dvaezazizi
 - Jul 11, 2018
- HPE DL325 Gen10 Plus V2
 - Epyc 7513
 - 256GB RAM
 - 16x NVMe direct attach
 - QLogic Corp. FastLinQ QL41000 Series 10/25/40/50GbE Controller
 - Linux truenas 5.10.142+truenas #1 SMP Mon Sep 26 18:20:46 UTC 2022 x86_64 GNU/Linux
2022 Oct 30 16:38:18 truenas Device: /dev/nvme4n1, number of Error Log entries increased from 230917 to 231033
2022 Oct 30 16:38:18 truenas Device: /dev/nvme1n1, number of Error Log entries increased from 214056 to 214172
2022 Oct 30 16:38:18 truenas Device: /dev/nvme0n1, number of Error Log entries increased from 213937 to 214053
2022 Oct 30 16:38:18 truenas Device: /dev/nvme5n2, number of Error Log entries increased from 36162 to 36278
2022 Oct 30 16:38:18 truenas Device: /dev/nvme7n1, number of Error Log entries increased from 27371 to 27487
Model Number: TCM615T4P5xnFTRI
Serial Number: <removed>
Firmware Version: 3P01
PCI Vendor ID: 0x1e0f
PCI Vendor Subsystem ID: 0x1590
IEEE OUI Identifier: 0x8ce38e
Total NVM Capacity: 15,360,950,534,144 [15.3 TB]
Unallocated NVM Capacity: 312,458,870,784 [312 GB]
Controller ID: 1
NVMe Version: 1.4
Number of Namespaces: 1
Namespace 1 Size/Capacity?: 15,048,491,663,360 [15.0 TB]
Namespace 1 Utilization: 2,165,793,648,640 [2.16 TB]
Namespace 1 Formatted LBA Size: 4096
Namespace 1 IEEE EUI-64: 8ce38e e209a49501
Local Time is: Sun Oct 30 16:37:26 2022 PDT
Firmware Updates (0x16): 3 Slots, no Reset required
Optional Admin Commands (0x025f): Security Format Frmw_DL NS_Mngmt Self_Test MI_Snd/Rec Get_LBA_Sts
Optional NVM Commands (0x00ff): Comp Wr_Unc DS_Mngmt Wr_Zero Sav/Sel_Feat Resv Timestmp Verify
Log Page Attributes (0x1e): Cmd_Eff_Lg Ext_Get_Lg Telmtry_Lg Pers_Ev_Lg
Maximum Data Transfer Size: 8192 Pages
Warning Comp. Temp. Threshold: 76 Celsius
Critical Comp. Temp. Threshold: 82 Celsius
Namespace 1 Features (0x10): NP_Fields
Supported Power States
St Op Max Active Idle RL RT WL WT Ent_Lat Ex_Lat
Supported LBA Sizes (NSID 0x1)0 + 27.50W 25.00W - 0 0 0 0 500000 500000
1 + 19.80W 18.00W - 0 0 1 1 500000 500000
2 + 17.60W 16.00W - 0 0 2 2 500000 500000
3 + 15.40W 14.00W - 1 1 3 3 500000 500000
4 + 12.10W 11.00W - 2 2 4 4 500000 500000
5 + 9.90W 9.00W - 3 3 5 5 500000 500000
6 - 5.00W - - 6 6 6 6 500000 500000
Id Fmt Data Metadt Rel_Perf
0 - 512 0 0
1 - 512 8 0
2 - 1 0 0
3 + 4096 0 0
4 - 4096 8 0
5 - 4096 64 0
START OF SMART DATA SECTION
SMART overall-health self-assessment test result: PASSEDSMART/Health Information (NVMe Log 0x02)
Critical Warning: 0x00
Temperature: 47 Celsius
Available Spare: 100%
Available Spare Threshold: 26%
Percentage Used: 0%
Data Units Read: 76,623,421 [39.2 TB]
Data Units Written: 59,365,282 [30.3 TB]
Host Read Commands: 614,079,901
Host Write Commands: 549,353,795
Controller Busy Time: 544
Power Cycles: 59
Power On Hours: 3,526
Unsafe Shutdowns: 24
Media and Data Integrity Errors: 25
Error Information Log Entries: 214,053
Warning Comp. Temperature Time: 0
Critical Comp. Temperature Time: 0
Temperature Sensor 1: 109 Celsius
Temperature Sensor 2: 101 Celsius
Error Information (NVMe Log 0x01, 16 of 256 entries)
Num ErrCount? SQId CmdId? Status PELoc LBA NSID VS
0 214053 0 0xc00a 0xc004 0x02e - 0 -
1 214052 0 0x7019 0xc004 0x02e - 0 -
2 214051 0 0xc008 0xc004 0x02e - 0 -
3 214050 0 0xb00b 0xc004 0x02e - 0 -
4 214049 0 0x601b 0xc004 0x02e - 0 -
5 214048 0 0x601a 0xc004 0x02e - 0 -
6 214047 0 0x6018 0xc004 0x02e - 0 -
7 214046 0 0x501b 0xc004 0x02e - 0 -
8 214045 0 0x700c 0xc004 0x02e - 0 -
9 214044 0 0x600f 0xc004 0x02e - 0 -
10 214043 0 0x600d 0xc004 0x02e - 0 -
11 214042 0 0x600c 0xc004 0x02e - 0 -
12 214041 0 0x3013 0xc004 0x02e - 0 -
13 214040 0 0x3012 0xc004 0x02e - 0 -
14 214039 0 0x3010 0xc004 0x02e - 0 -
15 214038 0 0x2013 0xc004 0x02e - 0 -
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.10.142+truenas] (local build)
smartctl comes with ABSOLUTELY NO WARRANTY. This is free
software, and you are welcome to redistribute it under
the terms of the GNU General Public License; either
version 2, or (at your option) any later version.
See http://www.gnu.org for further details.
smartmontools release 7.2 dated 2020-12-30 at 16:48:30 UTC
smartmontools SVN rev 5155 dated 2020-12-30 at 16:49:18
smartmontools build host: x86_64-pc-linux-gnu
smartmontools build with: C++14, GCC 10.2.1 20210110
smartmontools configure arguments: '--includedir=${prefix}/include' '--mandir=${prefix}/share/man' '--infodir=${prefix}/share/info' '--localstatedir=/var' '--disable-option-checking' '--disable-silent-rules' '--libdir=${prefix}/lib/x86_64-linux-gnu' '--runstatedir=/run' '--disable-maintainer-mode' '--disable-dependency-tracking' '--build=x86_64-linux-gnu' '--host=x86_64-linux-gnu' '--prefix=/usr' '--sysconfdir=/etc' '--mandir=/usr/share/man' '--with-initscriptdir=no' '--docdir=/usr/share/doc/smartmontools' '--with-attributelog=/var/lib/smartmontools/attrlog.' '--with-drivedbdir=/var/lib/smartmontools/drivedb' '--with-exampledir=/usr/share/doc/smartmontools/examples/' '--with-savestates=/var/lib/smartmontools/smartd.' '--with-smartdplugindir=/etc/smartmontools/smartd_warning.d' '--with-smartdscriptdir=/usr/share/smartmontools' '--with-systemdenvfile=/etc/default/smartmontools' '--with-systemdsystemunitdir=/lib/systemd/system' '--with-libsystemd=auto' '--with-selinux' 'build_alias=x86_64-linux-gnu' 'host_alias=x86_64-linux-gnu' 'CXXFLAGS=-g -O2 -ffile-prefix-map=/dpkg-src=. -fstack-protector-strong -Wformat -Werror=format-security -fsigned-char -Wall' 'LDFLAGS=-Wl,-z,relro -Wl,-z,now' 'CPPFLAGS=-Wdate-time -D_FORTIFY_SOURCE=2' 'CFLAGS=-g -O2 -ffile-prefix-map=/dpkg-src=. -fstack-protector-strong -Wformat -Werror=format-security -fsigned-char -Wall'
.................Entry[63]
error_count : 214030
sqid : 0
cmdid : 0x7003
status_field : 0xc004(INVALID_FIELD: A reserved coded value or an unsupported value in a defined field)
parm_err_loc : 0x2e
lba : 0xffffffffffffffff
nsid : 0
vs : 0
trtype : The transport type is not indicated or the error is not transport related.
cs : 0xffffffffffffffff
trtype_spec_info: 0
