Long (extended) offline self test failed [unsupported field in scsi command]
David Henrickson
I can run a short SMART test just fine, however, I do get the error when trying to run a long one via the gui. I can type in "smartctl -a /dev/da0" for all 8 disks and get a return INSTANTLY....but it doesn't actually do the test. What is the issue here? I have seen other forums post this, but came to find out they were SSD's....I dont have SSd's. These are rotational drives. I have listed what "smartctl -a /dev/de0" shows below. I am now running on a MBD-X11SPM-TF motherboard with a Gold 5215 CPU and 320Gb RAM on TrueNAS 13.0 Core.
Warning: the supported mechanisms for making configuration changes
are the TrueNAS WebUI and API exclusively. ALL OTHERS ARE
NOT SUPPORTED AND WILL RESULT IN UNDEFINED BEHAVIOR AND MAY
RESULT IN SYSTEM FAILURE.
root@truenas[~]# smartctl -a /dev/da0
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p7 amd64] (local build)
Vendor: HITACHI
Product: H0H72121CLAR12T0
Revision: Q3D0
Compliance: SPC-4
User Capacity: 12,000,138,625,024 bytes [12.0 TB]
Logical block size: 4096 bytes
LU is fully provisioned
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Logical Unit id: 0x5000cca25319a7fc
Serial number: 8DGG3DRH
Device type: disk
Transport protocol: SAS (SPL-3)
Local Time is: Thu Nov 2 12:10:43 2023 PDT
SMART support is: Enabled
Temperature Warning: Disabled or Not Supported
SMART Health Status: OK
Grown defects during certification = 0
Total blocks reassigned during format = 0
Total new blocks reassigned = 0
Power on minutes since format = 29216
Current Drive Temperature: 37 C
Drive Trip Temperature: 60 C
Accumulated power on time, hours:minutes 26608:38
Manufactured in week 49 of year 2017
Specified cycle count over device lifetime: 50000
Accumulated start-stop cycles: 112
Specified load-unload count over device lifetime: 600000
Accumulated load-unload cycles: 774
Elements in grown defect list: 0
Vendor (Seagate Cache) information
Blocks sent to initiator = 12153047899701248
Error counter log:
Errors Corrected by Total Correction Gigabytes Total
ECC rereads/ errors algorithm processed uncorrected
fast | delayed rewrites corrected invocations [10^9 bytes] errors
read: 0 5 0 5 3227312 397176.690 0
write: 0 291 0 291 603463 467221.564 0
verify: 0 13 0 13 10348 80708.573 0
Non-medium error count: 0
SMART Self-test log
Num Test Status segment LifeTime LBA_first_err [SK ASC ASQ]
Description number (hours)
# 1 Background short Completed - 26583 - [- - -]
# 2 Background short Completed - 25277 - [- - -]
# 3 Background short Completed - 23813 - [- - -]
# 4 Background short Completed - 22349 - [- - -]
# 5 Background short Completed - 20885 - [- - -]
# 6 Background short Completed - 19421 - [- - -]
# 7 Background short Completed - 17957 - [- - -]
# 8 Background short Completed - 16494 - [- - -]
# 9 Background short Completed - 15030 - [- - -]
#10 Background short Completed - 12486 - [- - -]
#11 Background short Completed - 11022 - [- - -]
#12 Background short Completed - 9581 - [- - -]
#13 Background short Completed - 8141 - [- - -]
#14 Background short Completed - 6701 - [- - -]
#15 Background short Completed - 5261 - [- - -]
#16 Background short Completed - 3821 - [- - -]
#17 Reserved(3) Completed - 2359 - [- - -]
#18 Reserved(3) Completed - 2359 - [- - -]
NugentS
You need to run
smartctl -t long /dev/da0 to run a long test. -a just gives you results
joeschmuck
Old Man
You definitely do not have routine SMART tests setup. I recommend a daily SMART Short test and a once a week SMART Long test if that is reasonable for you.
David Henrickson
I plan on doing the setup for the SMART tests that way, as I have that setup for my home labs, however, it still will not let me do a manual or set LONG test. That is the issue here. Still says unsupported field in iscsi command if done in shell or done by GUI
David Henrickson
You need to run
I still get the same error doing it through Shell with this. States unsupported field in iSCSI command
Davvo
Are you virtualizing? How are the drives connected to the motherboard?
Iirc it's a drives' firmware bug, and you possibily need to update it.
David Henrickson
Currently, they are in a NODE 804 case with (8) hard drives just directly connected to the 9300-8i LSI card. No virtualizing....I know the rules. haha
joeschmuck
Old Man
Try this command and post here the exact output so we can see.
smartctl -r ioctl -t long /dev/da0
Also, what firmware is on your 9300-8i LSI card? Please note that I'm not the guru on LSI cards, if the firmware is not correct, this could be causing issues.
oldhome7
I'm having this same issue and this is the output I get
 [inquiry: 12 00 00 00 24 00 ]
  CAM status=0x1, SCSI status=0x0, resid=0x0
  status=0x0
 [inquiry: 12 01 00 00 fc 00 ]
  CAM status=0x1, SCSI status=0x0, resid=0xe6
  status=0x0
  status=0x0
 [request sense: 03 00 00 00 12 00 ]
  status=0x0
 [send diagnostic: 1d 40 00 00 00 00 ]
  CAM status=0x8c, SCSI status=0x2, resid=0x0
  sense_len=0x20, sense_resid=0x0
  status=0x2: [desc] sense_key=0x5 asc=0x24 ascq=0x0
The pool is 8x 8TB HGST drives
Vendor:               HITACHI
Product:              HUH72808CLAR8000
Revision:             M7K0
Compliance:           SPC-4
User Capacity:        8,001,563,222,016 bytes [8.00 TB]
Logical Unit id:      0x5000cca261035e30
Serial number:        VJG1VE0X
Device type:          disk
Local Time is:        Sat Nov  4 16:44:16 2023 CDT
SMART support is:     Available - device has SMART capability.
The controller is a 9217-4i4e crossflashed to 9207-4i4e with these drives attached to the external port.
joeschmuck
Old Man
Please list the exact firmware version information. I still suspect the card does not have the correct firmware on it.
See this posting, it may help you understand what we are discussing. And again, I'm not the LSI guru so I'm uncomfortable telling you what to do to fix the problem. But first generate the output like the link has of your controller, I still suspect it is the issue.
oldhome7
        Adapter Selected is a LSI SAS: SAS2308_2(D1)
Num   Ctlr            FW Ver        NVDATA        x86-BI
       PCI Addr
0  SAS2308_2(D1)   20.00.07.00    14.01.00.06    07.39.0
     00:01:00:00
        Finished Processing Commands Successfully.
        Exiting SAS2Flash.
oldhome7
I see my copy and paste didn't quite grab everything, disadvantage of trying it on the phone. That should say x86-BIOS and 07.39.02.00. The rest looks okay.
joeschmuck
Old Man
How do we know it's in IT Mode?
oldhome7
      Controller Number              : 0
      Controller                     : SAS2308_2(D1)
      PCI Address                    : 00:01:00:00
      SAS Address                    : 500605b-0-0b4a-a160
      NVDATA Version (Default)       : 14.01.00.06
      NVDATA Version (Persistent)    : 14.01.00.06
      Firmware Product ID            : 0x2214 (IT)
      Firmware Version               : 20.00.07.00
      NVDATA Vendor                  : LSI
      NVDATA Product ID              : SAS9207-4i4e
      BIOS Version                   : 07.39.02.00
      UEFI BSD Version               : N/A
      FCODE Version                  : N/A
      Board Name                     : SAS9217-4i4e
      Board Assembly                 : 03-25597-01B
      Board Tracer Number            : SV54564825
      Exiting SAS2Flash.
I did the flash myself, on a batch of these actually, and verified after I had done it.
David Henrickson
Hello.....looks like someone else tried to hijack this post.....anyway, here you go!
root@truenas[~]# smartctl -r ioctl -t long /dev/da0
status=0x0
status=0x0
status=0x0
status=0x0
root@truenas[~]#
David Henrickson
Also...here is my raid card information, as I see that was down the thread a little further for the other individual that joined this. Thank you!
its a LSI 9300-8i fully updated.
root@truenas[~]# sas3flash -list
Avago Technologies SAS3 Flash Utility
Version 16.00.00.00 (2017.05.02)
Copyright 2008-2017 Avago Technologies. All rights reserved.
Adapter Selected is a Avago SAS: SAS3008(C0)
Controller : SAS3008(C0)
PCI Address : 00:b6:00:00
SAS Address : 5003048-0-1a6f-b201
NVDATA Version (Default) : 0e.01.00.07
NVDATA Version (Persistent) : 0e.01.00.07
Firmware Product ID : 0x2221 (IT)
Firmware Version : 16.00.01.00
NVDATA Vendor : LSI
NVDATA Product ID : SAS9300-8i
BIOS Version : 08.37.00.00
UEFI BSD Version : 18.00.00.00
FCODE Version : N/A
Board Name : LSI3008-IT
Board Assembly : N/A
Board Tracer Number : N/A
Exiting SAS3Flash.
root@truenas[~]#
oldhome7
Sorry for the hijacking, but it does seem that our ioctl outputs are the same so maybe it's the same issue and we can get this sorted together?
joeschmuck
Old Man
So I will say this again, I don't have the required knowledge to help out in this situation. Hopefully someone else will come to the rescue.
oldhome7
Maybe there's enough info in here for somebody to help. Clearly it's not card specific as I'm using a SAS2308 and David has a SAS3008.
Davvo
It's not an issue related to the HBAs. I recall quite a few threads about HGST drives having this issue. @isopropyl knows, it's a big PIAS.
