Offline/Unreadable sectors
g4m3r7ag
I got two alerts today that indicate a drive is failing
Device: /dev/sdaa [SAT], 1 Offline uncorrectable sectors.
2023-08-25 05:35:12 (America/New_York)
Device: /dev/sdaa [SAT], 1 Currently unreadable (pending) sectors.
Smartctl shows 5 sectors
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     POSR--   084   064   044    -    232741880
  3 Spin_Up_Time            PO----   097   097   000    -    0
  4 Start_Stop_Count        -O--CK   100   100   020    -    3
  5 Reallocated_Sector_Ct   PO--CK   100   100   010    -    0
  7 Seek_Error_Rate         POSR--   072   060   045    -    15623910
  9 Power_On_Hours          -O--CK   100   100   000    -    186
 10 Spin_Retry_Count        PO--C-   100   100   097    -    0
 12 Power_Cycle_Count       -O--CK   100   100   020    -    3
 18 Unknown_Attribute       PO-R--   100   100   050    -    0
187 Reported_Uncorrect      -O--CK   100   100   000    -    0
188 Command_Timeout         -O--CK   100   100   000    -    0
190 Airflow_Temperature_Cel -O---K   063   048   000    -    37 (Min/Max 32/41)
192 Power-Off_Retract_Count -O--CK   100   100   000    -    3
193 Load_Cycle_Count        -O--CK   100   100   000    -    184
194 Temperature_Celsius     -O---K   037   043   000    -    37 (0 24 0 0 0)
197 Current_Pending_Sector  -O--C-   100   100   000    -    5
198 Offline_Uncorrectable   ----C-   100   100   000    -    5
199 UDMA_CRC_Error_Count    -OSRCK   200   200   000    -    0
200 Multi_Zone_Error_Rate   PO---K   100   100   001    -    0
240 Head_Flying_Hours       ------   100   100   000    -    177 (139 157 0)
241 Total_LBAs_Written      ------   100   253   000    -    4114527832
242 Total_LBAs_Read         ------   100   253   000    -    757907169
I know the drive needs replaced, my question is, why does zpool status show everything as healthy and both of my spares as available? Shouldn't one of them have replaced this drive? What is the best way to go about replacing this drive?
  pool: mediapool
 state: ONLINE
  scan: scrub repaired 0B in 00:56:21 with 0 errors on Sun Aug 20 00:56:23 2023
        NAME                                      STATE     READ WRITE CKSUM
        mediapool                                 ONLINE       0     0     0
          raidz2-0                                ONLINE       0     0     0
            fc28be11-cfcb-4310-a4d5-36531d779a7d  ONLINE       0     0     0
            d43e06b3-c91f-4687-bdd0-15a303bf8fdb  ONLINE       0     0     0
            330eb677-d7c4-44d4-a6db-602496cf9001  ONLINE       0     0     0
            080e9d00-9a9d-44c1-b279-bc410cca13bd  ONLINE       0     0     0
            21cb0b7b-9306-4693-8519-c482d285fb1f  ONLINE       0     0     0
            4b59be12-1d6e-42f0-92e3-4b4280c02511  ONLINE       0     0     0
            c2fbd595-b01b-4fe4-8c8f-87e2306ac28d  ONLINE       0     0     0
            a4c99187-0f71-4a6f-83a0-58e28a9e075e  ONLINE       0     0     0
            25484855-c687-4f1e-bd5d-1465c9fec243  ONLINE       0     0     0
          raidz2-1                                ONLINE       0     0     0
            c31032f7-7caf-40c8-a7ad-42e2ecf2e7cf  ONLINE       0     0     0
            85674f4b-7343-4866-adb3-99a97e0930cf  ONLINE       0     0     0
            513e8932-da72-462e-9e2d-b6e4bdac5bc3  ONLINE       0     0     0
            1e0a6702-6ae8-4928-9d31-4f790acaf709  ONLINE       0     0     0
            4d7d74a9-0210-425e-afa5-ac6b242d46c9  ONLINE       0     0     0
            a2e8f227-19b9-4e78-a698-1c3b7db3314a  ONLINE       0     0     0
            d0faddc4-bcab-4798-8540-b52657b93ff8  ONLINE       0     0     0
            c59d3768-5540-464f-83dd-942bf8e72486  ONLINE       0     0     0
            953d3df3-392a-4809-98d1-43c00cb4659a  ONLINE       0     0     0
          raidz2-2                                ONLINE       0     0     0
            5bb4e189-dbc1-4063-916d-2f0c1fbd7cb6  ONLINE       0     0     0
            9a6c21c7-9f0a-4b0a-baa3-be34c90e2759  ONLINE       0     0     0
            1541d9c8-faa2-403e-8b13-257bdc2140cd  ONLINE       0     0     0
            c5cca3a8-3daa-45cc-a7c6-91742c66722f  ONLINE       0     0     0
            58391c13-a95a-4ce0-87d1-a1d6e16be8f4  ONLINE       0     0     0
            cb00cce6-b7fc-4556-aaff-0b9a52d5e1c7  ONLINE       0     0     0
            0c22e517-ec04-4498-8b82-bf26cbc606e8  ONLINE       0     0     0
            04d9c373-3c6f-47af-b0fc-6d09769816da  ONLINE       0     0     0
            1117b896-1de4-46fc-8d43-3e58bf0f5408  ONLINE       0     0     0
          raidz2-3                                ONLINE       0     0     0
            da5c4592-1862-4e0e-8a62-2e06b5bc6930  ONLINE       0     0     0
            59e2457a-2d68-4f1b-8620-7f1b557bb75a  ONLINE       0     0     0
            e78825e2-46ef-4eb8-befe-b3f48dd55898  ONLINE       0     0     0
            bdf4eca6-6286-4bd1-be1c-93983832d97d  ONLINE       0     0     0
            f4b2f430-c984-4606-b03d-f8886b723860  ONLINE       0     0     0
            2ff78736-177a-4398-8c05-416077046249  ONLINE       0     0     0
            340b51f4-5569-437a-a475-eb0d7926c7be  ONLINE       0     0     0
            fbfbbdfa-d56d-4668-8ad7-6fb6edcb1ad0  ONLINE       0     0     0
            906d152d-e26c-4f07-9f84-e5bb7bf0fdf5  ONLINE       0     0     0
        spares
          f2fa95b4-0f16-4c4e-9a3a-0284c7a6209d    AVAIL
          dd7827ca-6619-447d-b28f-4ea8f62b7dac    AVAIL
errors: No known data errors
Because, apparently, no reads/writes have hit any of the failing sectors. This is a perfectly normal situation.
According to the docs.
Two things at odds:
g4m3r7ag
Two things at odds:
Why is that? They are Manufacturer recertified Seagate Exos drives so I assume SMART data was wiped to some extent.
joeschmuck
Old Man
You have provided very limited data in order to give you a proper diagnosis however if you provide the entire output of smartctl -x /dev/sdaa then we can provide a conclusive answer.
Have you run a SMART Long test? I would recommend you do that.
Based on the information you provided @WI_Hedgehog hit the nail on the head. The drive has very few power_on_hours, the load_cycle_count is also very low. And you can ignore ID 1 and ID 7, this is a unique coding by Seagate, you actually have zero errors.
Does it? I don't know that. I guess if you purchased a used drive from an unreputable source then maybe the drive statistics could have been erased, or the manufacturer did. But I'd think it was still in warranty and if so, then I'd replace it. If there is no warranty remaining, run a SMART Long Test and post the smartctl -x data after it's completed. You may redact the drive serial number if you desire. Some people are a little sensitive to that.
Also, Current Pending Sector Error means that a sector was having problems reading the data but it eventually did read the data. If it was unable to read the data at all, then it would be reflected in ID 5 as a Reallocated Sector.
g4m3r7ag
Does it? I don't know that. I guess if you purchased a used drive from an unreputable source then maybe the drive statistics could have been erased, or the manufacturer did. But I'd think it was still in warranty and if so, then I'd replace it. If there is not warranty remaining, run a SMART Long Test and post the smartctl -x data after it's completed. You may redact the drive serial number if you desire. Some people are a little sensitive to that.
I have a SMART long test running that I started after the error came in. The last one that ran was a week ago, right after I installed the drive along with 35 others. I'll post the full output once it completes.
joeschmuck
Old Man
Do you know if the drives are under warranty? If yes, hopefully you can get an RMA going. I know refurbished drives hold a very small warranty normally. For any other refurbished drives, I'd recommend you burn them in if you haven't already. It may save you some grief.
g4m3r7ag
There's a two year warranty from the seller where I bought them, not through the manufacturer according to their website. I checked the serial with Seagate anyways and it shows under warranty until December. I already contacted the seller about the offline uncorrectables, waiting to hear back from them but don't expect a response until Monday. I assumed since TrueNAS threw the red/critical error that the drive was bad. Not sure why it throws a critical error if it's not critical enough for it to automatically offline the drive and start a resilver with the hotspare.
joeschmuck
Old Man
I can't answer that either, however Pending Sector Errors is not critical in my book, it's a warning to keep an eye on the drive. When ID 5 Reallocated Sectors starts to increment, that is critical to me because it shows that a portion of the drive was not readable. When drives are manufactured, some sectors are mapped out because they are unreadable, but the manufacturer then zero's out the SMART values. They do not expect any further media problems but it happens.
g4m3r7ag
The SMART Long test completed, here is the output
root@truenas01[/home/admin]# smartctl -x /dev/sdaa
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.107+truenas] (local build)
Device Model:     ST20000NM007D-3DJ103
Serial Number:    XXXXXXXX
LU WWN Device Id: 5 000c50 0e63f5d65
Firmware Version: SN03
User Capacity:    20,000,588,955,648 bytes [20.0 TB]
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ACS-4 (minor revision not indicated)
SATA Version is:  SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sat Aug 26 14:34:19 2023 EDT
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Unavailable
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Disabled
ATA Security is:  Disabled, NOT FROZEN [SEC1]
Write SCT (Get) Feature Control Command failed: scsi error aborted command
Wt Cache Reorder: Unknown (SCT Feature Control command failed)
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
Self-test execution status:      ( 121) The previous self-test completed having
                                        the read element of the test failed.
data collection:                (  567) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        (1729) minutes.
Conveyance self-test routine
SCT capabilities:              (0x70bd) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     POSR--   073   064   044    -    19304848
  7 Seek_Error_Rate         POSR--   072   060   045    -    17394537
  9 Power_On_Hours          -O--CK   100   100   000    -    206
190 Airflow_Temperature_Cel -O---K   062   048   000    -    38 (Min/Max 32/41)
193 Load_Cycle_Count        -O--CK   100   100   000    -    185
194 Temperature_Celsius     -O---K   038   043   000    -    38 (0 24 0 0 0)
240 Head_Flying_Hours       ------   100   100   000    -    197 (176 39 0)
241 Total_LBAs_Written      ------   100   253   000    -    4625374512
242 Total_LBAs_Read         ------   100   253   000    -    766046729
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      5  Comprehensive SMART error log
0x03       GPL     R/O      5  Ext. Comprehensive SMART error log
0x04       GPL     R/O    256  Device Statistics log
0x04       SL      R/O      8  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x08       GPL     R/O      2  Power Conditions log
0x09           SL  R/W      1  Selective self-test log
0x0a       GPL     R/W      8  Device Statistics Notification
0x0c       GPL     R/O   2048  Pending Defects log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x13       GPL     R/O      1  SATA NCQ Send and Receive log
0x21       GPL     R/O      1  Write stream error log
0x22       GPL     R/O      1  Read stream error log
0x24       GPL     R/O    768  Current Device Internal Status Data log
0x2f       GPL     -        1  Set Sector Configuration
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xa1       GPL,SL  VS     160  Device vendor specific log
0xa2       GPL     VS   16320  Device vendor specific log
0xa4       GPL,SL  VS     160  Device vendor specific log
0xa6       GPL     VS     192  Device vendor specific log
0xa8-0xa9  GPL,SL  VS     136  Device vendor specific log
0xab       GPL     VS       1  Device vendor specific log
0xad       GPL     VS      16  Device vendor specific log
0xb1       GPL,SL  VS     160  Device vendor specific log
0xb6       GPL     VS    1920  Device vendor specific log
0xbe-0xbf  GPL     VS   65535  Device vendor specific log
0xc1       GPL,SL  VS       8  Device vendor specific log
0xc3       GPL,SL  VS      24  Device vendor specific log
0xc6       GPL     VS    5184  Device vendor specific log
0xc7       GPL,SL  VS       8  Device vendor specific log
0xc9       GPL,SL  VS       8  Device vendor specific log
0xca       GPL,SL  VS      16  Device vendor specific log
0xcd       GPL,SL  VS       1  Device vendor specific log
0xce       GPL     VS       1  Device vendor specific log
0xcf       GPL     VS     512  Device vendor specific log
0xd1       GPL     VS     656  Device vendor specific log
0xd2       GPL     VS   10256  Device vendor specific log
0xd4       GPL     VS    2048  Device vendor specific log
0xda       GPL,SL  VS       1  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (5 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1  Extended offline    Completed: read failure       90%       192         5258602744
# 2  Short offline       Completed without error       00%       101         -
# 3  Extended offline    Completed without error       00%        42         -
# 4  Short offline       Completed without error       00%        15         -
SCT Status Version:                  3
SCT Version (vendor specific):       522 (0x020a)
Device State:                        Active (0)
Current Temperature:                    38 Celsius
Power Cycle Min/Max Temperature:     32/41 Celsius
Lifetime    Min/Max Temperature:     23/52 Celsius
Under/Over Temperature Limit Count:   0/6
SMART Status:                        0xc24f (PASSED)
Vendor specific:
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version:     2
Temperature Sampling Period:         4 minutes
Temperature Logging Interval:        59 minutes
Min/Max recommended Temperature:     10/40 Celsius
Min/Max Temperature Limit:            5/60 Celsius
Temperature History Size (Index):    128 (86)
Index    Estimated Time   Temperature Celsius
  87    2023-08-21 08:58    40  *********************
 ...    ..(  5 skipped).    ..  *********************
  93    2023-08-21 14:52    40  *********************
  94    2023-08-21 15:51    41  **********************
 ...    ..(  4 skipped).    ..  **********************
  99    2023-08-21 20:46    41  **********************
 100    2023-08-21 21:45    40  *********************
 101    2023-08-21 22:44    39  ********************
 102    2023-08-21 23:43    40  *********************
 103    2023-08-22 00:42    39  ********************
 ...    ..(  2 skipped).    ..  ********************
 106    2023-08-22 03:39    39  ********************
 107    2023-08-22 04:38    38  *******************
 ...    ..(  9 skipped).    ..  *******************
 117    2023-08-22 14:28    38  *******************
 118    2023-08-22 15:27    39  ********************
 ...    ..(  6 skipped).    ..  ********************
 125    2023-08-22 22:20    39  ********************
 126    2023-08-22 23:19    38  *******************
   1    2023-08-23 02:16    38  *******************
   2    2023-08-23 03:15    33  **************
   9    2023-08-23 10:08    33  **************
  10    2023-08-23 11:07    32  *************
  11    2023-08-23 12:06    32  *************
  12    2023-08-23 13:05    35  ****************
  13    2023-08-23 14:04    36  *****************
  14    2023-08-23 15:03    36  *****************
  15    2023-08-23 16:02    37  ******************
  16    2023-08-23 17:01    37  ******************
  17    2023-08-23 18:00    38  *******************
 ...    ..( 10 skipped).    ..  *******************
  28    2023-08-24 04:49    38  *******************
  29    2023-08-24 05:48    39  ********************
  30    2023-08-24 06:47    39  ********************
  31    2023-08-24 07:46    38  *******************
  32    2023-08-24 08:45    39  ********************
  33    2023-08-24 09:44    38  *******************
  34    2023-08-24 10:43    38  *******************
  35    2023-08-24 11:42    38  *******************
  36    2023-08-24 12:41    37  ******************
  37    2023-08-24 13:40    36  *****************
  38    2023-08-24 14:39    38  *******************
  48    2023-08-25 00:29    38  *******************
  49    2023-08-25 01:28    39  ********************
  50    2023-08-25 02:27    38  *******************
  51    2023-08-25 03:26    36  *****************
  52    2023-08-25 04:25    35  ****************
  53    2023-08-25 05:24    33  **************
  60    2023-08-25 12:17    33  **************
  61    2023-08-25 13:16    36  *****************
  62    2023-08-25 14:15    37  ******************
  69    2023-08-25 21:08    37  ******************
  70    2023-08-25 22:07    38  *******************
  71    2023-08-25 23:06    40  *********************
  72    2023-08-26 00:05    39  ********************
  73    2023-08-26 01:04    39  ********************
  74    2023-08-26 02:03    37  ******************
 ...    ..( 11 skipped).    ..  ******************
  86    2023-08-26 13:51    37  ******************
SCT Error Recovery Control:
           Read:    100 (10.0 seconds)
          Write:    100 (10.0 seconds)
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 1) ==
0x01  0x008  4               3  ---  Lifetime Power-On Resets
0x01  0x010  4             206  ---  Power-on Hours
0x01  0x018  6      4624421064  ---  Logical Sectors Written
0x01  0x020  6        11030273  ---  Number of Write Commands
0x01  0x028  6       766046233  ---  Logical Sectors Read
0x01  0x030  6         1830814  ---  Number of Read Commands
0x01  0x038  6               -  ---  Date and Time TimeStamp
0x03  =====  =               =  ===  == Rotating Media Statistics (rev 1) ==
0x03  0x008  4             206  ---  Spindle Motor Power-on Hours
0x03  0x010  4             197  ---  Head Flying Hours
0x03  0x018  4             185  ---  Head Load Events
0x03  0x020  4               0  ---  Number of Reallocated Logical Sectors
0x03  0x028  4               0  ---  Read Recovery Attempts
0x03  0x030  4               0  ---  Number of Mechanical Start Failures
0x03  0x038  4               5  ---  Number of Realloc. Candidate Logical Sectors
0x03  0x040  4               3  ---  Number of High Priority Unload Events
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4               0  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4               0  ---  Resets Between Cmd Acceptance and Completion
0x04  0x018  4               0  -D-  Physical Element Status Changed
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              38  ---  Current Temperature
0x05  0x010  1              36  ---  Average Short Term Temperature
0x05  0x018  1               -  ---  Average Long Term Temperature
0x05  0x020  1              43  ---  Highest Temperature
0x05  0x028  1              30  ---  Lowest Temperature
0x05  0x030  1              42  ---  Highest Average Short Term Temperature
0x05  0x038  1              36  ---  Lowest Average Short Term Temperature
0x05  0x040  1               -  ---  Highest Average Long Term Temperature
0x05  0x048  1               -  ---  Lowest Average Long Term Temperature
0x05  0x050  4               0  ---  Time in Over-Temperature
0x05  0x058  1              60  ---  Specified Maximum Operating Temperature
0x05  0x060  4               0  ---  Time in Under-Temperature
0x05  0x068  1               5  ---  Specified Minimum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4               1  ---  Number of Hardware Resets
0x06  0x010  4               0  ---  Number of ASR Events
0x06  0x018  4               0  ---  Number of Interface CRC Errors
0xff  =====  =               =  ===  == Vendor Specific Statistics (rev 1) ==
0xff  0x008  7               0  ---  Vendor Specific
0xff  0x010  7               0  ---  Vendor Specific
0xff  0x018  7               0  ---  Vendor Specific
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
Pending Defects log (GP Log 0x0c)
Index                LBA    Hours
    0         5258602744      173
    1         5306213280      174
    2         5321671216      174
    3         5735760040      182
    4         5739153016      182
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x000a  2            2  Device-to-host register FISes sent due to a COMRESET
0x0001  2            0  Command failed due to ICRC error
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
I probably wouldn't replace a disk based on bad sectors in the single digits, but this is a definite reason to replace, and should readily warrant a warranty replacement.
joeschmuck
Old Man
Replace your drive ! It has failed. @danb35 is of course correct, this is a hard failure and there is no getting around this. This is why I asked for a SMART Long test.
My advice, run a SAMRT Long Test on any of your refurbished drives once a week and a daily SMART Short Test. Actually that is what I advice people anyway but you might not do that. Keep an eye on those other drives, ensure you know when the warranty expires.
I tend to watch the decoded data:
(an unreadable sector is concerning, but it happens; more failures in frequent succession is an issue)
This is concerning, it should be at 100, it's at 84, 44 is EOL. This I'd concern myself with if it gets worse.
That's also not good (72, should be 100).
Low temperature might prolong drive life, and the rest looks good.
I'd keep an eye on it and have a backup drive ready to replace it if it fails. If it's under warranty I'd send them the S.M.A.R.T. info and see if they'll cover a replacement drive.
joeschmuck
Old Man
This value is not yet reliable, however you can use this as an indicator. The paper suggests that any value 55 or below warrants attention. I have attached two papers which discusses the Seagate SMART Attributes. The best way, in my opinion, to see if you have any real errors is the take the RAW value and divide it by #FFFFFFFF (4294967295), the whole number is the total number of actual errors. Example: Raw = 13884901885 / 4294967295 = 3.23 = 3 Errors. This goes for Seek Error Rates as well.
Here is a link to a great explanation as well which I ran across years ago. I like the way it explains the VALUE number and what it means.
  • SMART_attrib_spec.pdf
  • Normal_SATA_SMART_attrib_behaviour.pdf
g4m3r7ag
Thank you all, I have reached out to the seller, I don't expect to hear from them until Monday though. Hopefully they will warranty the drive. I have also changed my SMART schedules, I had a short once per week and long once per month, I have changed it to daily short and long once per week.
g4m3r7ag
After my reply last night a scrub ran, and then a SMART Long on every drive, the drive in question faulted at that point and a hot spare took over. Resilver went much faster then I would have expected with 20TB drives and 60TB of data and only took ~4 hours. Hopefully the seller will warranty it when I hear from them next week, if not it is under warranty from Seagate still until December according to their warranty check. Thank you for the help everyone.
