Ejay8400
 - Jun 6, 2016
Will check out this when i get home.What does the os think the temps are? Use sysctl -a | grep -i temp from the freenas cli.
Thanks for providing the "top" data, it's illuminating.
So it looks like Plex is doing a number on your system and odds are that your thermals are correct for the load you are putting on your system. A larger heatsink will help but likely not by much because you are pushing the CPU to the maximum. If you only want to make a heatsink change then get the one previously recommended, I trust these folks here who recommended it.
I think you need to start looking into your transcoding settings or the format of your media, or both.
Questions you might want to provide answers on to assist in some further advice:
1) What are the four devices that you are running Plex on the TV (target) side? Are they TVs (what models), are they Roku's (what models), you get the point. I'm looking for the device which has Plex on it.
2) What resolution do you have the targets set for in Plex?
3) What are the transcoding settings in the host (FreeNAS) Plex?
4) What is the format of the media you are sharing with Plex? (This is very important)
I suspect you have your settings pretty high and maybe you could relax them a bit or the media is something like BluRay material and the format needs to be seriously transcoded.
Some advice on the media. When I place media on my FreeNAS for Plex or DLNA use, I convert the data into a format which my devices can natively use, or no transcoding required and all video stuff happens in the Roku 3 before it hits my TV. All my media is in an MP4 container (H.264 format) and all my devices can handle that format directly. This works for my situation and maybe it could help you.
1) I was running all 4 on my laptop through the web player. But at other times I may play on Chromecast and Xbox One.
2) This test I set up to transcode from 1080p to 720p + subtitles. I think the subltitles for some reason takes a lot of CPU power.
3) Here you got my settings for transcoding in Plex:
	Not really set to anything high, the background transcoding option still have 2 higher settings to go.
4) Most of what I have on my Plex is in Mkv or mp4 (because of subtitles embeded in it). All is x264.
I know I could convert all my video files so they could do direct play on my server, but that would defeat the entire purpose of buying a server with some power to it just for my media library + it would take so much more time to convert 1000 movies and 3500 tv episodes than it is worth(including the strain on my laptop)
Here is the info from Plex on the video file I did the testing with:
	Edit:
So we can say that Plex(and the media) is the problem and not something wrong with the CPU itself? (thinking if there is any point in getting it replaced, is a hassle to replece it and probably takes a month+ to get a replacement after i send it)
Also, if im putting on the new CPU fan
