[How-To] ownCloud using NGINX, PHP-FPM, and MySQL
Mad_noob
My router is pure crap.
If the workaround i linked above isn't working for me, the only way is to change my router...
I don't have the time to do it right now, but as soon as i can will do it to try.
Joshua Parker Ruehlig
lol, yeah. Most people in the US have a cable provided modem/router combo, which is terrible.
For all my family members I switched them to a customer own modem + pfsense or ddwrt router.
Dwight Turner
was the jail created a standard jail or a plugin jail? ( i created a standard jail)
also followed the guide however I can not access using jail ip (which it doesn't show up in the plugin list)
why would it show on the plugin list if you setup a standard jail, and therefore it's not a plugin?
whatn error do you get when trying to access the jail IP?
Dwight Turner
502 Bad Gateway
nginx/1.10.1
using my jail ip http://192.168.1.3/owncloud
rechecked all the settings and everything is there as far as I know
using this to access it as per my jail ip address
Even restarted the php-fpm and nginx services and there are no errors.
502 Bad Gateway
nginx/1.10.1
Does 'sockstat' show you where php-fpm is listening?
Dwight Turner
www php-fpm 85398 0 stream /var/run/php-fpm.sock
www php-fpm 85397 0 stream /var/run/php-fpm.sock
root php-fpm 85396 10 stream -> ??
root php-fpm 85396 13 stream -> ??
root php-fpm 85396 14 stream /var/run/php-fpm.sock
Josh does this help? its the only php-fpm port info
Dwight Turner
yea getting a 404 not found error
does the URL require a port after it like the other plugins i run? (i.e. sickrage, CP, Sab headphones , etc)
you're nginx config is not correct then. no port necessary
Dwight Turner
ill keep digging
thnaks
hmm, another thought. maybe you didn't unpack/copy the files correctly.
Your owncloud source files should exist in /usr/local/www/owncloud
Dwight Turner
odd
when i go into /usr/local/www there isn't an owncloud directory
Dwight Turner
NM scratch that
its all correct i was just sshed into the root of freenas and not the jail (DOH)!
I been looking at it too long i guess
NM scratch that
ok, if the file exists, but you're getting a 404, suggests your nginx config is incorrect.
Dwight Turner
i feel stupid
the lines in php-fpm.conf were not uncommented ! ( ; )
sorry for posting so many times on me not following the directions!
pulls up the web page now
i feel stupid
yeah, that one hits people alot
Dwight Turner
make /usr/ports/www/nginx install
how do you select the options when the installer comes up?
usually they come up, I'd never being set. but you can always 'make config' to change them
Dwight Turner
thanks
how to select and deselect?key command ?
