Wolfeman0101
- Jun 14, 2012
I made the change but pkg upgrade && pkg update doesn't find a new version.
When a port is available, it doesn't mean that the package maintainer has made the binary pkg available yet. There can be a few days or even a week of delay.I made the change but pkg upgrade && pkg update doesn't find a new version.
The current FreeBSD port has been updated to 4.5.2. The package should be available soon.
Ah ok thanks for the information.When a port is available, it doesn't mean that the package maintainer has made the binary pkg available yet. There can be a few days or even a week of delay.
From post #2:
One alternative is to use the Ports Collection, but it's honestly not worth it when it comes to something like this. Using the Ports Collection requires compiling (from source) every time there's a new version. You'll also need to dedicate 1 GB+ of data just to fetch all the files (Makefiles, patches, etc.) While it's possible to fetch just a single port via "svn", it can get a bit frustrating, since many times one application will require the presence of other applications or libraries.
Moral of the story: Best bet is to wait a few days or so for the binary pkg to be available.
I think it's because they can't tell what OS you are running just the version of qBittorrent.Web UI - apparent path traversal vulnerability · Issue #18618 · qbittorrent/qBittorrent
qBittorrent & operating system versions qBitTorrent version: 4.5.1 (latest stable as of today). Operating System: Windows 10, version 22H2. x64 architecture. What is the problem? I ran a Nessus vul...github.com
The vulnerability only affects Windows machines. Still sucks trackers are closing down support for these clients (If that is true, I haven't had any issues with any of my trackers so far).
Also if it is true, it sucks for SCALE users, since @truecharts froze updates for the month of March for their breaking changes update.
Rolling back might be an option, I have a seedbox running 4.39 using TL with no issues so far.
Nope.So no news bout this yet!!
Just got another tracker blocking this version...Nope.
Even the "latest" branch might take over a week for a port to be packaged up and made available in the binary pkg repository.
I remember there was a serious bug in yt-dlp (the bug was so bad that the application simply did not work anymore due to YouTube's recent changes.) It was swiftly fixed in version 2023-02-17, yet it took over a week for the binary pkg to be available.
EDIT: If you reaaaaaaaaally want it right now, you can build your own binary pkg using the Ports Collection. I just don't think it's worth it, since soon after you do this, it'll be available in the "latest" repository, anyways.
cd /usr/ports/net-p2p/qbittorrent/ && make install clean
Just wait.Just got another tracker blocking this version...
Thinking if downgradind is a easy option...
If you installed qbittorrent via the package and not the plugin and have upgraded over a few previous versions there is a way to down grade by installing a cached previous version. If it's the plugin then you'll just have to wait as others have pointed out.Just got another tracker blocking this version...
The port was upgraded a few days ago, the package is still not available.the package got updated and the issue is resolved.
FreshPorts -- net-p2p/qbittorrent: Bittorrent client using Qt6 and libtorrent-rasterbar
qBittorrent is the open source bittorrent client in C++/Qt that uses libtorrent-rasterbar. It aims to be a good alternative to all other bittorrent clients. qBittorrent is fast, stable and provides unicode support as well as many features. Features: - Well-integrated and extensible Search...www.freshports.org
it is updated, at least for FreeBSD13 amd64 arch, I just got it updated on my TrueNAS .The port was upgraded a few days ago, the package is still not available.
