Jailer
Not strong, but bad
- Sep 12, 2014
From the jail cli:Hey Jailer,
Can you detail out the steps here?
First you need to download the ports tree and extract them
portsnap fetch extractAfter that add the following to /etc/mke.conf
echo 'DEFAULT_VERSIONS+=ssl=openssl' >> /etc/make.confNext uninstall openssl and nginx
pkg delete openssl pkg delete nginxOnce they have been uninstalled re install each starting with openssl.
cd /usr/ports/security/openssl/ && make install cleanOnce that's completed install nginx
cd /usr/ports/www/nginx/ && make install cleanAfter they have installed restart nginx
service nginx restartNow go check your results at SSL Labs server test to check the results.
Once you've got all that set you'll need to lock the 2 packages that you installed from ports. If you don't the next time you do a
pkg upgrade you'll overwrite the ports version with the package install. To do this just run pkg lock name_of_package and it won't be upgraded until you unlock it.To keep everythign up to date you will need to manage the packages and ports seperately. Packages are managed with the package manger. To manage the ports you have a couple options. I install the portmaster package to manage my ports but you can install what works for you.
Your workflow for updates will go as follows:
pkg upgradeand upgrade all your packages.pkg unlock name_of_packageand unlock nginx and opensslportsnap fetch updateto update the ports treeportmaster -ato check your packages and install available updatespkg lock name_of_packageto lock nginx and openssl after updates are installed
Can you provide the relevant section in your conf file also?
server {
listen 443 ssl;
server_name www.boredguy.showersnet.com boredguy.showersnet.com;
root /usr/local/www/nginx;
ssl_session_cache shared:SSL:10m;
ssl_session_timeout 10m;
ssl_ciphers HIGH:!aNULL:!MD5;
ssl_prefer_server_ciphers on;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_certificate /usr/local/etc/letsencrypt/live/boredguy.showersnet.com/fullchain.pem;
ssl_certificate_key /usr/local/etc/letsencrypt/live/boredguy.showersnet.com/privkey.pem;
ssl_stapling on;
ssl_stapling_verify on;
ssl_dhparam /usr/local/etc/nginx/dhparams.pem;
add_header Strict-Transport-Security "max-age=31536000; includeSubDomains; preload";
