I built my first server a couple years ago thanks to the community here and everything's been great so far. Recently, I've experience my first alert regarding a HDD:
The smart data is:
I tried doing some research before posting but only found conflicting information and I'm not sure I entirely understand SMART and how it works. The red flag for me here was the multi_zone_error_rate incrementing to 1. When the alert first came up I thought the drive would try to re-map or flag the bad area and subsequently complete tests but I keep getting the read failures. I have about 130 days left on the warranty on this drive.
Can anyone give me an opinion on this drive?
Thanks!
Device: /dev/ada2, Self-Test Log error count increased from 0 to 1 Mon, 26 Aug 2019 09:00:38 GMT
The smart data is:
root@freenas:~ # smartctl -a /dev/ada2
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Red
Device Model: WDC WD30EFRX-68EUZN0
Serial Number: WD-WCC4N5UJXJV0
LU WWN Device Id: 5 0014ee 2b81fd842
Firmware Version: 82.00A82
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Fri Sep 13 11:37:23 2019 CDT
SMART support is: Enabled
General SMART Values:
was never started.
Self-test execution status: ( 118) The previous self-test completed having
the read element of the test failed.
data collection: (39360) seconds.
Auto Offline data collection on/off supp ort.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 395) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_ FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 181 180 021 Pre-fail Always - 5916
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 153
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 073 073 000 Old_age Always - 20151
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 153
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 94
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 206
194 Temperature_Celsius 0x0022 114 107 000 Old_age Always - 36
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 1
SMART Error Log Version: 1
No Errors Logged
Num Test_Description Status Remaining LifeTime(hours) LBA _of_first_error
# 1 Short offline Completed: read failure 60% 20119 156 5552088
# 2 Short offline Completed: read failure 60% 19951 156 5552088
# 3 Extended offline Completed: read failure 10% 19867 156 5552088
# 4 Short offline Completed: read failure 60% 19711 156 5552088
# 5 Short offline Completed without error 00% 19544 -
# 6 Short offline Completed without error 00% 19376 -
# 7 Short offline Completed without error 00% 19208 -
# 8 Extended offline Completed without error 00% 19120 -
# 9 Short offline Completed without error 00% 18968 -
#10 Short offline Completed without error 00% 18800 -
#11 Short offline Completed without error 00% 18669 -
#12 Short offline Completed without error 00% 18503 -
#13 Extended offline Completed without error 00% 18415 -
#14 Short offline Completed without error 00% 18287 -
#15 Short offline Completed without error 00% 18119 -
#16 Short offline Completed without error 00% 17951 -
#17 Short offline Completed without error 00% 17783 -
#18 Extended offline Completed without error 00% 17699 -
#19 Short offline Completed without error 00% 17544 -
#20 Short offline Completed without error 00% 17376 -
#21 Short offline Completed without error 00% 17208 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay.I tried doing some research before posting but only found conflicting information and I'm not sure I entirely understand SMART and how it works. The red flag for me here was the multi_zone_error_rate incrementing to 1. When the alert first came up I thought the drive would try to re-map or flag the bad area and subsequently complete tests but I keep getting the read failures. I have about 130 days left on the warranty on this drive.
Thanks!
