Best to start your own topic on that instead of cluttering up this thread. Permissions are an entirely different subject than the Nextcloud install.TY so much.... I knew I was missing something. now I have to figure out the permissions. any advice
root@nextcloud:~ # service apache24 restart Performing sanity check on apache24 configuration: WARNING: number of probes fixed does not match the number of defined probes (12 != 13, respectively) WARNING: some probes might not fire or your program might crash [Tue Jan 10 08:30:41.061213 2017] [so:warn] [pid 69250] AH01574: module php7_module is already loaded, skipping httpd: Syntax error on line 543 of /usr/local/etc/apache24/httpd.conf: Syntax error on line 13 of /usr/local/etc/apache24/Includes/cloud.alleghenyvascular.com.conf: Expected </Directory> but saw </IfModule>
apps directory not found! Please put the Nextcloud apps folder in the Nextcloud folder or the folder above. You can also configure the location in the config.php file.
, I get the following warnings (3 times): WARNING: number of probes fixed does not match the number of defined probes (12 != 13, respectively)
LoadModule php7_module libexec/apache24/libphp7.so
, from httpd.conf, the warnings go away. Anyone know what's up? upload_max_size
. I did, however, see upload_max_filesize = 2M
. Is that the correct one to modify?port moved to databases/pecl-redis on 2017-02-15
REASON: Merged with latest codebase that supports all php versions
15 Feb 2017 14:57:37
Add pecl-redis 3.1.1 (copied from php56-redis and updated to 3.1.1)
- Remove databases/php56-redis, databases/php70-redis and databases/php71-redis
- Add MOVED entries
- While I'm here, add LICENSE_FILE
Changes: https://pecl.php.net/package-changelog.php?package=redis
PR: 216700
Submitted by: Daniel Ylitalo <daniel@blodan.se> (maintainer of
databases/php71-redis)
Approved by: Mikhail Tsatsenko <m.tsatsenko@gmail.com> (maintainer of
databases/php56-redis),
Joshua Ruehlig <joshruehlig@gmail.com> (maintainer of databases/php70-redis,
timeout, 14 days)
su -m www -c 'php /usr/local/www/apache24/data/nextcloud/occ config:system:set memcache.local --value="\OC\Memcache\APCu"'
su -m www -c 'php /usr/local/www/apache24/data/nextcloud/occ config:system:delete memcache.local'
Port Moves
- port moved here from devel/php70-APCu on 2017-02-12
REASON: Use devel/pecl-APCu for PHP 7.0+ users
Yeah, I tried that, then it wanted to uninstall all of my php70 packages.Well you could try to install it. The port was moved. All the info is available at freshports.
https://www.freshports.org/devel/pecl-APCu/
Not necessarily. Nextcloud won't NEED those things to run. I think they're just used for caching to help improve performance. Though I could be wrong.so if understand correctly, until this will be clarified (php70-APCu php70-redis) this guide won't be successful of setting up freshly nextcloud?
Well, i do have limitted amount of resources, which i would like to reserve for other tasks, instead of spining up ubuntu server just for nextcloud.Not necessarily. Nextcloud won't NEED those things to run. I think they're just used for caching to help improve performance. Though I could be wrong.
Anyway, I abandoned the idea of doing this in a jailed/FreeBSD machine. I just spun up an Ubuntu Server VM and got everything setup there. It's much easier & there's a lot more documentation online for how to do it.
Correct. And unless you have many users connecting to your nextcloud instance you likely won't see any benefit from it.I think they're just used for caching to help improve performance. Though I could be wrong.
I have the same problem. Did anyone find a solution to this one?I'm having the same problem as the last 2 posters. there is no php70-APCu or php70-redis packages.
Also, when I doservice apache24 restart
When I comment out the line,LoadModule php7_module libexec/apache24/libphp7.so
AH00526: Syntax error on line 7 of /usr/local/etc/apache24/Includes/lgk.ddns.net.conf: Invalid command '[END,QSA,R=permanent]', perhaps misspelled or defined by a module not included in the server configuration
Made it trough here.Restart apache... again...
$ service apache24 restart
Navigate to the website
http://192.168.1.99/
You should now see the setup screen for NextCloud!!
# pkg install pecl-APCu Updating FreeBSD repository catalogue... FreeBSD repository is up to date. All repositories are up to date. pkg: No packages available to install matching 'pecl-APCu' have been found in the repositories
