Jailer
Not strong, but bad
- Sep 12, 2014
by default the my.cnf doesn't exist, so yes create it.
service nginx start && service php-fpm start && service mysql-server start
Shared object "libiconv.so.2" not found, required by "php-fpm" /usr/local/etc/rc.d/php-fpm: WARNING: failed to start php_fpm
the packages with the jail get out of date.Ok ran the first lineCode:service nginx start && service php-fpm start && service mysql-server start
And I get this error
Code:Shared object "libiconv.so.2" not found, required by "php-fpm" /usr/local/etc/rc.d/php-fpm: WARNING: failed to start php_fpm
I swear to god I'm about to give up on this.
pkg upgrade
is php running?And now 502 bad gateway. :(
service php-fpm status
ls -l /var/run/php-fpm.sock
you ran that on your host!? only run these commands in the jail, unless specified.I get this
Code:php-fpm does not exist in /etc/rc.d or the local startup directories (/etc/ix.rc.d /usr/local/etc/rc.d)
hmm strange. you should have installed php-fpm when you installed php56No it was run in the jail
pkg install nginx mariadb55-server php56-extensions php56-curl php56-exif php56-fileinfo php56-gd php56-mbstring php56-pdo_mysql php56-openssl php56-zip php56-zlib
if so did you set the listen address in the php-fpm.conf
Code:ls -l /var/run/php-fpm.sock
listen = /var/run/php-fpm.sock
If you set this, you obviously had php-fpm installed at one point (its an included extension of php56). that's why im surprised the script is gone from /usr/local/etc/rc.dNo I set to what you had listed in the tutorial
Code:listen = /var/run/php-fpm.sock
root@owncloud:/ # service php-fpm start Starting php_fpm. [14-Jan-2015 20:41:06] ERROR: unable to bind listening socket for address '/usr/local/ls -l /var/run/php-fpm.sock': No such file or directory (2) [14-Jan-2015 20:41:06] ERROR: FPM initialization failed /usr/local/etc/rc.d/php-fpm: WARNING: failed to start php_fpm
there was a misunderstanding earlier.OK I lied. This is what I get now when I try to start the service
Code:root@owncloud:/ # service php-fpm start Starting php_fpm. [14-Jan-2015 20:41:06] ERROR: unable to bind listening socket for address '/usr/local/ls -l /var/run/php-fpm.sock': No such file or directory (2) [14-Jan-2015 20:41:06] ERROR: FPM initialization failed /usr/local/etc/rc.d/php-fpm: WARNING: failed to start php_fpm
that socket should be owned by www, check you uncommented the 'listen.owner' lines in php-fpm.confphp-fpm is running now but I still get the bad gateway error
output from the command is
Code:srw-rw---- 1 root wheel 0 Jan 14 20:56 /var/run/php-fpm.sock
No problem, glad you got through it.FINALLY! It's up.I didn't uncomment the lines in the php-fpm.conf file.
Sorry for all the trouble I've caused for being a noob.
Try this. Then run, "service nginx reload"
Code:worker_processes 2; events { worker_connections 1024; } http { include mime.types; default_type application/octet-stream; log_format main '$remote_addr - $remote_user [$time_local] "$request" ' access_log logs/access.log main; sendfile off; #keepalive_timeout 0; keepalive_timeout 65; gzip off; server { root /usr/local/www/owncloud; location = /robots.txt { allow all; access_log off; log_not_found off; } location = /favicon.ico { access_log off; log_not_found off; } index index.php; try_files $uri $uri/ /index.php$is_args$args; client_max_body_size 512M; location ~ ^/(?:\.|data|config|db_structure\.xml|README) { deny all; } location ~ \.php(?:$|/) { fastcgi_split_path_info ^(.+\.php)(/.*)$; fastcgi_pass unix:/var/run/php-fpm.sock; fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name; fastcgi_param PATH_INFO $fastcgi_path_info; include fastcgi_params; fastcgi_param MOD_X_ACCEL_REDIRECT_ENABLED on; } location ~* \.(?:jpg|gif|ico|png|css|js|svg)$ { expires 30d; add_header Cache-Control public; } location ^~ /data { internal; alias /mnt/files; } } }
