I'm currently seeing the following alerts:
Device: /dev/da3 [SAT], 8 Currently unreadable (pending) sectors
Mon, 26 Oct 2020 04:04:47 GMT
Device: /dev/da3 [SAT], 8 Offline uncorrectable sectors
I ran a Smart Long test on the drive and these are the results:
I see a read failure in the extended offline test, but no LBA address. From what I've read, I would need this information to fix the bad sector. Anybody have any ideas or suggestions?
=== START OF INFORMATION SECTION === Model Family: Seagate Enterprise Capacity 3.5 HDD Device Model: ST10000NM0016-1TT101 Serial Number: ZA29PF61 LU WWN Device Id: 5 000c50 0b36874e1 Firmware Version: SNE0 User Capacity: 10,000,831,348,736 bytes [10.0 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 7200 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-3 T13/2161-D revision 5 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Tue Oct 27 11:26:43 2020 CDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 567) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 901) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x50bd) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 083 064 044 Pre-fail Always - 223527048 3 Spin_Up_Time 0x0003 091 091 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 34 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 40 7 Seek_Error_Rate 0x000f 087 060 045 Pre-fail Always - 496965224 9 Power_On_Hours 0x0032 085 085 000 Old_age Always - 13489 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 34 184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 0 0 189 High_Fly_Writes 0x003a 090 090 000 Old_age Always - 10 190 Airflow_Temperature_Cel 0x0022 070 059 040 Old_age Always - 30 (Min/Max 27/38) 191 G-Sense_Error_Rate 0x0032 091 091 000 Old_age Always - 18895 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 494 193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 643 194 Temperature_Celsius 0x0022 030 041 000 Old_age Always - 30 (0 18 0 0 0) 195 Hardware_ECC_Recovered 0x001a 024 001 000 Old_age Always - 223527048 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 8 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 8 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 13468h+15m+23.568s 241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 58571555938 242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 114515168403 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 13480 - # 2 Extended offline Completed: read failure 90% 13463 - # 3 Short offline Completed without error 00% 13456 - # 4 Short offline Completed without error 00% 13432 - # 5 Short offline Completed without error 00% 13408 - # 6 Short offline Completed without error 00% 13384 - # 7 Short offline Completed without error 00% 13361 - # 8 Short offline Completed without error 00% 13337 - # 9 Short offline Completed without error 00% 13313 - #10 Short offline Completed without error 00% 13290 - #11 Short offline Completed without error 00% 13266 - #12 Short offline Completed without error 00% 13242 - #13 Short offline Completed without error 00% 13218 - #14 Short offline Completed without error 00% 13197 - #15 Short offline Completed without error 00% 13173 - #16 Short offline Completed without error 00% 13149 - #17 Short offline Completed without error 00% 13125 - #18 Short offline Completed without error 00% 13101 - #19 Short offline Completed without error 00% 13077 - #20 Short offline Completed without error 00% 13053 - #21 Short offline Completed without error 00% 13029 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
