SOLVED Volume Import Issue
Reckman
Sorry if this is a really simple fix, I am a FreeNAS newb.
I am upgrading my system and am trying to import my pool. I first tried to do it with the GUI. Volume showed up, I started importing it. GUI showed the busy progress bar, so I waited a few hours. It never went away. I ran Zpool status from the shell and everything looked ok so I rebooted. Pool doesn't show up in any of the menus. Thanks for the help, below is some more information if you need it.
[root@RRZFS ~]# zpool status
pool: RAID5-1
state: ONLINE
status: Some supported features are not enabled on the pool. The pool can
still be used, but some features are unavailable.
scan: scrub repaired 0 in 19h42m with 0 errors on Wed Aug 27 19:42:13 2014
NAME STATE READ WRITE CKSUM
RAID5-1 ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
gptid/7cef0b02-f8b9-11e2-b029-001a64a8693c ONLINE 0 0 0
gptid/7d73fae7-f8b9-11e2-b029-001a64a8693c ONLINE 0 0 0
gptid/049a6ec5-fe32-11e2-bd34-001a64a8693c ONLINE 0 0 0
gptid/7e5d0238-f8b9-11e2-b029-001a64a8693c ONLINE 0 0 0
raidz1-1 ONLINE 0 0 0
gptid/81d0fa3b-ffbf-11e2-b631-001a64a8693c ONLINE 0 0 0
gptid/82820479-ffbf-11e2-b631-001a64a8693c ONLINE 0 0 0
gptid/8318cdd3-ffbf-11e2-b631-001a64a8693c ONLINE 0 0 0
gptid/83919012-ffbf-11e2-b631-001a64a8693c ONLINE 0 0 0
errors: No known data errors
[root@RRZFS ~]# zpool import
[root@RRZFS ~]#
System Info
Freenase - FreeNAS-9.2.1.7-RELEASE-x64 (fdbe9a0)
Motherboard - Supermicro X10SL7-F
CPU - I3 4360 Haswell Dual-Core
Ram - (4) Samsung 8GB DDR3-1600 MHz PC3-12800 240-pin ECC Server Memory - M391B1G73QH0-YK0
Hard Drives -
(7) Hitachi (Toshiba) 3TB 7200rpm 64MB 3.5" SATA3 6Gb/s Hard Drive 9F24312
(1) 3TB WD Green
(4) Hitachi Deskstar 5K3000 HDS5C3030ALA630 3 TB,Internal,5200 RPM,3.5" (0F12460) Hard Drive
First 8 drives are in one pool with two VDev Raid-Z2
[root@RRZFS] ~# dmesg
Copyright (c) 1992-2013 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
        The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 9.2-RELEASE-p10 #0 r262572+4fb5adc: Wed Aug  6 17:07:16 PDT 2014
    root@build3.ixsystems.com:/fusion/jkh/921/freenas/os-base/amd64/fusion/jkh/921/freenas/FreeBSD/src/sys/FREENAS.amd64 amd64
gcc version 4.2.1 20070831 patched [FreeBSD]
CPU: Intel(R) Core(TM) i3-4360 CPU @ 3.70GHz (3700.07-MHz K8-class CPU)
  Origin = "GenuineIntel"  Id = 0x306c3  Family = 0x6  Model = 0x3c  Stepping = 3
  Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
  Features2=0x7fdafbbf<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,<b11>,FMA,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,MOVBE,POPCNT,TSCDLT,AESNI,XSAVE,OSXSAVE,AVX,F16C,RDRAND>
  AMD Features=0x2c100800<SYSCALL,NX,Page1GB,RDTSCP,LM>
  AMD Features2=0x21<LAHF,ABM>
  Standard Extended Features=0x27ab<GSFSBASE,TSCADJ,SMEP,ENHMOVSB,INVPCID>
  TSC: P-state invariant, performance statistics
real memory  = 34359738368 (32768 MB)
avail memory = 33129791488 (31595 MB)
Event timer "LAPIC" quality 600
ACPI APIC Table: <SUPERM SMCI--MB>
FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
FreeBSD/SMP: 1 package(s) x 2 core(s) x 2 SMT threads
 cpu0 (BSP): APIC ID:  0
 cpu1 (AP): APIC ID:  1
 cpu2 (AP): APIC ID:  2
 cpu3 (AP): APIC ID:  3
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ACPI Warning: FADT (revision 5) is longer than ACPI 2.0 version, truncating length 268 to 244 (20110527/tbfadt-320)
ioapic0 <Version 2.0> irqs 0-23 on motherboard
kbd1 at kbdmux0
cryptosoft0: <software crypto> on motherboard
aesni0: <AES-CBC,AES-XTS> on motherboard
padlock0: No ACE support.
acpi0: <SUPERM SMCI--MB> on motherboard
acpi0: Power Button (fixed)
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
cpu2: <ACPI CPU> on acpi0
cpu3: <ACPI CPU> on acpi0
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 950
Event timer "HPET" frequency 14318180 Hz quality 550
Event timer "HPET1" frequency 14318180 Hz quality 440
Event timer "HPET2" frequency 14318180 Hz quality 440
Event timer "HPET3" frequency 14318180 Hz quality 440
Event timer "HPET4" frequency 14318180 Hz quality 440
atrtc0: <AT realtime clock> port 0x70-0x77 irq 8 on acpi0
Event timer "RTC" frequency 32768 Hz quality 0
attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x1808-0x180b on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> irq 16 at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib1
pcib2: <ACPI PCI-PCI bridge> irq 16 at device 1.1 on pci0
pci2: <ACPI PCI bus> on pcib2
mps0: <LSI SAS2308> port 0xe000-0xe0ff mem 0xf7240000-0xf724ffff,0xf7200000-0xf723ffff irq 17 at device 0.0 on pci2
mps0: Firmware: 16.00.01.00, Driver: 16.00.00.00-fbsd
mps0: IOCCapabilities: 1285c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,HostDisc>
pci0: <serial bus, USB> at device 20.0 (no driver attached)
ehci0: <EHCI (generic) USB 2.0 controller> mem 0xf7514000-0xf75143ff irq 16 at device 26.0 on pci0
usbus0: EHCI version 1.0
usbus0 on ehci0
pcib3: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0
pci3: <ACPI PCI bus> on pcib3
pcib4: <ACPI PCI-PCI bridge> at device 0.0 on pci3
pci4: <ACPI PCI bus> on pcib4
vgapci0: <VGA-compatible display> port 0xd000-0xd07f mem 0xf6000000-0xf6ffffff,0xf7000000-0xf701ffff irq 16 at device 0.0 on pci4
pcib5: <ACPI PCI-PCI bridge> irq 18 at device 28.2 on pci0
pci5: <ACPI PCI bus> on pcib5
igb0: <Intel(R) PRO/1000 Network Connection version - 2.4.0> port 0xc000-0xc01f mem 0xf7400000-0xf747ffff,0xf7480000-0xf7483fff irq 18 at device 0.0 on pci5
igb0: Using MSIX interrupts with 5 vectors
igb0: Ethernet address: 0c:c4:7a:30:14:78
igb0: Bound queue 0 to cpu 0
igb0: Bound queue 1 to cpu 1
igb0: Bound queue 2 to cpu 2
igb0: Bound queue 3 to cpu 3
pcib6: <ACPI PCI-PCI bridge> irq 19 at device 28.3 on pci0
pci6: <ACPI PCI bus> on pcib6
igb1: <Intel(R) PRO/1000 Network Connection version - 2.4.0> port 0xb000-0xb01f mem 0xf7300000-0xf737ffff,0xf7380000-0xf7383fff irq 19 at device 0.0 on pci6
igb1: Using MSIX interrupts with 5 vectors
igb1: Ethernet address: 0c:c4:7a:30:14:79
igb1: Bound queue 0 to cpu 0
igb1: Bound queue 1 to cpu 1
igb1: Bound queue 2 to cpu 2
igb1: Bound queue 3 to cpu 3
ehci1: <EHCI (generic) USB 2.0 controller> mem 0xf7513000-0xf75133ff irq 23 at device 29.0 on pci0
usbus1: EHCI version 1.0
usbus1 on ehci1
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
ahci0: <Intel Lynx Point AHCI SATA controller> port 0xf050-0xf057,0xf040-0xf043,0xf030-0xf037,0xf020-0xf023,0xf000-0xf01f mem 0xf7512000-0xf75127ff irq 19 at device 31.2 on pci0
ahci0: AHCI v1.30 with 6 6Gbps ports, Port Multiplier not supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
ahcich2: <AHCI channel> at channel 2 on ahci0
ahcich3: <AHCI channel> at channel 3 on ahci0
ahcich4: <AHCI channel> at channel 4 on ahci0
ahcich5: <AHCI channel> at channel 5 on ahci0
pci0: <serial bus, SMBus> at device 31.3 (no driver attached)
pci0: <dasp> at device 31.6 (no driver attached)
acpi_button0: <Sleep Button> on acpi0
acpi_button1: <Power Button> on acpi0
acpi_tz0: <Thermal Zone> on acpi0
acpi_tz1: <Thermal Zone> on acpi0
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0
uart2: <16550 or compatible> port 0x3e8-0x3ef irq 7 on acpi0
orm0: <ISA Option ROM> at iomem 0xc0000-0xc7fff on isa0
sc0: <System console> at flags 0x100 on isa0
sc0: CGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3d0-0x3db iomem 0xb8000-0xbffff on isa0
wbwd0: DevID 0xc3 DevRev 0x33, will not attach, please report this.
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
est0: <Enhanced SpeedStep Frequency Control> on cpu0
p4tcc0: <CPU Frequency Thermal Control> on cpu0
coretemp1: <CPU On-Die Thermal Sensors> on cpu1
est1: <Enhanced SpeedStep Frequency Control> on cpu1
p4tcc1: <CPU Frequency Thermal Control> on cpu1
coretemp2: <CPU On-Die Thermal Sensors> on cpu2
est2: <Enhanced SpeedStep Frequency Control> on cpu2
p4tcc2: <CPU Frequency Thermal Control> on cpu2
coretemp3: <CPU On-Die Thermal Sensors> on cpu3
est3: <Enhanced SpeedStep Frequency Control> on cpu3
p4tcc3: <CPU Frequency Thermal Control> on cpu3
Timecounters tick every 1.000 msec
ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
DUMMYNET 0xfffffe00082f5c80 with IPv6 initialized (100409)
load_dn_sched dn_sched RR loaded
load_dn_sched dn_sched WF2Q+ loaded
load_dn_sched dn_sched FIFO loaded
load_dn_sched dn_sched PRIO loaded
load_dn_sched dn_sched QFQ loaded
usbus0: 480Mbps High Speed USB v2.0
usbus1: 480Mbps High Speed USB v2.0
ugen0.1: <Intel> at usbus0
uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0
ugen1.1: <Intel> at usbus1
uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
ada0 at ahcich2 bus 0 scbus3 target 0 lun 0
ada0: <TOSHIBA DT01ACA300 MX6OABB0> ATA-8 SATA 3.x device
ada0: Serial Number 13H89SBGS
ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada0: Previously was known as ad8
ada1 at ahcich3 bus 0 scbus4 target 0 lun 0
ada1: <WDC WD30EZRX-00DC0B0 80.00A80> ATA-9 SATA 3.x device
ada1: Serial Number WD-WMC1T1984544
ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada1: quirks=0x1<4K>
ada1: Previously was known as ad10
ada2 at ahcich4 bus 0 scbus5 target 0 lun 0
ada2: <TOSHIBA DT01ACA300 MX6OABB0> ATA-8 SATA 3.x device
ada2: Serial Number 13K7Z77GS
ada2: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada2: Command Queueing enabled
ada2: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada2: Previously was known as ad12
ada3 at ahcich5 bus 0 scbus6 target 0 lun 0
ada3: <Hitachi HDS5C3030ALA630 MEAOA5C0> ATA-8 SATA 3.x device
ada3: Serial Number MJ1311YNG7ESGA
ada3: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada3: Command Queueing enabled
ada3: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada3: Previously was known as ad14
SMP: AP CPU #1 Launched!
da1 at mps0 bus 0 scbus0 target 1 lun 0
da1: <ATA TOSHIBA DT01ACA3 ABB0> Fixed Direct Access SCSI-6 device
da1: Serial Number            13K8YAGGS
SMP: AP CPU #2 Launched!
da1: 600.000MB/s transfers
da1: 2861588MB (5860533168 512 byte sectors: 255H 63S/T 364801C)
da2 at mps0 bus 0 scbus0 target 2 lun 0
SMP: AP CPU #3 Launched!
da2: <ATA TOSHIBA DT01ACA3 ABB0> Fixed Direct Access SCSI-6 device
da2: Serial Number            13K8Y89GS
da2: 600.000MB/s transfers
da2: 2861588MB (5860533168 512 byte sectors: 255H 63S/T 364801C)
da3 at mps0 bus 0 scbus0 target 3 lun 0
da3: <ATA TOSHIBA DT01ACA3 ABB0> Fixed Direct Access SCSI-6 device
da3: Serial Number            13K8RT7GS
da3: 600.000MB/s transfers
da3: 2861588MB (5860533168 512 byte sectors: 255H 63S/T 364801C)
da4 at mps0 bus 0 scbus0 target 4 lun 0
da4: <ATA TOSHIBA DT01ACA3 ABB0> Fixed Direct Access SCSI-6 device
da4: Serial Number            13K8Y9ZGS
da4: 600.000MB/s transfers
da4: Command Queueing enabled
da4: 2861588MB (5860533168 512 byte sectors: 255H 63S/T 364801C)
da5 at mps0 bus 0 scbus0 target 5 lun 0
da5: <ATA TOSHIBA DT01ACA3 ABB0> Fixed Direct Access SCSI-6 device
da5: Serial Number            13H80JXGS
da5: 600.000MB/s transfers
da5: Command Queueing enabled
da5: 2861588MB (5860533168 512 byte sectors: 255H 63S/T 364801C)
da0 at mps0 bus 0 scbus0 target 0 lun 0
da0: <ATA Hitachi HDS5C303 A5C0> Fixed Direct Access SCSI-6 device
da0: Serial Number       MJ1311YNG5U3AA
da0: 600.000MB/s transfers
da0: 2861588MB (5860533168 512 byte sectors: 255H 63S/T 364801C)
da6 at mps0 bus 0 scbus0 target 6 lun 0
da6: <ATA Hitachi HDS5C303 A5C0> Fixed Direct Access SCSI-6 device
da6: Serial Number       MJ1311YNG69AHA
da6: 600.000MB/s transfers
da6: Command Queueing enabled
da6: 2861588MB (5860533168 512 byte sectors: 255H 63S/T 364801C)
da7 at mps0 bus 0 scbus0 target 7 lun 0
da7: <ATA Hitachi HDS5C303 A5C0> Fixed Direct Access SCSI-6 device
da7: Serial Number       MJ1311YNG73H5A
da7: 600.000MB/s transfers
da7: Command Queueing enabled
da7: 2861588MB (5860533168 512 byte sectors: 255H 63S/T 364801C)
Timecounter "TSC-low" frequency 1850035564 Hz quality 1000
uhub0: 2 ports with 2 removable, self powered
uhub1: 2 ports with 2 removable, self powered
GEOM_PART: integrity check failed (ada3, MBR)
ugen0.2: <vendor 0x8087> at usbus0
uhub2: <vendor 0x8087 product 0x8008, class 9/0, rev 2.00/0.05, addr 2> on usbus0
ugen1.2: <vendor 0x8087> at usbus1
uhub3: <vendor 0x8087 product 0x8000, class 9/0, rev 2.00/0.05, addr 2> on usbus1
uhub2: 4 ports with 4 removable, self powered
uhub3: 6 ports with 6 removable, self powered
ugen0.3: <vendor 0x0000> at usbus0
uhub4: <vendor 0x0000 product 0x0001, class 9/0, rev 2.00/0.00, addr 3> on usbus0
ugen1.3: <Corsair> at usbus1
umass0: <Corsair Survivor 3.0, class 0/0, rev 2.10/1.10, addr 3> on usbus1
umass0:  SCSI over Bulk-Only; quirks = 0x0100
umass0:8:0:-1: Attached to scbus8
da8 at umass-sim0 bus 0 scbus8 target 0 lun 0
da8: <Corsair Survivor 3.0 PMAP> Removable Direct Access SCSI-6 device
da8: Serial Number 07083713EE1B9F47
da8: 40.000MB/s transfers
da8: 15288MB (31309824 512 byte sectors: 255H 63S/T 1948C)
da8: quirks=0x2<NO_6_BYTE>
ugen1.4: <vendor 0x04d9> at usbus1
ukbd0: <vendor 0x04d9 USB Keyboard, class 0/0, rev 1.10/4.03, addr 4> on usbus1
kbd0 at ukbd0
uhid0: <vendor 0x04d9 USB Keyboard, class 0/0, rev 1.10/4.03, addr 4> on usbus1
Root mount waiting for: usbus0
uhub_attach: port 4 power on failed, USB_ERR_TIMEOUT
uhub4: 4 ports with 3 removable, self powered
ugen0.4: <vendor 0x0557> at usbus0
ukbd1: <vendor 0x0557 product 0x2419, class 0/0, rev 1.10/1.00, addr 4> on usbus0
kbd2 at ukbd1
ums0: <vendor 0x0557 product 0x2419, class 0/0, rev 1.10/1.00, addr 4> on usbus0
ums0: 3 buttons and [Z] coordinates ID=0
Trying to mount root from ufs:/dev/ufs/FreeNASs1a [ro]...
GEOM_RAID5: Module loaded, version 1.1.20130907.44 (rev 5c6d2a159411)
GEOM_ELI: Device ada0p1.eli created.
GEOM_ELI: Encryption: AES-XTS 256
GEOM_ELI:     Crypto: hardware
GEOM_ELI: Device ada1p1.eli created.
GEOM_ELI: Device ada2p1.eli created.
GEOM_ELI: Device da1p1.eli created.
GEOM_ELI: Device da2p1.eli created.
GEOM_ELI: Device da3p1.eli created.
GEOM_ELI: Device da4p1.eli created.
GEOM_ELI: Device da5p1.eli created.
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
vboxdrv: fAsync=0 offMin=0x1cc offMax=0xf3c
mjws00
Nice job providing information. :) What version was the pool built on?
I'd try exporting the pool and then going for a clean import via the GUI:
#zpool export RAID5-1
Give it a shot. It should import quickly, not take hours.
mjws00
Fantastic. Looks like a lot of data to trust to Z1. Not sure what you're storing... but a poorly timed URE might hurt.
Reckman
Yea I know...not exactly easy switching to a new pool though. Its not like I can toss 15 tb onto my desktop.
mjws00
Been there. :) Glad you're rollin.
