UHPVN01ZRCCCQ8
Controller ID:                      0
NVMe Version:                       1.2.1
Alecmascot
Target release for the fix is Beta.1
Alecmascot
In the ticket
darkkent
Ah okay so there isn't a fix for it yet, but it will be release in beta.1?
sorry not had to do this before
