Hi
I've had a few issues with setting up the plex container, I've followed the guide as follows
Ports set to 32400, TZ set to GB, PLEX_CLAIM set to nothing, Networking on Host mode, and the volumes as follows -
/media/VMRoot/VMDocker/Docker_Configs/Plex-A1/config/:/config
/media/VMRoot/VMDocker/Docker_Configs/Plex-A1/transcode/:/transcode
I've left the data volume un-mapped as I want to get it all working first
I only get this issue when I add the volumes, when i leave them all blank it works perfectly. Here is what I get in the logs when I do add the volumes -
28/06/2018 22:32:26[services.d] done.
28/06/2018 22:32:26Starting Plex Media Server.
28/06/2018 22:32:26terminate called after throwing an instance of 'boost::filesystem::filesystem_error'
28/06/2018 22:32:26  what():  boost::filesystem::create_directory: Permission denied: "/config/Library/Application Support/Plex Media Server/Logs"
28/06/2018 22:32:26****** PLEX MEDIA SERVER CRASHED, CRASH REPORT WRITTEN: /config/Library/Application Support/Plex Media Server/Crash Reports/1.13.2.5154-fd05be322/PLEX MEDIA SERVER/215000c1-ba32-c6d1-69812f4e-4ef86ccf.dmp
28/06/2018 22:32:26Aborted
The volumes are all set with the permissions 777 so I'm not 100% sure why this is happening, I've also tried this same setup and added PUID and PGID to the parameters and used the IDs of the user and group which own the config and transcode directory. Any ideas what Im doing wrong here
Thanks!
