rmccullough
 - May 17, 2018
I received an alert yesterday that the S.M.A.R.T. tests failed to run on my boot device (
I tried running
I don't seeing this issue before, is this an indication that my mSATA drive is going bad?
			/dev/ada0).Code:
root@freenas[~]# smartctl -t short /dev/ada0 smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p9 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF OFFLINE IMMEDIATE AND SELF-TEST SECTION === Self-test functions not supported Can't start self-test without aborting current test (150% remaining), add '-t force' option to override, or run 'smartctl -X' to abort test.
I tried running
smartctl -X /dev/ada0, but it didn't seem to make a difference.I don't seeing this issue before, is this an indication that my mSATA drive is going bad?
