amuzhaqi
- Aug 31, 2023
As the title says, I am unsure about the past settings to follow regarding setting up my system. I am new to this, so that I would appreciate some feedback.
These are the following configurations for my system.
13th Gen Intel(R) Core(TM) i5-13600K
64 GB of DDDR5 RAM
2 x 4TB SSD
2 x 2TB NVME
1 X 16TB HDD
My idea is to use the two SSDs as Data VDEVs, one of the NVMEs as the boot system, and another as a Cache.
The 16TB will be my backup drive. I want to make sure what the best action would be to set up my system. The main usage of this system will be to store all my family pictures and have about a dozen docker applications running in the background.
Should I set up the data pool disks as MIRROR or STRIPE since I will have a backup? What is my best approach to go about this? I want to add that I might add more SSD drives in the future to extend the data size.
64 GB of DDDR5 RAM
2 x 4TB SSD
2 x 2TB NVME
1 X 16TB HDD
