tres_kun
- Oct 10, 2015
It seems like this hard drive is failing
It disconnects from the system every minute and clicks at the same time
Have replaced the sata cable with a known working one
If somebody can check the smart reading for me
To confirm my suspicions
Thank you
Thank you
1 Raw_Read_Error_Rate 0x000f 117 099 006 Pre-fail Always - 124799272 3 Spin_Up_Time 0x0003 099 097 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 094 094 020 Old_age Always - 6849 5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 072 060 030 Pre-fail Always - 16442132 9 Power_On_Hours 0x0032 094 094 000 Old_age Always - 5661 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 457 184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0022 066 052 045 Old_age Always - 34 (Min/Max 34/34) 194 Temperature_Celsius 0x0022 034 048 000 Old_age Always - 34 (0 10 0 0 0) 195 Hardware_ECC_Recovered 0x001a 053 025 000 Old_age Always - 124799272 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Interrupted (host reset) 00% 5453 - # 2 Short offline Completed without error 00% 5356 - # 3 Short offline Completed without error 00% 5212 - # 4 Short offline Completed without error 00% 5116 - # 5 Short offline Completed without error 00% 4972 - # 6 Extended offline Completed without error 00% 4733 - # 7 Short offline Completed without error 00% 4635 - # 8 Short offline Completed without error 00% 4491 - # 9 Short offline Completed without error 00% 4395 - #10 Short offline Completed without error 00% 4250 - #11 Extended offline Completed without error 00% 3987 - #12 Short offline Completed without error 00% 3891 - #13 Short offline Completed without error 00% 3747 - #14 Short offline Completed without error 00% 3651 - #15 Short offline Completed without error 00% 3507 - #16 Extended offline Completed without error 00% 3268 - #17 Short offline Completed without error 00% 3170 - #18 Short offline Completed without error 00% 3026 - #19 Short offline Completed without error 00% 2930 - #20 Short offline Completed without error 00% 2786 - #21 Extended offline Completed without error 00% 2524 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
