SOLVED Issue with 9.10 and SanDisk Cruzer Fit Drives
zoomzoom
Link to Bug Report (filed 3/24)
Please read the bug report for details about the issue prior to commenting
dmesg
  • Code:
    FreeBSD 10.3-RC3 #0 86b9b91(freebsd10): Mon Mar 21 17:43:20 PDT 2016
        root@build.ixsystems.com:/tank/home/nightlies/build-freenas9/_BE/objs/tank/home/nightlies/build-freenas9/_BE/trueos/sys/FreeNAS.amd64 amd64
    FreeBSD clang version 3.4.1 (tags/RELEASE_34/dot1-final 208032) 20140512
    KLD file linux.ko is missing dependencies
    module_register: cannot register pci/xhci from kernel; already loaded from xhci.ko
    Module pci/xhci failed to register: 17
    CPU: Intel(R) Atom(TM) CPU  C2750  @ 2.40GHz (2400.06-MHz K8-class CPU)
      Origin="GenuineIntel"  Id=0x406d8  Family=0x6  Model=0x4d  Stepping=8
      Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
      Features2=0x43d8e3bf<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,SSE4.1,SSE4.2,MOVBE,POPCNT,TSCDLT,AESNI,RDRAND>
      AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM>
      AMD Features2=0x101<LAHF,Prefetch>
      Structured Extended Features=0x2282<TSCADJ,SMEP,ERMS,NFPUSG>
      VT-x: PAT,HLT,MTF,PAUSE,EPT,UG,VPID
      TSC: P-state invariant, performance statistics
    real memory  = 36507222016 (34816 MB)
    avail memory = 33227407360 (31688 MB)
    Event timer "LAPIC" quality 600
    ACPI APIC Table: <INTEL  TIANO   >
    FreeBSD/SMP: Multiprocessor System Detected: 8 CPUs
    FreeBSD/SMP: 1 package(s) x 8 core(s)
    cpu0 (BSP): APIC ID:  0
    cpu1 (AP): APIC ID:  2
    cpu2 (AP): APIC ID:  4
    cpu3 (AP): APIC ID:  6
    cpu4 (AP): APIC ID:  8
    cpu5 (AP): APIC ID: 10
    cpu6 (AP): APIC ID: 12
    cpu7 (AP): APIC ID: 14
    random: <Software, Yarrow> initialized
    WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
    ioapic0 <Version 2.0> irqs 0-23 on motherboard
    module_register_init: MOD_LOAD (vesa, 0xffffffff80dcd910, 0) error 19
    kbd1 at kbdmux0
    cryptosoft0: <software crypto> on motherboard
    aesni0: <AES-CBC,AES-XTS> on motherboard
    padlock0: No ACE support.
    acpi0: <ALASKA A M I > on motherboard
    acpi0: Power Button (fixed)
    cpu0: <ACPI CPU> on acpi0
    cpu1: <ACPI CPU> on acpi0
    cpu2: <ACPI CPU> on acpi0
    cpu3: <ACPI CPU> on acpi0
    cpu4: <ACPI CPU> on acpi0
    cpu5: <ACPI CPU> on acpi0
    cpu6: <ACPI CPU> on acpi0
    cpu7: <ACPI CPU> on acpi0
    hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
    Timecounter "HPET" frequency 14318180 Hz quality 950
    Event timer "HPET" frequency 14318180 Hz quality 350
    Event timer "HPET1" frequency 14318180 Hz quality 340
    Event timer "HPET2" frequency 14318180 Hz quality 340
    atrtc0: <AT realtime clock> port 0x70-0x77 irq 8 on acpi0
    atrtc0: Warning: Couldn't map I/O.
    Event timer "RTC" frequency 32768 Hz quality 0
    attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0
    Timecounter "i8254" frequency 1193182 Hz quality 0
    Event timer "i8254" frequency 1193182 Hz quality 100
    Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
    acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0
    pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
    pci0: <ACPI PCI bus> on pcib0
    pcib1: <ACPI PCI-PCI bridge> mem 0xffff40000-0xffff5ffff irq 16 at device 1.0 on pci0
    pci1: <ACPI PCI bus> on pcib1
    pcib2: <PCI-PCI bridge> mem 0xdfa00000-0xdfa1ffff irq 16 at device 0.0 on pci1
    pci2: <PCI bus> on pcib2
    pcib3: <PCI-PCI bridge> irq 17 at device 1.0 on pci2
    pci3: <PCI bus> on pcib3
    xhci0: <XHCI (generic) USB 3.0 controller> mem 0xdf900000-0xdf901fff irq 17 at device 0.0 on pci3
    xhci0: 64 bytes context size, 64-bit DMA
    usbus0 on xhci0
    pcib4: <PCI-PCI bridge> irq 17 at device 5.0 on pci2
    pci4: <PCI bus> on pcib4
    xhci1: <XHCI (generic) USB 3.0 controller> mem 0xdf800000-0xdf801fff irq 17 at device 0.0 on pci4
    xhci1: 64 bytes context size, 64-bit DMA
    usbus1 on xhci1
    pcib5: <PCI-PCI bridge> irq 19 at device 7.0 on pci2
    pci5: <PCI bus> on pcib5
    xhci2: <XHCI (generic) USB 3.0 controller> mem 0xdf700000-0xdf701fff irq 19 at device 0.0 on pci5
    xhci2: 64 bytes context size, 64-bit DMA
    usbus2 on xhci2
    pcib6: <PCI-PCI bridge> irq 17 at device 9.0 on pci2
    pci6: <PCI bus> on pcib6
    xhci3: <XHCI (generic) USB 3.0 controller> mem 0xdf600000-0xdf601fff irq 17 at device 0.0 on pci6
    xhci3: 64 bytes context size, 64-bit DMA
    usbus3 on xhci3
    pcib7: <ACPI PCI-PCI bridge> mem 0xffff20000-0xffff3ffff irq 20 at device 3.0 on pci0
    pci7: <ACPI PCI bus> on pcib7
    pcib8: <ACPI PCI-PCI bridge> mem 0xdf500000-0xdf51ffff irq 22 at device 0.0 on pci7
    pci8: <ACPI PCI bus> on pcib8
    pcib9: <PCI-PCI bridge> irq 23 at device 1.0 on pci8
    pci9: <PCI bus> on pcib9
    ahci0: <Marvell 88SE9172 AHCI SATA controller> port 0xc040-0xc047,0xc030-0xc033,0xc020-0xc027,0xc010-0xc013,0xc000-0xc00f mem 0xdf410000-0xdf4101ff irq 23 at device 0.0 on pci9
    ahci0: AHCI v1.00 with 2 6Gbps ports, Port Multiplier supported with FBS
    ahcich0: <AHCI channel> at channel 0 on ahci0
    ahcich1: <AHCI channel> at channel 1 on ahci0
    pcib10: <PCI-PCI bridge> irq 23 at device 5.0 on pci8
    pci10: <PCI bus> on pcib10
    pcib11: <PCI-PCI bridge> irq 23 at device 0.0 on pci10
    pci11: <PCI bus> on pcib11
    vgapci0: <VGA-compatible display> port 0xb000-0xb07f mem 0xde000000-0xdeffffff,0xdf000000-0xdf01ffff irq 23 at device 0.0 on pci11
    vgapci0: Boot video device
    pcib12: <PCI-PCI bridge> irq 21 at device 7.0 on pci8
    pci12: <PCI bus> on pcib12
    igb0: <Intel(R) PRO/1000 Network Connection, Version - 2.5.3-k> port 0xa000-0xa01f mem 0xdf300000-0xdf37ffff,0xdf380000-0xdf383fff irq 21 at device 0.0 on pci12
    igb0: Using MSIX interrupts with 5 vectors
    igb0: Ethernet address: d0:50:99:5a:f8:b6
    igb0: Bound queue 0 to cpu 0
    igb0: Bound queue 1 to cpu 1
    igb0: Bound queue 2 to cpu 2
    igb0: Bound queue 3 to cpu 3
    pcib13: <PCI-PCI bridge> irq 23 at device 9.0 on pci8
    pci13: <PCI bus> on pcib13
    igb1: <Intel(R) PRO/1000 Network Connection, Version - 2.5.3-k> port 0x9000-0x901f mem 0xdf200000-0xdf27ffff,0xdf280000-0xdf283fff irq 23 at device 0.0 on pci13
    igb1: Using MSIX interrupts with 5 vectors
    igb1: Ethernet address: d0:50:99:5a:f8:b7
    igb1: Bound queue 0 to cpu 4
    igb1: Bound queue 1 to cpu 5
    igb1: Bound queue 2 to cpu 6
    igb1: Bound queue 3 to cpu 7
    pcib14: <ACPI PCI-PCI bridge> mem 0xffff00000-0xffff1ffff at device 4.0 on pci0
    pci14: <ACPI PCI bus> on pcib14
    ahci1: <Marvell 88SE9230 AHCI SATA controller> port 0xd050-0xd057,0xd040-0xd043,0xd030-0xd037,0xd020-0xd023,0xd000-0xd01f mem 0xdfb10000-0xdfb107ff irq 23 at device 0.0 on pci14
    ahci1: AHCI v1.20 with 8 6Gbps ports, Port Multiplier not supported
    ahci1: quirks=0x900<NOBSYRES,ALTSIG>
    ahcich2: <AHCI channel> at channel 0 on ahci1
    ahcich3: <AHCI channel> at channel 1 on ahci1
    ahcich4: <AHCI channel> at channel 2 on ahci1
    ahcich5: <AHCI channel> at channel 3 on ahci1
    ahcich6: <AHCI channel> at channel 4 on ahci1
    ahcich7: <AHCI channel> at channel 5 on ahci1
    ahcich8: <AHCI channel> at channel 6 on ahci1
    ahcich9: <AHCI channel> at channel 7 on ahci1
    pci0: <base peripheral, IOMMU> at device 15.0 (no driver attached)
    ehci0: <Intel Avoton USB 2.0 controller> mem 0xdfc03000-0xdfc033ff irq 23 at device 22.0 on pci0
    usbus4: EHCI version 1.0
    usbus4 on ehci0
    ahci2: <Intel Avoton AHCI SATA controller> port 0xe0d0-0xe0d7,0xe0c0-0xe0c3,0xe0b0-0xe0b7,0xe0a0-0xe0a3,0xe040-0xe05f mem 0xdfc02000-0xdfc027ff irq 19 at device 23.0 on pci0
    ahci2: AHCI v1.30 with 4 3Gbps ports, Port Multiplier not supported
    ahcich10: <AHCI channel> at channel 0 on ahci2
    ahcich11: <AHCI channel> at channel 1 on ahci2
    ahcich12: <AHCI channel> at channel 2 on ahci2
    ahcich13: <AHCI channel> at channel 3 on ahci2
    ahci3: <Intel Avoton AHCI SATA controller> port 0xe090-0xe097,0xe080-0xe083,0xe070-0xe077,0xe060-0xe063,0xe020-0xe03f mem 0xdfc01000-0xdfc017ff irq 19 at device 24.0 on pci0
    ahci3: AHCI v1.30 with 2 6Gbps ports, Port Multiplier not supported
    ahcich14: <AHCI channel> at channel 0 on ahci3
    ahcich15: <AHCI channel> at channel 1 on ahci3
    isab0: <PCI-ISA bridge> at device 31.0 on pci0
    isa0: <ISA bus> on isab0
    uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
    uart2: <16550 or compatible> port 0x248-0x24f irq 3 on acpi0
    wbwd0: <Nuvoton WPCM450RA0BX> at port 0x2e-0x2f on isa0
    orm0: <ISA Option ROM> at iomem 0xc0000-0xc7fff on isa0
    sc0: <System console> at flags 0x100 on isa0
    sc0: CGA <16 virtual consoles, flags=0x300>
    vga0: <Generic ISA VGA> at port 0x3d0-0x3db iomem 0xb8000-0xbffff on isa0
    atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
    atkbd0: <AT Keyboard> irq 1 on atkbdc0
    kbd0 at atkbd0
    atkbd0: [GIANT-LOCKED]
    fdc0: <Enhanced floppy controller> at port 0x3f0-0x3f5,0x3f7 irq 6 drq 2 on isa0
    coretemp0: <CPU On-Die Thermal Sensors> on cpu0
    est0: <Enhanced SpeedStep Frequency Control> on cpu0
    coretemp1: <CPU On-Die Thermal Sensors> on cpu1
    est1: <Enhanced SpeedStep Frequency Control> on cpu1
    coretemp2: <CPU On-Die Thermal Sensors> on cpu2
    est2: <Enhanced SpeedStep Frequency Control> on cpu2
    coretemp3: <CPU On-Die Thermal Sensors> on cpu3
    est3: <Enhanced SpeedStep Frequency Control> on cpu3
    coretemp4: <CPU On-Die Thermal Sensors> on cpu4
    est4: <Enhanced SpeedStep Frequency Control> on cpu4
    coretemp5: <CPU On-Die Thermal Sensors> on cpu5
    est5: <Enhanced SpeedStep Frequency Control> on cpu5
    coretemp6: <CPU On-Die Thermal Sensors> on cpu6
    est6: <Enhanced SpeedStep Frequency Control> on cpu6
    coretemp7: <CPU On-Die Thermal Sensors> on cpu7
    est7: <Enhanced SpeedStep Frequency Control> on cpu7
    random: unblocking device.
    usbus0: 5.0Gbps Super Speed USB v3.0
    ZFS filesystem version: 5
    ZFS storage pool version: features support (5000)
    Timecounters tick every 1.000 msec
    ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
    usbus1: 5.0Gbps Super Speed USB v3.0
    usbus2: 5.0Gbps Super Speed USB v3.0
    usbus3: 5.0Gbps Super Speed USB v3.0
    usbus4: 480Mbps High Speed USB v2.0
    ugen0.1: <0x1912> at usbus0
    uhub0: <0x1912 XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
    ugen2.1: <0x1912> at usbus2
    uhub1: <0x1912 XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus2
    ugen1.1: <0x1912> at usbus1
    uhub2: <0x1912 XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus1
    ugen3.1: <0x1912> at usbus3
    uhub3: <0x1912 XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus3
    ugen4.1: <Intel> at usbus4
    uhub4: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus4
    uhub0: 3 ports with 3 removable, self powered
    uhub1: 3 ports with 3 removable, self powered
    uhub2: 3 ports with 3 removable, self powered
    uhub3: 3 ports with 3 removable, self powered
    ahcich10: Poll timeout on slot 2 port 0
    ahcich10: is 08000000 cs 00000004 ss 00000000 rs 00000004 tfd 150 serr 00800000 cmd 00044117
    usb_alloc_device: set address 2 failed (USB_ERR_IOERROR, ignored)
    (aprobe10:ahcich10:0:0:0): NOP. ACB: 00 00 00 00 00 00 00 00 00 00 00 00
    (aprobe10:ahcich10:0:0:0): CAM status: Command timeout
    (aprobe10:ahcich10:0:0:0): Error 5, Retries exhausted
    ahcich10: Poll timeout on slot 4 port 0
    ahcich10: is 08000000 cs 00000010 ss 00000000 rs 00000010 tfd 150 serr 00800000 cmd 00044317
    ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
    ada0: <ST4000VN000-1H4168 SC46> ACS-2 ATA SATA 3.x device
    ada0: Serial Number
    ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
    ada0: Command Queueing enabled
    ada0: 3815447MB (7814037168 512 byte sectors)
    ada0: Previously was known as ad4
    ada1 at ahcich1 bus 0 scbus1 target 0 lun 0
    ada1: <ST4000VN000-1H4168 SC46> ACS-2 ATA SATA 3.x device
    ada1: Serial Number
    ada1: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
    ada1: Command Queueing enabled
    ada1: 3815447MB (7814037168 512 byte sectors)
    ada1: Previously was known as ad6
    ada2 at ahcich2 bus 0 scbus2 target 0 lun 0
    ada2: <ST4000VN000-1H4168 SC46> ACS-2 ATA SATA 3.x device
    ada2: Serial Number
    ada2: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
    ada2: Command Queueing enabled
    ada2: 3815447MB (7814037168 512 byte sectors)
    ada2: Previously was known as ad8
    ada3 at ahcich3 bus 0 scbus3 target 0 lun 0
    ada3: <ST4000VN000-1H4168 SC46> ACS-2 ATA SATA 3.x device
    ada3: Serial Number
    ada3: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
    ada3: Command Queueing enabled
    ada3: 3815447MB (7814037168 512 byte sectors)
    ada3: Previously was known as ad10
    ada4 at ahcich4 bus 0 scbus4 target 0 lun 0
    ada4: <ST4000VN000-1H4168 SC46> ACS-2 ATA SATA 3.x device
    ada4: Serial Number
    ada4: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
    ada4: Command Queueing enabled
    ada4: 3815447MB (7814037168 512 byte sectors)
    ada4: Previously was known as ad12
    ada5 at ahcich5 bus 0 scbus5 target 0 lun 0
    ada5: <ST4000VN000-1H4168 SC46> ACS-2 ATA SATA 3.x device
    ada5: Serial Number
    ada5: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
    ada5: Command Queueing enabled
    ada5: 3815447MB (7814037168 512 byte sectors)
    ada5: Previously was known as ad14
    ada6 at ahcich11 bus 0 scbus11 target 0 lun 0
    ada6: <Samsung SSD 850 EVO 120GB EMT01B6Q> ACS-2 ATA SATA 3.x device
    ada6: Serial Number
    ada6: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 512bytes)
    ada6: Command Queueing enabled
    ada6: 114473MB (234441648 512 byte sectors)
    ada6: quirks=0x1<4K>
    ada6: Previously was known as ad26
    ada7 at ahcich12 bus 0 scbus12 target 0 lun 0
    ada7: <ST750LX003-1AC154 SM12> ATA8-ACS SATA 3.x device
    ada7: Serial Number
    ada7: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
    ada7: Command Queueing enabled
    ada7: 715404MB (1465149168 512 byte sectors)
    ada7: Previously was known as ad28
    ada8 at ahcich14 bus 0 scbus14 target 0 lun 0
    ada8: <ST4000VN000-1H4168 SC46> ACS-2 ATA SATA 3.x device
    ada8: Serial Number
    ada8: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
    ada8: Command Queueing enabled
    ada8: 3815447MB (7814037168 512 byte sectors)
    ada8: Previously was known as ad32
    ada9 at ahcich15 bus 0 scbus15 target 0 lun 0
    ada9: <ST4000VN000-1H4168 SC46> ACS-2 ATA SATA 3.x device
    ada9: Serial Number
    ada9: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
    ada9: Command Queueing enabled
    ada9: 3815447MB (7814037168 512 byte sectors)
    ada9: Previously was known as ad34
    pass6 at ahcich9 bus 0 scbus9 target 0 lun 0
    pass6: <Marvell Console 1.01> Removable Processor SCSI device
    pass6: Serial Number
    pass6: 150.000MB/s transfers (SATA 1.x, UDMA4, ATAPI 12bytes, PIO 8192bytes)
    SMP: AP CPU #1 Launched!
    SMP: AP CPU #4 Launched!
    SMP: AP CPU #6 Launched!
    SMP: AP CPU #3 Launched!
    SMP: AP CPU #7 Launched!
    SMP: AP CPU #2 Launched!
    SMP: AP CPU #5 Launched!
    Timecounter "TSC-low" frequency 1200028992 Hz quality 1000
    usbd_setup_device_desc: getting device descriptor at addr 2 failed, USB_ERR_IOERROR
    usbd_req_re_enumerate: addr=2, set address failed! (USB_ERR_IOERROR, ignored)
    Root mount waiting for: usbus4 usbus3
    uhub4: 8 ports with 8 removable, self powered
    ugen4.2: <vendor 0x8087> at usbus4
    uhub5: <vendor 0x8087 product 0x07db, class 9/0, rev 2.00/0.02, addr 2> on usbus4
    uhub5: 4 ports with 4 removable, self powered
    ugen4.3: <CPS> at usbus4
    ugen4.4: <American Megatrends Inc.> at usbus4
    uhub6: <7-port Hub> on usbus4
    uhub6: 5 ports with 5 removable, self powered
    ugen4.5: <American Megatrends Inc.> at usbus4
    ukbd0: <Keyboard Interface> on usbus4
    kbd2 at ukbd0
    Root mount waiting for: usbus3
    ugen3.2: <Unknown> at usbus3 (disconnected)
    uhub_reattach_port: could not allocate new device
    Trying to mount root from zfs:freenas-boot/ROOT/default []...
    GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7)
    igb0: link state changed to UP
    igb1: link state changed to UP
    ipmi0: <IPMI System Interface> port 0xca2,0xca3 on acpi0
    ipmi0: KCS mode found at io 0xca2 on acpi
    ipmi0: IPMI device rev. 1, firmware rev. 0.23, version 2.0
    ipmi0: Number of channels 2
    ipmi0: Attached watchdog
    hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI> TSC/1/64/0x20<REA> IAP/2/40/0x3ff<INT,USR,SYS,EDG,THR,REA,WRI,INV,QUA,PRC> IAF/3/40/0x67<INT,USR,SYS,REA,WRI>
    igb0: link state changed to DOWN
    igb1: link state changed to DOWN
    vboxdrv: fAsync=0 offMin=0x588 offMax=0x12f0
    GEOM_ELI: Device ada3p1.eli created.
    GEOM_ELI: Encryption: AES-XTS 128
    GEOM_ELI:     Crypto: hardware
    GEOM_ELI: Device ada0p1.eli created.
    GEOM_ELI: Device ada2p1.eli created.
    GEOM_ELI: Device ada4p1.eli created.
    GEOM_ELI: Device ada9p1.eli created.
    GEOM_ELI: Device ada5p1.eli created.
    GEOM_ELI: Device ada1p1.eli created.
    GEOM_ELI: Device ada8p1.eli created.
    nfsd: can't register svc name
    ipmi0: detached
    pid 1637 (syslog-ng), uid 0: exited on signal 6 (core dumped)
pciconf -lv
  • Code:
    hostb0@pci0:0:0:0:      class=0x060000 card=0x00000000 chip=0x1f018086 rev=0x02 hdr=0x00
        vendor     = 'Intel Corporation'
        device     = 'Atom processor C2000 SoC Transaction Router'
        class      = bridge
        subclass   = HOST-PCI
    pcib1@pci0:0:1:0:       class=0x060400 card=0x1f101849 chip=0x1f108086 rev=0x02 hdr=0x01
        device     = 'Atom processor C2000 PCIe Root Port 1'
        class      = bridge
        subclass   = PCI-PCI
    pcib7@pci0:0:3:0:       class=0x060400 card=0x1f121849 chip=0x1f128086 rev=0x02 hdr=0x01
        device     = 'Atom processor C2000 PCIe Root Port 3'
        class      = bridge
        subclass   = PCI-PCI
    pcib14@pci0:0:4:0:      class=0x060400 card=0x1f131849 chip=0x1f138086 rev=0x02 hdr=0x01
        device     = 'Atom processor C2000 PCIe Root Port 4'
        class      = bridge
        subclass   = PCI-PCI
    hostb1@pci0:0:14:0:     class=0x060000 card=0x1f141849 chip=0x1f148086 rev=0x02 hdr=0x00
        device     = 'Atom processor C2000 RAS'
        class      = bridge
        subclass   = HOST-PCI
    none0@pci0:0:15:0:      class=0x080600 card=0x1f161849 chip=0x1f168086 rev=0x02 hdr=0x00
        device     = 'Atom processor C2000 RCEC'
        class      = base peripheral
        subclass   = IOMMU
    none1@pci0:0:19:0:      class=0x088000 card=0x1f151849 chip=0x1f158086 rev=0x02 hdr=0x00
        device     = 'Atom processor C2000 SMBus 2.0'
    ehci0@pci0:0:22:0:      class=0x0c0320 card=0x1f2c1849 chip=0x1f2c8086 rev=0x02 hdr=0x00
        device     = 'Atom processor C2000 USB Enhanced Host Controller'
        class      = serial bus
        subclass   = USB
    ahci2@pci0:0:23:0:      class=0x010601 card=0x1f221849 chip=0x1f228086 rev=0x02 hdr=0x00
        device     = 'Atom processor C2000 AHCI SATA2 Controller'
        class      = mass storage
        subclass   = SATA
    ahci3@pci0:0:24:0:      class=0x010601 card=0x1f321849 chip=0x1f328086 rev=0x02 hdr=0x00
        device     = 'Atom processor C2000 AHCI SATA3 Controller'
        subclass   = SATA
    isab0@pci0:0:31:0:      class=0x060100 card=0x1f381849 chip=0x1f388086 rev=0x02 hdr=0x00
        device     = 'Atom processor C2000 PCU'
        class      = bridge
        subclass   = PCI-ISA
    none2@pci0:0:31:3:      class=0x0c0500 card=0x1f3c1849 chip=0x1f3c8086 rev=0x02 hdr=0x00
        device     = 'Atom processor C2000 PCU SMBus'
        class      = serial bus
        subclass   = SMBus
    pcib2@pci0:1:0:0:       class=0x060400 card=0x860810b5 chip=0x860810b5 rev=0xba hdr=0x01
        vendor     = 'PLX Technology, Inc.'
        device     = 'PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch'
        class      = bridge
        subclass   = PCI-PCI
    pcib3@pci0:2:1:0:       class=0x060400 card=0x860810b5 chip=0x860810b5 rev=0xba hdr=0x01
        class      = bridge
        subclass   = PCI-PCI
    pcib4@pci0:2:5:0:       class=0x060400 card=0x860810b5 chip=0x860810b5 rev=0xba hdr=0x01
        class      = bridge
        subclass   = PCI-PCI
    pcib5@pci0:2:7:0:       class=0x060400 card=0x860810b5 chip=0x860810b5 rev=0xba hdr=0x01
        class      = bridge
        subclass   = PCI-PCI
    pcib6@pci0:2:9:0:       class=0x060400 card=0x860810b5 chip=0x860810b5 rev=0xba hdr=0x01
        class      = bridge
        subclass   = PCI-PCI
    xhci0@pci0:3:0:0:       class=0x0c0330 card=0x00151912 chip=0x00151912 rev=0x02 hdr=0x00
        vendor     = 'Renesas Technology Corp.'
        device     = 'uPD720202 USB 3.0 Host Controller'
        class      = serial bus
        subclass   = USB
    xhci1@pci0:4:0:0:       class=0x0c0330 card=0x00151912 chip=0x00151912 rev=0x02 hdr=0x00
        class      = serial bus
        subclass   = USB
    xhci2@pci0:5:0:0:       class=0x0c0330 card=0x00151912 chip=0x00151912 rev=0x02 hdr=0x00
        class      = serial bus
        subclass   = USB
    xhci3@pci0:6:0:0:       class=0x0c0330 card=0x00151912 chip=0x00151912 rev=0x02 hdr=0x00
        class      = serial bus
        subclass   = USB
    pcib8@pci0:7:0:0:       class=0x060400 card=0x860810b5 chip=0x860810b5 rev=0xba hdr=0x01
        class      = bridge
        subclass   = PCI-PCI
    pcib9@pci0:8:1:0:       class=0x060400 card=0x860810b5 chip=0x860810b5 rev=0xba hdr=0x01
        class      = bridge
        subclass   = PCI-PCI
    pcib10@pci0:8:5:0:      class=0x060400 card=0x860810b5 chip=0x860810b5 rev=0xba hdr=0x01
        class      = bridge
        subclass   = PCI-PCI
    pcib12@pci0:8:7:0:      class=0x060400 card=0x860810b5 chip=0x860810b5 rev=0xba hdr=0x01
        class      = bridge
        subclass   = PCI-PCI
    pcib13@pci0:8:9:0:      class=0x060400 card=0x860810b5 chip=0x860810b5 rev=0xba hdr=0x01
        class      = bridge
        subclass   = PCI-PCI
    ahci0@pci0:9:0:0:       class=0x010601 card=0x91721849 chip=0x91721b4b rev=0x11 hdr=0x00
        vendor     = 'Marvell Technology Group Ltd.'
        device     = '88SE9172 SATA 6Gb/s Controller'
        subclass   = SATA
    pcib11@pci0:10:0:0:     class=0x060400 card=0x11501849 chip=0x11501a03 rev=0x02 hdr=0x01
        vendor     = 'ASPEED Technology, Inc.'
        device     = 'AST1150 PCI-to-PCI Bridge'
        class      = bridge
        subclass   = PCI-PCI
    vgapci0@pci0:11:0:0:    class=0x030000 card=0x20001849 chip=0x20001a03 rev=0x21 hdr=0x00
        device     = 'ASPEED Graphics Family'
        class      = display
        subclass   = VGA
    igb0@pci0:12:0:0:       class=0x020000 card=0x15331849 chip=0x15338086 rev=0x03 hdr=0x00
        device     = 'I210 Gigabit Network Connection'
        class      = network
        subclass   = ethernet
    igb1@pci0:13:0:0:       class=0x020000 card=0x15331849 chip=0x15338086 rev=0x03 hdr=0x00
        class      = network
        subclass   = ethernet
    ahci1@pci0:14:0:0:      class=0x010601 card=0x92301849 chip=0x92301b4b rev=0x11 hdr=0x00
        device     = '88SE9230 PCIe SATA 6Gb/s Controller'
        subclass   = SATA
debug
sfbayzfs
I had a different problem installing 9.10 onto a brand new Sandisk Cruzer Fit 16GB USB 2.0 version SDCZ33-016G-B35:
active set on da1
No handlers could be found for logger "freenasOS.Configuration"
File "/use/local/bin/freenas-install", line 56, in module
if installer.GetPackages() != True:
File "/usr/local/lib/freenasOS/Installer.py", line 857, in GetPackages
pkgFile = self._conf.FindPackageFile(pkg, handler=get_file_handler)
File "/usr/local/lib/freenasOS/Configuration.py", line 1101, in FinePackageFile
intr_ok = True
File "/usr/local/lib/freenasOS/Configuration.py", line 630, in TryGetNetworkFile
raise url_exc
urllib2.URLError: <urlopen error [Errno 8] hostname nor servname provided, or not known>
The FreeNAS installation on da1 has failed. Press enter to continue...
It did this with the disk brand new out of the package, and after I had dd'ed /dev/zero over the entire drive
zoomzoom
Please see the linked Bug Report.
The issue is most likely related to the illegal character cruzers' use in the file table (I believe it's the file table, but if it's not, it deals with an illegal character within a specific hex value in the firmware), or at least this was the impression I got after reading up on quirks. One of the maintainers believes it's due to quirks and is looking into it, however there is the possibility the cruzer drives will simply no longer be compatible with 9.10 onwards, as this is a problem specific to the cruzers. (Cruzers have also been notorious for having a high rate of failure on FreeNAS, however I used them simply because I upgraded to the 128GB model and had no other use for the two 64GB ones I replaced)
freenas4n00b
Thats interesting. i use two sandisk cruzer blades for over two years with 0 issues. Also just upgrade to 9.10 without a hitch.
i guess i am just lucky?
zoomzoom
Are you using USB2 or USB3 cruzers?
Also, as mentioned, this is an issue with 9.10 (i.e. FreeBSD 10.3), not 9.3 (FreeBSD 9.3) or backwards.
freenas4n00b
When i built my system, the USB3 had problems with Freenas so i went with USB2.
Being a boot device, i figured i dont need that extra speed anyways.
zoomzoom
Unless you just built the system in the last couple of days, your experience has nothing to do with the issue this thread is about.
Again, this is an issue with cruzers and FreeNAS 9.10 (FreeBSD 10.3). Please take the time to read the bug report.
freenas4n00b
1. I am using cruzers
2. I am running Freenas 9.10
Those two make it relevant but oh well. Sorry to bother. Good luck
sfbayzfs
My issue is different - after wiping a Transcend 32GB USB2 mini drive, it crashed in the exact same place as the 16GB USB2 Cruzer Fit did upon fresh 9.10 install attempt. I was able to reinstall 9.3.1 onto the same Cruzer fit with no problems after wiping it with dd. These installs were both on an HP Microserver N40L.
zoomzoom
" i use two sandisk cruzer blades for over two years with 0 issues"
Per the above statement, your experience has nothing to do with the issue this thread is about. Even more baffling, I clearly state this was experienced on a USB3 cruzer, of which you don't utilize, and is yet another reason why your experience thus far does not apply to this specific thread.
I'm baffled why you bothered to reply to the thread at all for the simple fact this is a bug with 9.10 and has zero to do with faulty hardware or user actions. What exactly you're wishing good luck to is also baffling, seeming as this seems to be tied to quirks in FreeBSD 10.3, which you'd know had you taken the time to read the bug report.
Do you recommend I place a huge red arrow stating read bug report prior to replying, as I figured putting it at the very beginning of the OP would have been construed as perhaps one should read it prior to commenting. I didn't post the information in the OP on a whim, so if one is not going to take the time to legitimately contemplate the information provided to them prior to commenting, perhaps it's best to not comment at all (or at the very least until one has done the common sense thing and read the information referenced).
zoomzoom
Why exactly are you posting without having bothered to read the information referenced in the first post? There's a link to the Bug Report that was filed for a reason...
joeschmuck
Old Man
Do we need to lock this thread or just hope folks read the bug report. I think your first statement is pretty clear to me. I would however take and add the bug hyperlink to the text in red as well because some folks are going to overlook the blue link in small text above it and not realize it's linked to the bug report, or just make the "Bug Report Submitted" say something like "Link to Bug Report". Your call, I'm just offering some friendly advice in hopes to reduce needless postings.
zoomzoom
Locking the thread is fine, as I was going to ask for it to be deleted (unless you or other mods believe it should remain as more of an informational type thread). I submitted the Bug Report after creating the thread, once it became apparent hardware wasn't the issue.
I've made the suggested changes in case you or other mods believe it will help others by keeping the thread.
thewizard
Sandisk Cruzer Blade, same issue upgraded from 9.2.1.7 to 9.3 toasted! Lucky I saved a backup of my config hey. System just doesn't post at all with the 9.3 image on two different Sandisk USB's I have.
joeschmuck
Old Man
The data is still valuable to anyone having the same problem and since yet another posting of an unrelated problem was posted, I'll lock it.
joeschmuck
Old Man
Problem Solved, please see bug report.
