after a lot of pain I have managed to get Feenas working on the SS4200. my problem is it cannot find the network card and have no network.
my Setup:
Freenas x64 8.3 installed on usb flash
Intel SS4200 headless with RS-232 serial connection.
below is the screen capture - free nas is booting but not finding/using the right NIC?
I would very much appreciate the help because I have been trying to install freenas on the SS4200 since last august - have been soldering cables, finding all the how-tos and now I do not have experience on linux/unix how to address this driver? problem. same has been reported on hardware by another member.
below the screen capture
ΪΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΏ
³ ³
³ ³ ______
³ ³ | ____| __ ___ ___
³ Welcome to FreeNAS! ³ | |__ | '__/ _ \/ _ \
³ ³ | __|| | | __/ __/
³ ³ | | | | | | |
³ 1. Boot FreeNAS [default] ³ |_| |_| \___|\___|
³ 2. Boot FreeNAS with ACPI disabled ³ _ _ __ _____
³ 3. Boot FreeNAS in Safe Mode ³ | \ | | / \ / ____|
³ 4. Boot FreeNAS in single user mode ³ | \ | |/ /\ \| (__
³ 5. Boot FreeNAS with verbose logging ³ | |\\ | | |__| |\___ \
³ 6. Escape to loader prompt ³ | | \\| | __ |____) |
³ 7. Reboot ³ | | \ | | | | |
³ ³ |_| \_|_| |_|_____/
³ ³
³ ³ The free network attached storage
³ ³
³ Select option, [Enter] for default ³
³ or [Space] to pause timer 0 ³
ΐΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΔΩ
KDB: debugger backends: ddb
KDB: current backend: ddb
Copyright (c) 1992-2012 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 8.3-RELEASE-p4 #0 r241984M: Wed Oct 24 00:57:10 PDT 2012
root@build.ixsystems.com:/usr/home/jpaetzel/8.3.0-RELEASE/os-base/amd64/usr/home/jpaetzel/8.3.0-RELEASE/FreeBSD/src/sys/FREENAS.amd64 amd64
Timecounter "i8254" frequency 1193182 Hz quality 0
CPU: Intel(R) Celeron(R) CPU 420 @ 1.60GHz (1600.01-MHz K8-class CPU)
Origin = "GenuineIntel" Id = 0x10661 Family = 6 Model = 16 Stepping = 1
Features=0xafebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,TM,PBE>
Features2=0xe31d<SSE3,DTES64,MON,DS_CPL,TM2,SSSE3,CX16,xTPR,PDCM>
AMD Features=0x20100800<SYSCALL,NX,LM>
AMD Features2=0x1<LAHF>
TSC: P-state invariant
real memory = 1073741824 (1024 MB)
avail memory = 1007759360 (961 MB)
ACPI APIC Table: <121907 APIC1340>
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ioapic0 <Version 2.0> irqs 0-23 on motherboard
kbd1 at kbdmux0
hpt27xx: RocketRAID 27xx controller driver v1.0 (Oct 24 2012 00:56:59)
cryptosoft0: <software crypto> on motherboard
aesni0: No AESNI support.
acpi0: <121907 XSDT1340> on motherboard
acpi0: [ITHREAD]
acpi0: Power Button (fixed)
acpi0: reservation of 0, a0000 (3) failed
acpi0: reservation of 100000, 3f700000 (3) failed
Timecounter "ACPI-fast" frequency 3579545 Hz quality 1000
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x808-0x80b on acpi0
cpu0: <ACPI CPU> on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
vgapci0: <VGA-compatible display> port 0xec00-0xec07 mem 0xffa80000-0xffafffff,0xe0000000-0xefffffff,0xffa40000-0xffa7ffff irq 16 at device 2.0 on pci0
agp0: <Intel 82945G (945G GMCH) SVGA controller> on vgapci0
agp0: aperture size is 256M, detected 7932k stolen memory
pcib1: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0
pci1: <ACPI PCI bus> on pcib1
em0: <Intel(R) PRO/1000 Network Connection 7.3.2> port 0xbc00-0xbc1f mem 0xff6e0000-0xff6fffff irq 16 at device 0.0 on pci1
em0: Using an MSI interrupt
em0: [FILTER]
em0: Ethernet address: 00:15:17:31:ec:03
pcib2: <ACPI PCI-PCI bridge> irq 18 at device 28.2 on pci0
pci2: <ACPI PCI bus> on pcib2
siis0: <SiI3132 SATA controller> port 0xcc00-0xcc7f mem 0xff8ffc00-0xff8ffc7f,0xff8f8000-0xff8fbfff irq 18 at device 0.0 on pci2
siis0: [ITHREAD]
siisch0: <SIIS channel> at channel 0 on siis0
siisch0: [ITHREAD]
siisch1: <SIIS channel> at channel 1 on siis0
siisch1: [ITHREAD]
uhci0: <Intel 82801G (ICH7) USB controller USB-A> port 0xe880-0xe89f irq 23 at device 29.0 on pci0
uhci0: [ITHREAD]
usbus0: <Intel 82801G (ICH7) USB controller USB-A> on uhci0
uhci1: <Intel 82801G (ICH7) USB controller USB-B> port 0xe800-0xe81f irq 19 at device 29.1 on pci0
uhci1: [ITHREAD]
usbus1: <Intel 82801G (ICH7) USB controller USB-B> on uhci1
uhci2: <Intel 82801G (ICH7) USB controller USB-C> port 0xe480-0xe49f irq 18 at device 29.2 on pci0
uhci2: [ITHREAD]
usbus2: <Intel 82801G (ICH7) USB controller USB-C> on uhci2
uhci3: <Intel 82801G (ICH7) USB controller USB-D> port 0xe400-0xe41f irq 16 at device 29.3 on pci0
uhci3: [ITHREAD]
usbus3: <Intel 82801G (ICH7) USB controller USB-D> on uhci3
ehci0: <Intel 82801GB/R (ICH7) USB 2.0 controller> mem 0xffa3f800-0xffa3fbff irq 23 at device 29.7 on pci0
ehci0: [ITHREAD]
usbus4: EHCI version 1.0
usbus4: <Intel 82801GB/R (ICH7) USB 2.0 controller> on ehci0
pcib3: <ACPI PCI-PCI bridge> at device 30.0 on pci0
pci3: <ACPI PCI bus> on pcib3
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
ahci0: <Intel ICH7 AHCI SATA controller> port 0xe080-0xe087,0xe000-0xe003,0xdc00-0xdc07,0xd880-0xd883,0xd800-0xd80f mem 0xffa3fc00-0xffa3ffff irq 19 at device 31.2 on pci0
ahci0: [ITHREAD]
ahci0: AHCI v1.10 with 4 3Gbps ports, Port Multiplier not supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich0: [ITHREAD]
ahcich1: <AHCI channel> at channel 1 on ahci0
ahcich1: [ITHREAD]
ahcich2: <AHCI channel> at channel 2 on ahci0
ahcich2: [ITHREAD]
ahcich3: <AHCI channel> at channel 3 on ahci0
ahcich3: [ITHREAD]
pci0: <serial bus, SMBus> at device 31.3 (no driver attached)
acpi_button0: <Power Button> on acpi0
atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
uart0: [FILTER]
uart0: console (9600,n,8,1)
orm0: <ISA Option ROM> at iomem 0xcb000-0xcf7ff on isa0
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
atkbd0: [ITHREAD]
ppc0: cannot reserve I/O port range
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
coretemp0: Tj(target) value 0 does not seem right.
p4tcc0: <CPU Frequency Thermal Control> on cpu0
fuse4bsd: version 0.3.9-pre1, FUSE ABI 7.8
Timecounter "TSC" frequency 1600006752 Hz quality 800
Timecounters tick every 1.000 msec
hpt27xx: no controller detected.
usbus0: 12Mbps Full Speed USB v1.0
usbus1: 12Mbps Full Speed USB v1.0
usbus2: 12Mbps Full Speed USB v1.0
usbus3: 12Mbps Full Speed USB v1.0
usbus4: 480Mbps High Speed USB v2.0
ugen0.1: <Intel> at usbus0
uhub0: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
ugen1.1: <Intel> at usbus1
uhub1: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus1
ugen2.1: <Intel> at usbus2
uhub2: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2
ugen3.1: <Intel> at usbus3
uhub3: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus3
ugen4.1: <Intel> at usbus4
uhub4: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus4
uhub0: 2 ports with 2 removable, self powered
uhub1: 2 ports with 2 removable, self powered
uhub2: 2 ports with 2 removable, self powered
uhub3: 2 ports with 2 removable, self powered
uhub4: 8 ports with 8 removable, self powered
ugen4.2: <MWR> at usbus4
umass0: <MWR Memorette Swing, class 0/0, rev 2.00/2.00, addr 2> on usbus4
ada0 at ahcich0 bus 0 scbus2 target 0 lun 0
ada0: <ST3500320AS SD1A> ATA-8 SATA 1.x device
ada0: 150.000MB/s transfers (SATA 1.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 476940MB (976773168 512 byte sectors: 16H 63S/T 16383C)
ada1 at ahcich1 bus 0 scbus3 target 0 lun 0
ada1: <ST3500320AS SD1A> ATA-8 SATA 1.x device
ada1: 150.000MB/s transfers (SATA 1.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 476940MB (976773168 512 byte sectors: 16H 63S/T 16383C)
ada2 at ahcich2 bus 0 scbus4 target 0 lun 0
ada2: <ST3500320AS SD1A> ATA-8 SATA 1.x device
ada2: 150.000MB/s transfers (SATA 1.x, UDMA6, PIO 8192bytes)
ada2: Command Queueing enabled
ada2: 476940MB (976773168 512 byte sectors: 16H 63S/T 16383C)
ada3 at ahcich3 bus 0 scbus5 target 0 lun 0
ada3: <ST3500320AS SD1A> ATA-8 SATA 1.x device
ada3: 150.000MB/s transfers (SATA 1.x, UDMA6, PIO 8192bytes)
ada3: Command Queueing enabled
ada3: 476940MB (976773168 512 byte sectors: 16H 63S/T 16383C)
da0 at umass-sim0 bus 0 scbus6 target 0 lun 0
da0: <MWR Memorette Swing 1.00> Removable Direct Access SCSI-2 device
da0: 40.000MB/s transfers
da0: 3938MB (8065024 512 byte sectors: 255H 63S/T 502C)
GEOM: da0s1: geometry does not match label (16h,63s != 255h,63s).
Trying to mount root from ufs:/dev/ufs/FreeNASs1a
WARNING: /data was not properly dismounted
Setting hostuuid: 00020003-0004-0005-0006-00151731ec03.
Setting hostid: 0x98074a42.
/dev/ufs/FreeNASs4: SUMMARY INFORMATION BAD (SALVAGED)
/dev/ufs/FreeNASs4: BLK(S) MISSING IN BIT MAPS (SALVAGED)
/dev/ufs/FreeNASs4: 9 files, 1145 used, 39382 free (30 frags, 4919 blocks, 0.1% fragmentation)
No suitable dump device was found.
Entropy harvesting: kickstart.
Starting file system checks:
/dev/ufs/FreeNASs1a: FILE SYSTEM CLEAN; SKIPPING CHECKS
/dev/ufs/FreeNASs1a: clean, 1122069 free (1173 frags, 140112 blocks, 0.1% fragmentation)
/dev/ufs/FreeNASs4: FILE SYSTEM CLEAN; SKIPPING CHECKS
/dev/ufs/FreeNASs4: clean, 39382 free (30 frags, 4919 blocks, 0.1% fragmentation)
/dev/ufs/FreeNASs3: FILE SYSTEM CLEAN; SKIPPING CHECKS
/dev/ufs/FreeNASs3: clean, 2829 free (21 frags, 351 blocks, 0.7% fragmentation)
Mounting local file systems:.
Setting hostname: freenas.local.
Starting Network: lo0.
options=3<RXCSUM,TXCSUM>
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x7
inet6 ::1 perefixlen 128
minet 127.0.0.1 n0etmask 0xff00000:0
nd6 options =3<PERFORMNUD,AClCEPT_RTADV>
addi net ::ffff:0.0.n0.0: gateway ::1k
add net ::0.0. 0.0: gateway ::1s
Starting devd.t
ate changed to UP
Generating host.conf.
ELF ldconfig path: /lib /usr/lib /usr/local/lib
32-bit compatibility ldconfig path:
Creating and/or trimming log files.
Starting syslogd.
/etc/rc: WARNING: Dump device does not exist. Savecore not run.
/etc/rc: WARNING: failed precmd routine for vmware_guestd
Updating motd:.
Starting ntpd.
16+0 records in
16+0 records out
16 bytes transferred in 0.000488 secs (32784 bytes/sec)
Generating a 1024 bit RSA private key
writing new private key to '/etc/ssl/freenas/CA/private/cakey.key'
writing RSA key
Starting proftpd.
Starting smartd.
Nov 14 07:14:03 freenas ntpd_initres[1920]: host name not found: 0.freebsd.pool.ntp.org
Nov 14 07:14:03 freenas ntpd_initres[1920]: couldn't resolve `0.freebsd.pool.ntp.org', giving up on it
Nov 14 07:14:03 freenas ntpd_initres[1920]: host name not found: 1.freebsd.pool.ntp.org
Nov 14 07:14:03 freenas ntpd_initres[1920]: couldn't resolve `1.freebsd.pool.ntp.org', giving up on it
Nov 14 07:14:03 freenas ntpd_initres[1920]: host name not found: 2.freebsd.pool.ntp.org
Nov 14 07:14:03 freenas ntpd_initres[1920]: couldn't resolve `2.freebsd.pool.ntp.org', giving up on it
Starting django.
Waiting for http... Failed.
Performing sanity check on nginx configuration:
nginx: the configuration file /usr/local/etc/nginx/nginx.conf syntax is ok
nginx: configuration file /usr/local/etc/nginx/nginx.conf test is successful
Starting nginx.
ZFS NOTICE: Prefetch is disabled by default if less than 4GB of RAM is present;
to enable, add "vfs.zfs.prefetch_disable=0" to /boot/loader.conf.
ZFS filesystem version 5
ZFS storage pool version 28
Starting collectd.
Starting bsdstats.
Posting monthly OS statistics disabled
set monthly_statistics_enable="YES" in /etc/periodic.conf
Configuring syscons: blanktime.
Starting sshd.
Starting cron.
Starting rpcbind.
Starting mountd.
I have since found that the network card onboard is the " The Intel® Entry Storage System SS4200-E uses the 82573E Gigabit Ethernet Network controller. "
is it an issue of not having the proper network driver? I am testing the same installation on a desktop pc with a different type NIC and it seems to have no problem to find the network card- get IP etc.
I can also see that its finding the NIC so why its not used as the primary NIC? IP address is already configured to a static IP without DHCP.
em0: [FILTER]
my Setup:
³ ³
³ ³ ______
³ ³ | | | | | | |
³ ³
³ ³
kbd1 at kbdmux0
acpi0: [ITHREAD]
em0: [FILTER]
siis0: [ITHREAD]
siisch0: [ITHREAD]
siisch1: [ITHREAD]
uhci0: [ITHREAD]
uhci1: [ITHREAD]
uhci2: [ITHREAD]
uhci3: [ITHREAD]
ehci0: [ITHREAD]
ahci0: [ITHREAD]
ahcich0: [ITHREAD]
ahcich1: [ITHREAD]
ahcich2: [ITHREAD]
ahcich3: [ITHREAD]
uart0: [FILTER]
kbd0 at atkbd0
atkbd0: [ITHREAD]
Starting devd.t
ate changed to UP
Starting syslogd.
Updating motd:.
Starting ntpd.
16+0 records in
16+0 records out
writing RSA key
Starting proftpd.
Starting smartd.
Starting django.
Starting nginx.
Starting collectd.
Starting bsdstats.
Starting sshd.
Starting cron.
Starting rpcbind.
Starting mountd.
em0: [FILTER]
