mijki
- Jan 27, 2023
Hello guys,
I spend some hours searching on the web and reading articles and different forums about Home Servers and I think I would like to build one by myself. I don't really like the idea of Synology or QNAP because of their restrictions. I tried to create some configurations for myself and I want to ask your help with choosing one. I wanted them to be future-proof and expandable in the future.
My main usage will be:
And one for a bit more money, I called that "Medior":
Just some notes:
Please feel free to critique my configs and add recommendations to be better, every help is thanked.
And thank you in advance!
- TrueNAS Scale with accessible from the internet (maybe in a VM in Proxmox or ESXi?), I would use that to store private data and the data of my research group (this is why it should be reachable from the internet). I want to use Traefix or Nginx and Cloudflare for security and Next Cloud for Access on different devices (laptops, mobile, etc.)
- Running my own website/web app --> this could run in a separate VM
- VM with Windows 11 to run different simulations (like electrical grid current flow) on Win environment
- Maybe some Plex/Jellyfin server in the future for 4-5 people
Part list | Intel | Ryzen |
Case | Fractal Design Node 304 | Fractal Design Node 304 |
Supply | EVGA SuperNOVA 550 GM SFX+ATX | EVGA SuperNOVA 550 GM SFX+ATX |
Motherboard | MSI B560M PRO-VDH | ASRock B550M Pro4 |
CPU | Intel Pentium Gold G6405 Dual-Core 4.1GHz | AMD Ryzen 3 4300G 4-Core 3.8GHz |
RAM | Kingston FURY Beast 16GB (2x8GB) DDR4 3200MHz | Kingston Server Premier DIMM 16GB, DDR4-2666 ( KSM26ED8/16HD) |
Cache storage | - | - |
Boot storage | Kingston A400 2.5 480GB SATA3 (2 pcs., mirrored) | Kingston A400 2.5 480GB SATA3 (2 pcs., mirrored) |
Storage | Seagate IronWolf 4TB SATA3 (ST4000VN006) (4pcs.) | Seagate IronWolf 4TB SATA3 (ST4000VN006) (4pcs.) |
Case | Fractal Design Node 804 | Fractal Design Node 804 |
Motherboard | B660M Steel Legend | ASRock B550M Pro4 |
CPU | Intel Core i3-12100 4-Core 3.30GHz LGA1700 | AMD Ryzen 5 4600G 6-Core 3.7GHz AM4 |
RAM | Kingston Server Premier DIMM 16GB, DDR4-2666 ( KSM26ED8/16HD) | Kingston Server Premier DIMM 16GB, DDR4-2666 ( KSM26ED8/16HD) |
Cache storage | Samsung 980 1TB M.2 PCIe | Samsung 980 1TB M.2 PCIe |
Boot storage | Samsung 870 QVO 2.5 1TB SATA3 (2 pcs., mirrored) | Samsung 870 QVO 2.5 1TB SATA3 (2 pcs., mirrored) |
Storage | Seagate IronWolf 4TB SATA3 (ST4000VN006) (4 - 8 pcs.) | Seagate IronWolf 4TB SATA3 (ST4000VN006) (4 - 8 pcs.) |
Just some notes:
- ASRock states on its website, these MoBos are working with ECC, but I want to show you guys first.
- I can leave mITX behind and get a Fractal Define if necessary.
- I would like to use the ECC if possible, but most of the server MoBos are too expensive.
- I read here that, if I want proper ECC with Ryzen, I should get one without APU or a PRO G version.
