First of all, hi all! This is my first message here.
Like many I have been rather attracted by the Docker possibilities of Corral and the cold shower has been hard. Moreover this is happening at the moment I have to setup home & professional servers and I wanted to use Docker for applications. So I insisted a bit and ended up with a setup based on Rancher & RancherOS which I now found very satisfying. Because it sounds like there is a lot of people around struggling with setting this thing up, I thought I should write something here to help. This is an example on how to setup a Plex server as a container in Rancher running under a RancherOS VM. I used this procedure successfully with two different machines on two very different networks.
The full guide can be found in this Resource's page, accessible via the tabs above and to the left of this post.
