First build validation...
Martial
Anybody can look at this build, and advice me?
AMD Ryzen 5 5600X​
ASUS ROG Strix B550-I Gaming AMD AM4​
Kingston 32GB DDR4 3200Mhz CL22 2Rx8 ECC Unbuffered Memory RAM DIMM Module - KSM32ED8/32ME​
Western Digital 6TB x3​
SAMSUNG 980 PRO SSD 1TB​
EVGA SuperNOVA 650 GM​
Thank you in advance ^_^
Dice
LarsR
5600x possibly wont boot without a gpu and may not be supported in core, maybe look at scale because it's debian based with broader hardware support.
B550 Board use realtek nics which are trash look at board with integrated intel cards or an intel add-in card.
There may also be some bios settings that need to be changed to get the system stable.
If possible dont go for gaming gear, for the mainboard look for asrock rack boards.
Martial
it will boot
#Intel® I225-V 2.5Gb Ethernet
Linus Tech Tips
I think they used it without problems.
Any feedback please,
i'm ready to buy it, but i want to be sure.
Thank you
LarsR
i've started with a 1600x and right now im on a 3700x and both cpu's wouldnt boot without a gpu, but ymmv.
Furthermore the support for 2.5Gb lan isnt the best on truenas. some got it working, others did not, again ymmv.
Martial
THA
thank you very much
pixelwave
AMD Ryzen 5 5600X​
Did you get the 5600X running headless sucessfully? Is the 2.5Gb Ethernet recognised?
I am thinking about a similar build - just with a mATX Board like the ASROCK X570M Pro4.
How is Freenas with AMD and ECC? I am thinking about deploying it on TrueNAS Scale .. I assume support is even better there since Linux-based?
pixelwave
