Athers
- Jan 29, 2022
Hi All,
I dont seem to see this issue has been reported..
I use the excellent Danb35 scripted install of nextcloud. I wanted to go from 22 to 23 due to the apparent enhanced performance with file uploads. Nextcloud 22 was working fine using the said script when 22 was the latest, however backed up files so went for a fresh install.
Followed same process which passed fine before, however now I am greeted with the following in the post install script: -
An unhandled exception has been thrown:
OCP\HintException: [0]: Memcache \OC\Memcache\APCu not available for local cache (Is the matching PHP module installed and enabled?)
Command: su -m www -c php /usr/local/www/nextcloud/occ config:system:set redis host --value="/var/run/redis/redis.sock" failed!
Command: su -m www -c php /usr/local/www/nextcloud/occ config:system:set redis port --value=0 --type=integer failed!
Command: su -m www -c php /usr/local/www/nextcloud/occ config:system:set memcache.distributed --value="\OC\Memcache\Redis" failed!
Command: su -m www -c php /usr/local/www/nextcloud/occ config:system:set memcache.locking --value="\OC\Memcache\Redis" failed!
Command: su -m www -c php /usr/local/www/nextcloud/occ config:system:set overwritehost --value="hidden.co.uk" failed!
Command: su -m www -c php /usr/local/www/nextcloud/occ config:system:set overwrite.cli.url --value="https://hidden.co.uk/" failed!
Command: su -m www -c php /usr/local/www/nextcloud/occ config:system:set overwriteprotocol --value="https" failed!
Command: su -m www -c php /usr/local/www/nextcloud/occ config:system:set htaccess.RewriteBase --value="/" failed!
Command: su -m www -c php /usr/local/www/nextcloud/occ maintenance:update:htaccess failed!
Command: su -m www -c php /usr/local/www/nextcloud/occ config:system:set trusted_domains 1 --value="hidden.co.uk" failed!
Command: su -m www -c php /usr/local/www/nextcloud/occ config:system:set trusted_domains 2 --value="192.168.1.100" failed!
Command: su -m www -c php /usr/local/www/nextcloud/occ background:cron failed!
Understandably I am then greeted with the: -
"Access through untrusted domain Please contact your administrator. If you are an administrator, edit the "trusted_domains" setting in config/config.php like the example in config.sample.php. Further information how to configure this can be found in the documentation"
So I added the domain and Ip to the trusted domains in the config, just to see if this resolved, however it did not. I am then greeted with:
Internal Server Error
The server encountered an internal error and was unable to complete your request.
Please contact the server administrator if this error reappears multiple times, please include the technical details below in your report.
More details can be found in the webserver log."
Any help appreciated thanks
