[Dragan]
- Aug 2, 2015
Hi everyone,
As a continuation of my intro post located here My Family FreeNAS Build – Intro
I now am kindly seeking all of your wise comments and feedback on the hardware selection I have chosen for my NAS build. The parts mentioned below have mostly been chosen based on a few similar successful builds on here and as per the Hardware Recommendation posts.
Majority of the items have already been purchased but I am seeking your confirmation on items bought and/or suggestions/opinions on couple of things that I can’t settle on.
Prices below are pcpartpicker prices and not necessarily the prices I have paid for each item, give or take few dollars here and there.
Here is the list:
PCPartPicker part list / Price breakdown by merchant
CPU: Intel Xeon E3-1241 V3 3.5GHz Quad-Core Processor ($389.00 @ CPL Online)
Got a great deal compared to the E3-1231 V3 - PURCHASED
Motherboard: ASRock E3C226D2I Mini ITX LGA1150 Motherboard ($319.00 @ CPL Online)
Chosen over the E3C224D2I due to supply - PURCHASED
Memory: Crucial 16GB (2 x 8GB) DDR3-1600 Memory CT102472BD160B ($266.00)
ECC RAM is CRAZY EXPENSIVE in Australia and terrible supply as well as no 16gb kits available anywhere, aussie dollar is terrible and not much better if ordered online from the states - PURCHASED
Storage: 6 x Hitachi Deskstar NAS 3TB 3.5" 7200RPM Internal Hard Drive ($1050.00)
$100 less for 6 x WD reds so I went with these instead - PURCHASED
Case: Fractal Design Node 304 Mini ITX Tower Case ($139.00 @ CPL Online)
Love the small form factor as well as built quality - PURCHASED
Power Supply: Silverstone 600W 80+ Gold Certified Fully-Modular SFX Power Supply ($169.00 @ CPL Online)
Overkill but I strongly believe in good clean power delivery, as well as the form factor and overall better for cable management of this model - PURCHASED
Rear Case Fan: Noctua NF-A14 PWM 82.5 CFM 140mm Fan ($29.00 @ PLE Computers)
Rear Case Exhaust fan, always been impressed with NOCTUAS and they never disappoint - PURCHASED
Front Case Fan: 2 x Noctua NF-A9 PWM 46.4 CFM 92mm Fan ($32.00 @ CPL Online)
Again as with the 140mm above, Great fans and should do the job just fine - PURCHASED
Total: $2425.00
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2015-08-10 10:40 AEST+1000
As I have chosen 6 hard drives that have tendencies to run hotter than the WD REDS [most popular choice on here], I am going about this build with a focus of MAX airflow approach for the case in question.
I understand that the noise level will possibly increase on load but that’s the sacrifice I am prepared to make in order to have everything running cooler.
Question 1:
To maximise the air flow in this small form factor case and with no overclocking ever intended, do I go for this CPU Cooler: Noctua NH-U12S 55.0 CFM CPU Cooler with additional CPU Fan: Noctua NF-F12 PWM 55.0 CFM 120mm Fan for a push pull configuration?
Excuse the PAINT diagrams. :)
Or
Just go with this CPU Cooler: Noctua NH-U14S 55.0 CFM CPU Cooler instead as I’ve upgraded all other case fans already.
Question 2:
Which of the following wattage UPS would be best suited for my usage?
I cannot see the exact same model numbers as these on the UPS compatibility list but judging by the model numbers I would say they will work of the same driver as the CYBERPOWER CP1000PFCLCD!? Model branding mentioned below might be specific for the Australian market.
UPS: CyberPower CP1300EPFCLCD
Or
UPS: CyberPower CP1500EPFCLCD
Question 3:
Do you guys see and agree with what I am trying to achieve here in regards to the overall build and dramatically improving the airflow of this case?
Thanks for your input and I look forward to your positive or negative feedback!
Cheers,
Dragan
Here is the list:
Total: $2425.00
Question 1:
Or
Question 2:
Or
Question 3:
Cheers,
Dragan
