Help with SMART results
samuyeah
Hello everyone,
This week I received a critical alert because of an "unrecoverable error in one or more devices": http://illumos.org/msg/ZFS-8000-9P
After a scrub, ada1 showed 11 checksum errors so I ran a long SMART test. These are the results:
# smartctl -a /dev/ada1
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:	 Western Digital Caviar Green (AF)
Device Model:	 WDC WD20EARS-00J99B0
Serial Number:	WD-WCAWZ1677837
LU WWN Device Id: 5 0014ee 25bc3d884
Firmware Version: 80.00A80
User Capacity:	2,000,398,934,016 bytes [2.00 TB]
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ATA8-ACS (minor revision not indicated)
SATA Version is:  SATA 2.6, 3.0 Gb/s
Local Time is:	Tue Jun  6 07:27:20 2017 CEST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x85) Offline data collection activity
										was aborted by an interrupting command from host.
Self-test execution status:	  (   0) The previous self-test routine completed
										been run.
data collection:				(33900) seconds.
capabilities:					(0x7b) SMART execute Offline immediate.
										command.
										Self-test supported.
SMART capabilities:			(0x0003) Saves SMART data before entering
										power-saving mode.
Error logging capability:		(0x01) Error logging supported.
Short self-test routine
recommended polling time:		(   2) minutes.
Extended self-test routine
recommended polling time:		( 327) minutes.
Conveyance self-test routine
recommended polling time:		(   5) minutes.
SCT capabilities:			  (0x3035) SCT Status supported.
										SCT Data Table supported.
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x002f   200   200   051	Pre-fail  Always	   -	   98
  3 Spin_Up_Time			0x0027   144   139   021	Pre-fail  Always	   -	   9800
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   830
  5 Reallocated_Sector_Ct   0x0033   200   200   140	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x002e   200   200   000	Old_age   Always	   -	   0
  9 Power_On_Hours		  0x0032   093   093   000	Old_age   Always	   -	   5285
10 Spin_Retry_Count		0x0032   100   100   000	Old_age   Always	   -	   0
11 Calibration_Retry_Count 0x0032   100   100   000	Old_age   Always	   -	   0
12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   429
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   172
193 Load_Cycle_Count		0x0032   108   108   000	Old_age   Always	   -	   276579
194 Temperature_Celsius	 0x0022   114   095   000	Old_age   Always	   -	   38
196 Reallocated_Event_Count 0x0032   200   200   000	Old_age   Always	   -	   0
197 Current_Pending_Sector  0x0032   200   200   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0030   200   200   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x0032   200   200   000	Old_age   Always	   -	   0
200 Multi_Zone_Error_Rate   0x0008   200   200   000	Old_age   Offline	  -	   3
SMART Error Log Version: 1
No Errors Logged
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline	Completed: read failure	   70%	  5280		 1275044616
# 2  Short offline	   Completed without error	   00%	  5278		 -
# 3  Short offline	   Completed without error	   00%	  5268		 -
# 4  Short offline	   Completed: read failure	   90%	  5172		 12852030
# 5  Short offline	   Completed: read failure	   20%	  4963		 12852024
# 6  Short offline	   Completed without error	   00%	  4934		 -
# 7  Extended offline	Completed without error	   00%	  4932		 -
# 8  Short offline	   Completed without error	   00%	  4838		 -
# 9  Short offline	   Completed without error	   00%	  4742		 -
#10  Short offline	   Completed without error	   00%	  4646		 -
#11  Extended offline	Completed without error	   00%	  4597		 -
#12  Short offline	   Completed without error	   00%	  4550		 -
#13  Short offline	   Completed without error	   00%	  4454		 -
#14  Short offline	   Completed without error	   00%	  4382		 -
#15  Short offline	   Completed without error	   00%	  4287		 -
#16  Short offline	   Completed without error	   00%	  4191		 -
#17  Extended offline	Completed without error	   00%	  4189		 -
#18  Short offline	   Completed without error	   00%	  4165		 -
No Errors Logged
#19  Short offline	   Completed without error	   00%	  4069		 -
#20  Short offline	   Completed without error	   00%	  4001		 -
#21  Extended offline	Completed without error	   00%	  3952		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
Is it so serious doctor? Should I replace the disk ASAP?
Thanks in advance for all your kind support.
nojohnny101
samuyeah
You should check this resource that is designed to help you answer the very question you asked:
https://forums.freenas.org/index.ph...bleshooting-guide-all-versions-of-freenas.17/
Thanks johnny!
Not sure if I'm reading the log correctly but only thing I can see there is:
From the troubleshooting guide:
ID 200 MultiZone Error Rate can be the cause of a drive failure although a value in this location doesn't always mean it's the fault. It is notable if there are no other failing indications.
I'm trying to get a second opinion from anyone here with more experience and knowledge about this matter: what would you do in my situation?
CraigD
Do your drives get hot? Sometimes drives fail at extreme temperatures, then work fine once temperatures normalizes
Is the drive under warranty?
It has low hours, I didn't think WD still made 3.5" green drives guess I'm wrong
Look at "Lifetime Min/Max Temperature" Drives can play up in extreme temperatures, then come right in normal temperatures
[root@freenas] ~# smartctl -l scttemp /dev/ada1
SCT Status Version:  3
SCT Version (vendor specific):  258 (0x0102)
SCT Support Level:  1
Device State:  Active (0)
Current Temperature:  25 Celsius
Power Cycle Min/Max Temperature:  22/29 Celsius
Lifetime  Min/Max Temperature:  21/32 Celsius
Under/Over Temperature Limit Count:  0/0
Vendor specific:
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version:  2
Temperature Sampling Period:  1 minute
Temperature Logging Interval:  1 minute
Min/Max recommended Temperature:  0/60 Celsius
Min/Max Temperature Limit:  -41/85 Celsius
Temperature History Size (Index):  478 (366)
Have Fun
Stux
If the drive is in warranty, then RMA it.
samuyeah
Thanks Craig! Yes: my disks sometimes get too hot (above 40ºC) inside my Dell T20. I tried different things but air flow inside this case is very poor. I'll try to test the disk again under different conditions... anyway, rest of the disks (total = 4 x 2TB WD Green) also get as hot as that one but didn't received those kind of errors (yet).
My 2TB WD Green are already some years old in spite of their low hours :(
samuyeah
Just in case a disk replacement is needed: is WD NAS Red still the cheapest-reliable-favourite option in these forums?
Robert Trevellyan
Pony Wrangler
I don't worry about a drive in the bottom bay hovering a few degrees above 40C under load, e.g. during a scrub. Is it ideal? No, but it's well within acceptable limits.
tvsjr
I'll confess... my drives hover in the high 30s and hit low 40s under significant load (which is fairly often). I've not experienced issues as a result. Pushing 50 I'd worry about... but 40 is in the "meh" range in my book. I know the ZFS Police will get on me about this... probably take away my pony.
WD Red or HGST Deskstar NAS seem to be the favorites. I've been very happy with HGST drives, so I've stuck with them. They are 7200RPM drives, so they naturally run a bit hotter.
Stux
Seagate NAS drives tend to be cheaper. Jury is still out on if they are reliable or not.
I have 16 and they've been good so far ;)
