Nextcloud in maintance after update
Leonard Lassen
Hello, everybody.
I have in Truenas a Nextcloud plugin running which I wanted to update via the GUI. NAch the update I had to macehn the update also in the browser. However, an error occurred, on which Nextcloud went into maintenance mode and I get them from this with update also not merh out.
the following I have already tried. But to no avail. Can someone tell me exactly what to do or what the problem is?
iocage console nextcloud
cd /usr/local/www/nextcloud
su -m www -c "/usr/local/bin/php occ maintenance:mode --off"
and then the update cmd
su -m www -c "/usr/local/bin/php occ upgrade"
after that i get the following
root@nextcloud:/usr/local/www/nextcloud # su -m www -c "/usr/local/bin/php occ upgrade"
PHP Fatal error:  Allowed memory size of 536870912 bytes exhausted (tried to allocate 528384 bytes) in /usr/local/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php on line 133
best regards Leonard
Patrick M. Hausen
Try increasing the memory_limit parameter in /usr/local/etc/php.ini.
Leonard Lassen
Do you mean this?
