Problem: Cannot see Files on Webdav on IP webpage
zak1687
Hi, I need help I have port forwarded webdav correctly but everytime I access (example ip:) https://113.525.353.252:8282/ I can enter all the username and pass but it comes up with Not Found Error 404 The requested URL was not found on this server.
Specs: CPU: Intel(R) Celeron(R) CPU J1900 @ 1.99GHz
RAM: 8GB DDR3
MOBO: SuperMicro X10SBA
Storage: 2x3TB (WD RED) raid mirror
os version: Truenas-13.0-U3.1 (Core)
Davvo
I don't know what is going on, but do note that CORE's minimum RAM is 16GB.
I suggest you to give more infos. Are you using a plugin? A jail? A VM?
The more you explain the more someone can help you.
zak1687
Hi, I'm not using any plugins/jails. I setup webdav so I can use it as a mapped drive for windows and so I can access it outside of Local Area Network. I have configured webdav with port 8282 and it works fine except I cannot access any of the files or folder, I have setup the share correctly with its correct permissions. I keep getting this error. (attached below) Not sure what to do.
Thanks
Zak.
RAM: 8GB DDR3
