I would appreciate a check over of the following components I am hoping to put together to consolidate all my storage into one large quiet server. Currently I just have a large number of seperate hard drives either in storage or in external cases. The usage I am considering is mostly simple file storage and serving to 1 or 2 clients over SMB. I would also run Sabnzbd, CouchPotato, Headphones, torrent client, and podcast downloader. I don't currently plan on running PLEX but I guess I might in the future. Components I am considering are the following.
Are there any gotchas, conflicts, or things I am missing.
Which CPU would you recommend?
Motherboard: X10SLM+-F (LGA 1150) [Used]
CPU: i3-4160, or i3-4170, or i3-4340, or E3-1220 v3, or E3-1231 v3
CPU Fan: Noctua NH-U9DXi4 or Cooler Master Hyper 212
Memory: 4 x Samsung M391B5273DH0-CK0 (4GB DDR3 ECC PC3-12800 CL11 Unbuffered UDIMM) or Hynix HMT451U7BFR8A-PB 4GB DDR3 ECC PC3-12800 CL11 1.35V Unbuffered UDIMM) [Used]
Boot Drive: 1 x Samsung 860 EVO 250 GB
HBA: LSI 9210-8i in IT mode [Used]
Case: Supermicro SC846 [Used]
Backplane: BPN-SAS2-846EL1 [Used]
Power Supply: 2 x Supermicro PWS-920P-SQ [Used]
Fan Wall Replacement Fans: Noctua NF-F12 iPPC 3000 PWM
Rear Wall Replacement Fans: Noctua NF-R8 PWM
Cable from HBA to Expander: SFF-8087 to SFF-8087 connector
