Phil Williams
 - Feb 1, 2023
Will do.You must make sure that those are not SMR drives
Does everything else look ok?
Roughly 20TB usable (16TB maximum recommended, leave 20% open)Storage: Western Digital Red 4 TB 3.5" 5400 RPM Internal Hard Drive (£86.82 @ BT Shop) x8 for storage (Raid Z2)
Why? Isn't the four gigabit ports on the motherboard enough? One should be enough actually.Wired Network Adapter: Intel EXPI9402PTG2P20 2 x Gigabit Ethernet PCIe x4 Network Adapter (£40.00 @ Amazon UK)
We need actual model number or part number info. This is too basic. It has me asking if this is ECC RAM. Based on the info here it is not. Highly recommend ECC RAM if you are using this server as a backup. Nothing is more fun that restoring a backup just to find out it's corrupt.Memory: Kingston Server Premier 32 GB (1 x 32 GB) DDR4-3200 CL22 Memory (£86.98 @ MoreCoCo)
Don't do it.Storage: Samsung 970 Evo Plus 250 GB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive (£38.86 @ BT Shop) - boot
Um, why this motherboard? It only has up to 6 SATA ports, that includes the M.2 card. This means you are a few ports low.Motherboard: Supermicro X11SCL-LN4F Micro ATX LGA1151 Motherboard (£456.00 @ Amazon UK)
A CPU with built in graphics? On a motherboard that will not use it? Well I don't think it would.CPU: Intel Core i3-8100 3.6 GHz Quad-Core Processor (£165.00 @ Amazon UK)
That is a beast! You would be doing better to use a smaller factory sized fan. They work great for a NAS use case.CPU Cooler: Noctua NH-U12A chromax.black 60.09 CFM CPU Cooler (£119.95 @ Amazon UK)
Nice Case! I wish I had one. It just looks so clean and sleek.Case: Fractal Design Define R5 ATX Mid Tower Case
Nice power supply. It "should" be fine for 8 drives but you might be pushing it. I'd shop for an 800 Watt myself if I were going to install 8 to 10 hard drives.Power Supply: be quiet! Straight Power 11 650W 650 W 80+ Gold Certified Fully Modular ATX Power Supply (£106.31 @ Box Limited)
Yep that's what I came out with. Allowing 20% but also growth over the next few years.16TB maximum recommended, leave 20% open
Yeh .Why? Isn't the four gigabit ports on the motherboard enough? One should be enough actually
This is it: https://www.ebuyer.com/1566054-king...erver-32-gb-ddr4-3200-pc4-25600-ksm32ed8-32hcWe need actual model number or part number info. This is too basic
Nvme. Ok why? LolDon't do it.
I'm dropping to 6 drives instead of 8 and using nvme for boot.Um, why this motherboard
Yeh dithered on this for a while. Decision was based on compatibility and processor requirements rather than graphics.A CPU with built in graphics? On a motherboard that will not use it?
Basing this on heat dissipation plus keeping noise down.That is a beast! You would be doing better to use a smaller factory sized fan
Should be able to go higher. Again noise reduction was a concern.Nice power supply. It "should" be fine for 8 drives but you might be pushing it.
Went with the r6 in the end as the r5 is in short supply.Nice Case!
Yup that was it. I have a separate Plex box for transcoding.The i3-8100, with iGPU makes sense if you plan to do transcoding with Plex—BUT you'll need a C246 chipset for that, C242 does not support iGPU transcoding. (If you picked the 8100 because it happens to be cheaper than the 8100F that's all fine!).
The last part may depend on the motherboard. There are models out there, where putting in an M.2 SSD will deactivate one SATA port. But I don't remember if that is the case only for SATA-based M.2 SSDs or also ones that use NVMe. Either way, something to look out for IMHO.Any cheap NVMe SSD is fine for the boot drive (being NVMe means it won't use a SATA lane).
So I think I'll be OK, the motherboard manual lists the M.2 slot as PCI-E 3.0 x4. The board only has one M.2 slot and checking the manual (which confusingly referees to three models), I've got the following diagram:The last part may depend on the motherboard. There are models out there, where putting in an M.2 SSD will deactivate one SATA port. But I don't remember if that is the case only for SATA-based M.2 SSDs or also ones that use NVMe
It can be read as indicating this. But there should be an explicit warning in "prose" somewhere in the manual.So this says to me that usiong the 2nd M.2 slot would disable SATA6?
I have yet to come across a motherboard which deactivates SATA when using a M.2 NVMe drive.The last part may depend on the motherboard. There are models out there, where putting in an M.2 SSD will deactivate one SATA port. But I don't remember if that is the case only for SATA-based M.2 SSDs or also ones that use NVMe. Either way, something to look out for IMHO.
So I'm not cruzing this forum every day but I've seen reports of a NVMe boot drive not being recognized by the bootloader when installing TrueNAS. It may not still be a thing, but I see no need to take that risk. That is the only reason I say no to a NVMe boot drive. And I also knew the motherboard you selected would not meet your needs so buy one that has enough SATA ports to support the build properly.Nvme. Ok why? Lol
My thinking was using on board storage wouldn't take up a sata slot?
Very popular here. Good solid board. I highly recommend buying good stuff for the NAS, otherwise it's a risk. No corner cutting and I don't think you were cutting corners, not intentionally.X11SCH-LN4
Let me PM you my address to ship your "uneeded builds" to.But I like the small and fast NVMe's and I want to buy another one, just to have it. I have no need for it.
Ha Ha, I wish I had a...Let me PM you my address to ship your "uneeded builds" to.
which someone could ship mea stunning Define R6 case
