I am using TrueNAS-12.0-U8.1 core running on a HP microserver gen6or7 (n36l) with 16GB of RAM and four HGST HDN726060. I am trying to sort out arranging my disks to spin down when not in use. There are a number of issues the first of which is with smartctl itself. As can be seen the disk is a HGST Deskstar.
I have been playing with the following three commands
smartctl -i /dev/ada0 -n standby
smartctl -i /dev/ada0 -d sat -n standby
smartctl -i /dev/ada0 -d sat,auto -n standby
With the disk spinning I get the following.
With the disk spun down I get the following.
With the disk spinning why do I get the contradictory status reports, and why does "-d sat,auto" fail.
Thanks in advance
smartctl -i /dev/ada0 -n standby smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p14 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: HGST Deskstar NAS Device Model: HGST HDN726060ALE614 Serial Number: K1HJDTAB LU WWN Device Id: 5 000cca 255d58d6f Firmware Version: APGNW7JH User Capacity: 6,001,175,126,016 bytes [6.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 7200 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s) Local Time is: Fri May 27 09:35:36 2022 BST SMART support is: Available - device has SMART capability. SMART support is: Enabled Power mode is: ACTIVE or IDLE smartctl -i /dev/ada0 -d sat -n standby smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p14 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.or Device is in SLEEP mode, exit(2) smartctl -i /dev/ada0 -d sat,auto -n standby smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p14 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org Smartctl open device: /dev/ada0 [SCSI/SAT] failed: INQUIRY [SAT]: Input/output error
smartctl -i /dev/ada0 -n standby smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p14 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org Device is in STANDBY mode, exit(2) smartctl -i /dev/ada0 -d sat -n standby smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p14 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org Device is in SLEEP mode, exit(2) smartctl -i /dev/ada0 -d sat,auto -n standby smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p14 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org Smartctl open device: /dev/ada0 [SCSI/SAT] failed: INQUIRY [SAT]: Input/output error
Thanks in advance
