Hacking WD Greens (and Reds) with WDIDLE3.exe
joeschmuck
Old Man
Yes, most likely.
I disagree at this point in time.
I purchased WD30EZRX WD-GREEN on 8/9/2015 and finally had a chance to use install it this weekend. After 14 hours of running, i only see 4 LCC. Do I still need to use WDIDLE or did WD finally changed them?
You didn't give enough information such as you could have turned the power on and off 4 times which would also increase the head load count to 4. Wait 24 hours and post all of the SMART output and I could give you a better answer. At this rate (assuming it stays constant) you would hit about 158,000 load counts in 3 years.
Jailer
Not strong, but bad
@alexg I would at least check it and see what it's set at. If it's 8 seconds like most Greens are I'd change it.
I imagine the low LCC is probably due to whatever workload was being used for whatever testing, though a WD Green with reasonable idle timer would be nice.
alexg
26 hours. Perhaps numbers are low because this drive is in my replicated pool and not my primary. Replication occurs on a nightly basis. But I also ran resilvering in the last 24 hours to replace another drive. Does anyone have a link where I can download wdidle3? All the links to WD sites are no longer get you this utility.
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       26
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       2
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       15
Jailer
Not strong, but bad
solarisguy
[...] All the links to WD sites are no longer get you this utility. [...]
For Greens
RE2GP Idle Mode Update Utility
http://support.wdc.com/downloads.aspx?p=113
Released April 2010 (binary is dated 2009-10-23)
wdidle3_1_05.zip
Some of the language specific links:
http://support.wdc.com/downloads.aspx?p=113&lang=de
http://support.wdc.com/downloads.aspx?p=113&lang=en
http://support.wdc.com/downloads.aspx?p=113&lang=fr
For Reds
WD Red SMART load/Unload utility 3.5" Drive
http://support.wdc.com/downloads.aspx?p=201
Released 2013-12-20
wd5741.exe
http://support.wdc.com/downloads.aspx?p=201&lang=de
http://support.wdc.com/downloads.aspx?p=201&lang=en
http://support.wdc.com/downloads.aspx?p=201&lang=fr
joeschmuck
Old Man
I agree and I was thinking the same thing, it would be nice to see the default timer changed and maybe it has been, it would be nice to know.
@OP, you sure don't want to post too much SMART data, do you. But if your drive has been constantly busy, your LCC will go up but the question is how fast. Usage is a big factor.
@solarisguy Thanks for reposting those links, I'm sure many others will utilize them in the future.
2Does anyone have a link where I can download wdidle3? All the links to WD sites are no longer get you this utility.
You do realize I gave you the files as attachments in the original post?....
joeschmuck
Old Man
alexg
Guys, thanks for the links. I mean no disrespect, but I don't trust attachments someone posts. The LCC counts continue to grow and here is the latest full smart data (yeah, I was just trying to save you guys reading time by posting LCC data only). I will be making WDIDLE3 changes over the weekend.
smartctl 6.2 2013-07-26 r3841 [FreeBSD 9.2-RELEASE-p10 amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Western Digital Caviar Green (AF, SATA 6Gb/s)
Device Model:     WDC WD30EZRX-22D8PB0
Serial Number:    WD-WCC4N4RP9AH3
LU WWN Device Id: 5 0014ee 2b62b8f2b
Firmware Version: 80.00A80
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Rotation Rate:    5400 rpm
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Thu Oct 29 18:28:35 2015 EDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x80) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (39240) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 394) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x7035) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   100   253   021    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       2
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       96
10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       0
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       399
194 Temperature_Celsius     0x0022   122   112   000    Old_age   Always       -       28
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed without error       00%        14         -
# 2  Short offline       Completed without error       00%         1         -
Jailer
Not strong, but bad
Yeah you better get after those drives. The LCC in my wdidle'd greens is 162 with 8372 power on hours.
solarisguy
@anyview, there were no reports that it does not work.
If you do, please share with us the results and the model number of your drive (date it was manufactured would be a nice addition).
Ali777
I just tried adjusting the time to 300s for my new WD Green 2 Tb WD20EZRX
It works , thank you very much.
Ali777
@Ali777, is it tap, tap, tap, tap...? All the time?
Did you hear the same sound before using wdidle3 ?!?!?!
yes sounds like tap tap
actually I didn't pay much attention before using it I just checked the S.M.A.R.T it was OK
I tried to set it back to 8s, the sound disappear after the 8s
