Migrate to Mini X
rwfitzy
Hi. I'm planning to get a Mini X and migrate an old power sucking Dell 4U server. I haven't been in the Dell for years, it just sits on the rack running FreeNAS-9.2 to start and now TrueNAS-12.0-U8.1. I believe it's running on a couple of USB SATADOMs with 5 HDD. Could it be as easy as pulling the drives and putting in the Mini X, letting it import and show in storage?
Samuel Tai
Export your pool on the Dell first. Shutdown and pull the drives. Move the drives over to the Mini X, and then import the pool.
Davvo
Make sure to use 5900 or lower RPM disks since the Mini X's chassis can't properly manage the generated heat otherwise.
