FreeNAS 8.2.0-BETA3 is now available
J
jpaetzel
Guest
I've just completed uploading FreeNAS 8.2.0-BETA3.
https://sourceforge.net/projects/freenas/files/FreeNAS-8.2.0/BETA3/
Upgrades from BETA2 work, but most likely any plugin stuff that is working in BETA2 will stop working
You'll want to use the plugins in the BETA3 directory with this beta, don't mix and match.
Notable highlights are a complete refactor of plugins, iSCSI target reload, and the samba security fix.
Release Notes for FreeNAS 8.2.0-BETA3
*** IMPORTANT ***
- The image size increased in 8.0.1-BETA3. The new size requires a 2 GB
storage device. The GUI upgrade can be used to upgrade a system from
BETA3, BETA4, or RC1 but upgrades from earlier releases can only be
done from the CD. The other option is to save the config, reinstall
the new version, then restore the config.
- FreeBSD can be really touchy with hardware. Please be sure to update
your BIOS/BMC firmware when upgrading / installing FreeNAS if you run
into OS hang issues. There have been cases identified where a BIOS
upgrade has fixed driver hangs, and/or other issues with FreeNAS; one
such example was with an Intel 82578DC motherboard, as noted in the
FreeNAS 8 forum thread titled "8.0.3-RELEASE coming soon..":
http://bit.ly/rq78Q3 , post # 70-88. Again, please only do this if you
experience booting / runtime issues, as some vendors don't test
FreeBSD interoperability as much as others between major firmware
releases.
- Previous builds were branded as i386/amd64 (32-bit and 64-bit
respectively). 8.0.3-RC1+ rebranded the architectures as x86 and x64,
respectively.
- 8.0.1 and 8.0.2 images advertised CIFS shares to Macs by default but
8.0.3 and later images don't advertise CIFS shares by default. If you
want to advertise CIFS shares in 8.0.3 and later, be sure to turn on
"Zeroconf" support in the CIFS global settings.
- Builds prior to 8.0.3-RELEASE with 'CIFS' didn't actually have AIO
(asynchronous I/O) enabled. So, if you experience performance
degradation after upgrading from prior versions of FreeNAS to
8.0.3-RELEASE or newer, turn off AIO or tune the AIO size from '1' to
something more reasonable (the new default in 8.0.3-RELEASE-p1 is 4096
or 4kB).
Changes in the 8.2 branch versus 8.0.x
Overview
The 8.2 branch of FreeNAS introduces many functional changes when
compared with the 8.0.x releases.
ZFS can be manipulated from the CLI, and changes for supported items
tracked by FreeNAS will be reflected in the GUI. zvols, datasets, and
entire volumes can be created, destroyed, or manipulated on the CLI and
will be propagated to the GUI.
The GUI now supports active-passive multipath capable hardware, which
targets mainly SAS drives on dual expander backplanes. Any multipath
capable devices that are detected will be placed in multipath units
which are then exposed to the GUI, and the parent devices will be
hidden.
Plugins are now available. Third party modules can be added to FreeNAS
which will persist across upgrades and can be manipulated and configured
from the GUI. Documentation on using and creating plugins is available
at http://doc.freenas.org/index.php/Plugins_Configuration . BitTorrent,
DLNA/uPNP, and iTunes plugins are available as of this writing.
The GUI now includes a webshell, which allows you to access a root
shell from within a web browser.
The "Create Volume" modal was renamed to "Volume Manager". Extending
existing pools is more intuitive than it was previously; selecting
multiple disks for a storage volume is now done via a multiselect
widget instead of checkboxes to improve ease of use when creating
volumes.
ZFS volumes can now have periodic scrub tasks configured for them; the
default is set to 35 days to be consistent with the OS default.
An autotuning script is now available -- disabled by default. It sets
various tunables and sysctls based on system resources and components.
The predetermined values are exposed through the GUI from the Sysctls
and Tunables panes.
A newer web toolkit is used, which behaves better with modal dialogs
and more intuitively in general when compared with older versions.
It also has better browser compatibility, including compatibility with
Android / iOS mobile devices!
A more responsive service state detection mechanism was added to
improve FreeNAS interoperability in VM software (VMware, VirtualBox,
etc).
Changes since 8.2.0-BETA2:
Enhancements
GUI
1. A major refactoring of the plugin structure has been done.
iSCSI
1. Target reload is now supported for adding and removing (but not changing)
targets on the fly. The Logical Unit Controller is used for this, reload
wil not function if the LUC is not enabled.
CIFS
1. Samba has been upgraded to 3.6.4 to address the security issues in 3.6.3
Bugfixes
GUI
1. Fix a javascript error that affected IE8
Changes since 8.0.4-RELEASE:
Enhancements
Build
1. Refactoring of the build system was done to ease release
engineering and make FreeNAS software development easier, faster,
and more deterministic.
2. Plugin jail generation was integrated into the build system.
GUI
1. The current password box for changing the admin password is hidden
when there isn't an admin password set.
2. Adding users allows for placing users into additional groups, as well
as greater clarity about the primary group the user will be in.
3. The NTP configuration fields are split in to separate fields instead
of overloading a single field.
4. Create Volume is now renamed to Volume manager, and has a different
widgit for selecting multiple disks, as well as a better GUI for
extending existing volumes versus adding new volumes.
5. Create dataset and create zvol are now buttons listed per pool, in
addition nested datasets can be created as a dataset has an add
dataset button.
6. Deleting volumes and datasets properly cascades to shares and
services; notification is provided if a filesystem is in use and
the configuration database is guaranteed to be more consistent with
the system state.
7. Update the GUI to reflect the fact that the dynamic DNS update period
is in seconds, not milliseconds.
8. Add the ability to enable or disable the autotuner to system ->
settings -> advanced.
9. Alias IPs are displayed in the interface configuration screen.
10. ZFS scrubs can be scheduled via the GUI.
11. The IP address used to connect to the FreeNAS box is displayed in
the GUI.
Middleware
1. Significant refactoring of the middleware was done to support
various changes made to the GUI.
OS/Third party
1. Add the iSCSI initiator kernel module to the system.
Plugins
AFP
CIFS
iSCSI
1. Use configured IPs on the system as candidates for portal addresses.
NFS
Tools
Bugfixes
Build
GUI
1. Exclude snapshots with existing clones from the pending delete list.
This fixes an issue where a clone will prevent an existing snapshot
from being deleted by the autosnapper.
2. Browser cache can become confused when the same browser is used to
access multiple versions of FreeNAS. Version specific cache data
was added to mitigate this issue.
Middleware
OS/Third party
Plugins
AFP
AD/CIFS/LDAP
1. Disable directory name caching, which improves performance on BSD.
2. Remove the ability to set a guest account per share, this is a global
setting only.
3. Change the default guest account to nobody.
4. Add anonymous LDAP bind support.
iSCSI
1. Ensure that a file extent resides in a volume.
NFS
Tools
Changes since 8.0.4-RC1:
Enhancements
GUI
1. Rename 'loaders' to 'tunables' to target the FreeBSD concept under
inspection (kernel tunables) (SF r10235, r10236).
Bugfixes
OS/Third party
1. Remove sane caps for minimum ZFS requirements for lower spec'ed home
user machines added in 8.0.4-BETA1. A better solution will be devised
in 8.2.0 with automatic system tuning, similar to legacy's
zfskerntune (SF r10271).
CIFS
1. Correct guest parameter setting in the GUI as it's a global option,
not a per-share option (SF r10296).
2. Allow Guest Only parameter only makes sense when Allow Guest is
specified (SF r10300).
3. Validate guest setting prior to accepting POST to ensure that the
value set for Guest is sane.
Changes since 8.0.4-BETA2:
Enhancements
Build
1. Remove Full_Install from the compressed disk image name to avoid
potential confusion when looking at the disk image vs the GUI
upgrade image (SF r10154).
Middleware
1. Do not restart collectd (reporting backend) when deleting snapshots
in the GUI (SF r10139).
Tools
1. Add arcstat.py and arc_summary.py tools originally contributed by
jhell (FreeBSD contributor), ported by jhixson to FreeNAS 8.x.
Bugfixes
GUI
1. Correct window title for snapshot deletion GUI (SF r10138).
Middleware
1. Catch ZFS snapshot errors when snapshots are done via the GUI instead of
failing silently (SF r10152).
2. Work around interoperability issues with user / group population in the
GUI by failing silently in certain cases if AD/LDAP users cannot be
retrieved (SF r10140).
3. Fix case where local and remote paths passed to rsync in Rsync tasks
weren't quoted, so paths with spaces in them would not work (FN 1285).
Changes since 8.0.4-BETA1:
Enhancements
OS/Third party
1. Update transmission to 2.42 (SF r10093).
2. Add MegaCLI tool (SF r10072, r10073).
3. Disable periodic tasks in the base system that would negatively
impact system performance on NAS boxes with large directory
structures (SF r10113).
Bugfixes
Middleware
1. Fix handling for 'every day' SMART tasks created in the GUI
(SF r10088).
2. Add in several robustness fixes to reduce potential for filesystem
corruption on root / boot device. In some scenarios this would also
improve performance when fetching data from the root device as well
(SF r10095, r10109, r10129).
CIFS
1. Fix vfs objects modules ordering so shadow copy (aka previous
versions) support functions again (FN 935, FN 1186, FN 1275).
2. Update samba to 3.6.3 to resolve several bugs (both security and
non-security related) (SF r10127).
iSCSI
1. Network field from iSCSI initiator could contain multiple IP
addresses, CIDR addresses, or ANY keyword (SF r10082).
2. Generate istgt.conf properly if and when multiple initiators were
specified (SF r10081).
Changes since 8.0.3-RELEASE-p1:
Enhancements
Build
1. Add .img suffix to simplify mounting full disk image for Windows and
OSX users (FN # 1236).
OS/Third party
1. Update firefly to 1696_6 for iTunes 10.5.2+ compatibility.
2. Add in sane caps for minimum ZFS requirements for lower spec'ed home
user machines.
AD/CIFS
1. Automatically create AD/LDAP user home directories (FN # 1203).
2. Add 'allow trusted domains' knob in the CIFS global configuration
(FN # 998).
iSCSI
1. Restrict portal input in the GUI to prevent scenarios where
incorrect input would prevent iSCSI from starting (FN # 1231).
Rsync
1. Add rsync+SSH functionality (FN # 990).
2. Add functionality to differentiate rsync pushing from pulling
(FN # 394).
Bugfixes
GUI
1. Fix disks / partition parsing when importing volumes (FN # 1202).
2. Restrict users from creating cronjobs / rsync tasks with long
usernames (FN # 1061).
Middleware
1. Correct smbpasswd parsing when debug level isn't set to minimum
logging (FN # 1224).
AD/CIFS
1. Escape samba AD/LDAP passwords (FN # 1225).
2. Ensure guest accounts are disabled if checked (SF r8276).
Changes since 8.0.3-RELEASE:
Enhancements
OS/Third party
1. Update ataidle from 2.6 to 2.72 based on maintainer's (brucec@FreeBSD)
recommendation due to interoperabilities with 2.6 and certain chipsets.
2. Fix the inadyn port so that it works on i386.
Bugfixes
Middleware
1. Fix a regression for DHCP users where /etc/resolv.conf would be nulled
out if DNS servers weren't specified in the GUI.
AD/CIFS
1. Disable AIO by default and change the default AIO read / write size to
4kB. This was done provided feedback and the fact that the build fixes
actually enabled AIO, whereas prior releases didn't enable it by
default. This can cause issues with machines that don't have the
resources to service AIO requests quickly enough, where previously they
would be able to service requests at near line speeds, whereas after
they are unable to service requests that quickly.
NFS:
1. Add in logic to start lockd and mountd when NFS is enabled s.t. FreeNAS
doesn't need to be manually prodded to start the services, or rebooted
in order for the services to become effective.
Changes since 8.0.2-RELEASE:
Enhancements
OS/Third party
1. Use smaller block and frag sizes for /etc and /var .
2. Import a build tweak to nuke /var/db/pkg to save ~7MB space.
3. Other build tweaks to remove non-essential features and packages from
the image.
4. Disable output to /var/log/console.log in non-debug builds to avoid
unnecessary duplication in /var/log/messages .
5. Upgrade ataidle to 2.6.
6. Upgrade nut / net-snmp to 2.6.2 and 5.7.1, respectively.
7. Import omnibus build system fixes to fix the fact that the 8.0.3-BETA1
image was broken due to the environment of the build machine where it
was produced on. This also fixes other items, such as DDNS because of
build environment tainting.
8. Increase the /var md size from 74MB to 160MB s.t. samba will be able
to service requests copying large sets of files, and the rest of the
system will be able to play nicely with samba to a certain degree.
More tuning is required for larger samba userbases.
GUI
1. Add kernel tunable / sysctl support.
Middleware
1. Hide Etc/GMT* timezones as they're behavior is counterintuitive and
conflicts with Windows 7 semantics (see r8707).
AD/CIFS
1. Bump samba from 3.5.11 to 3.6.1.
2. Address simple failure cases with getting Kerberos tickets (clock
skew) and joining AD domains (invalid passwords, bad short domain names,
etc) so that users could better rectify improperly configured NAS boxes;
this means that if either of these cases fail, the GUI will now inform
the user that the 'Active Directory' service is stopped.
3. Fix cachetool to better prevent potential race condition at boot between
winbindd and ix-cache.
4. Add knob for enabling/disabling Zeroconf/Bonjour (avahi) support in the
GUI. For technical reasons outside of the author's control, this
feature defaults to off when upgrading FreeNAS. FreeNAS admins
anticipating that they will have Mac users attempting to connect to CIFS
shares should enable this feature.
AFP
1. Bump netatalk to 2.2.1.
2. Add knob for controlling the maximum number of configurable connections
(see ticket: 847).
3. Only advertise services via avahi if they're enabled (see ticket: 852).
Rsync
- NFSv4 ACL support (see: r8375, r8414).
Bugfixes
OS/Third party
1. Fix NTFS volume imports.
GUI
1. ZFS volume deletion failed when trying to delete zvol with the name
'zvol'.
2. SSH pubkey saving was broken unless you manually add a newline to the
text box.
3. Fix traceback when trying to edit user if ssh public key was not
specified.
4. Fix the bug in rsync tasks where it would strip the trailing '/' off
the end of the destination path.
5. Fix a validation error when editing users / groups in 8.0.2+ where
if one entered in a path that wasn't valid, the GUI would traceback
instead of punting the actual validation error.
6. Fix an issue where if one entered in an invalid path, the GUI would
traceback instead of providing feedback stating that the directory
provided was invalid.
Middleware
1. Rsync task/crontab generation was broken with AD usernames and other
unsanitized input.
2. Fix email regressions since 8.0.2-RELEASE-p1 (SMART emails now work
with more than one recipient, non-SMTP authentication based emails
work again).
4. Fix an issue where if one autosnap process was killed uncleanly, more
autosnap processes could back up and eventually deadlock the system.
5. Fix an issue where the ZFS scrub cronjobs would execute every 30 days
instead of a number divisible by 7, so what would generally happen is
that ZFS scrubs would generally execute in the middle of the week.
6. Fix setting httpd to listen on an interface which is not the first
interface.
7. Add logic to create home directories on demand instead of failing
'silently' if the path to the directory didn't already exist.
8. Fix 'detaching' NTFS/UFS volumes so that it unmounts the volume in
the FreeBSD backend.
AD/CIFS
1. Change the default workgroup from FREENAS to WORKGROUP as having the same
name for the workgroup and the hostname is illegal per the SMB/CIFS
protocol.
Cosmetic items
1. Change "SSH key" in GUI to "SSH Public Key".
2. Fix GUI trademarks and branding to be more consistent with proper
branding, similar to what TrueNAS does today.
Major changes since 8.0.1-RELEASE:
- The email subsystem was not working correctly in 8.0.1-RELEASE, which
resulted in the system not being able to send mail, as well as of the
alerting system in the GUI.
Changes since 8.0.1-RELEASE:
- Allow decimal numbers for a dataset quota. (r8728)
- Fix setting recursive ACLs. (r8270)
- Start proftpd after ix-ssl to use the correct SSL cert. (r8246)
- Use wildcards in cron and rsync jobs instead of listing all values. (r8214, r8211)
- Fix case in iSCSI targets to match the behavior specified by RFC 3722. (r8120)
Changes since 8.0-RELEASE:
There's too much to list here, but the high points are:
- Divorced the volume members in the database from the FreeBSD devices.
This resolves an issue where FreeBSD can change devices names and the
GUI doesn't pick up the updates due to the devices names being hard-wired
in the database.
- Support exporting ZFS zvols (virtual devices) as device extents via iSCSI.
8.0 was only able to export physical device nodes or file based extents.
- The GUI now has an event notification system.
- The email backend has been refactored.
- Many many changes in the GUI to help it validate and sanitize inputs that
are passed to the backend daemons.
- Added UPS functionality.
- Added rsync client and server functionality.
- Added the ability to schedule cron jobs in the GUI.
- Vastly improved and reworked snapshot replication.
Errata:
- CHAP doesn't work with GlobalSAN initiators on OS X.
- Upgrades from FreeNAS 0.7 aren't supported.
- The installer doesn't check the size of the install media before attempting
an install. A 2 GB device is required, but the install will appear to
complete successfully on smaller devices, only to fail at boot.
- The installer will let you switch from i386 to amd64 architecture and
vice-versa, but some files, such as the rrd files used by the statistics
graphing package are architecture dependent.
- There are known interoperability issues with FreeNAS and Samba 4.x being
used as a PDC due to Samba 4.x not conforming to the Microsoft CIFS
specification and the way LDAP queries are executed on FreeNAS. Please see
the following support ticket for more details:
http://support.freenas.org/ticket/1135 .
Filename:
FreeNAS-8.2.0-BETA3-x64.GUI_Upgrade.xz
SHA256 Hash:
4fb9671652897afb3a0fda3e4cca94ab589575803339a6df68fda961ab9cb824
Filename:
FreeNAS-8.2.0-BETA3-x64.img.xz
SHA256 Hash:
70e0c196cf5f40c20ebc30e50ebd08006d9acfa550906082918534c1a5eda5c0
Filename:
FreeNAS-8.2.0-BETA3-x64.iso
SHA256 Hash:
c4e297a7eb848145a5badc673c9645ccf631cf9120d6598d7fc158da2c76e89d
Filename:
FreeNAS-8.2.0-BETA3-x86.GUI_Upgrade.xz
SHA256 Hash:
7c29463b13032dc53826f570e4c8ace09650d88b1256d6362c5fa4af42ebe101
Filename:
FreeNAS-8.2.0-BETA3-x86.img.xz
SHA256 Hash:
23c3d02f6f0dd462ea1610926754db30e1bc3f442840e7106b3e14b305ad8155
Filename:
SHA256 Hash:
zygoptera
I understand it as this beta is to (mainly) test that the refactoring did not introduce any bugs. Does this imply we are pretty close to a 8.2-RC ??
I am dying for the release of the stable 8.2 release...
edit:To avoid any misunderstanding; I really like FreeNAS and love the work the developers put in - no whining intended...
William Grzybowski
There were hundreds of commits between BETA2 and BETA3... I would expect at least a BETA4 before the RC1...
zygoptera
Just curious not being a programmer, were can I check these "commits" to have an idea of the work being done between the releases? I don't get were the real development discussions are held.
warri
At https://support.freenas.org you can see all open bug tickets, the developing process and the actual source code including all commits.
sirdir
BETA3 latest version?
Hi!
I wonder why BETA3 is listed as 'latest version' on the main page? I was tempted to install it as 'stable'...
J
jpaetzel
Guest
There is a commit mailing list you can subscribe to if you want to get an email for each commit, along with the diff of it.
You can also browse changesets at http://support.freenas.org
I've notified our web team, I agree that the download links should not be pointing at 8.2.0-BETA3
StephenFry
Updated BETA2 from the GUI to BETA3 - no weirdness to report, which is how I like it!
Thanks guys.
StephenFry
Ouch, sadly some weirdness after all:
The "Advanced Mode" button for CIFS shares doesn't do anything anymore, which means I can't edit my block/allow access by IP address.
drinking12many
Any idea what would cause this error while upgrading from BETA2?
[MiddlewareError: The update failed: Command '['sh', '-x', '/root/update']' returned non-zero exit status 1]
Here was the last couple lines in the terminal
Apr 21 13:20:30 freenas notifier[3066]: Executing: /usr/bin/xz -t /var/tmp/firmware/firmware.xz
Apr 21 13:20:49 freenas middleware[3066]: Popen()ing: /sbin/sha256 -q /var/tmp/firmware/firmware.xz
Apr 21 13:20:51 freenas updater[3066]: Executing: /usr/bin/xzcat /var/tmp/firmware/firmware.xz | sh -x /root/update
*edit Got this today think this is just a bug when using more than one ip - WARNING: The following IPs are bind to iSCSI Portal but were not found in the system: 0.0.0.0
Mitez
Got a problem with the Authentication Model in Services - CIFS enabled the "Anonymous" option. The username and password are the same on client machine
When signed into Windows 7 it doesn't pop-up with "Windows security" window asking for credentials.
It looks like the Anonymous and Local user Authentication are similar.
Is this a bug?
duckman
I don't think you can have a share that is both Anonymous (ie no access restrictions) and also Authenticated (where it will ask who you are).
I've tried, and it doesn't work. The documentation for samba isn't especially clear on this though...
I agree it would be nice to have - my plan was Read for anonymous & Write for authenticated. Sadly no.
jgreco
Resident Grinch
Yes, you can, kinda. Use two different shares pointing to the same files. For our anonymous read-only shares, we have corresponding shares named ${share}rw for maintenance and management purposes, and it works fine.
duckman
@jgreco Yes, that's what I did too in the end.
It's odd though - in the CIFS share options there is Allow Anonymous (which suggests that anonymous are allowed, perhaps in addition to authenticated as well?)
And also, and this is the kicker, Only Allow Anonymous. This definitely suggests that you can have a single share that is authenticated and also allow Anonymous, else why even have this option at all? Ticking it on or off makes no odds...
jgreco
Resident Grinch
I won't pretend to understand it either, don't feel bad.
tmacka88
any idea when a stable RC version will be released? I want to upgrade but dont want to have to re do all the plug in mods every time i upgrade.
cheers
ProtoSD
There's probably going to be another beta sometime soon. I suspect we won't see an RC until the end of May or beginning of June at the earliest. Apparently they're working on a way to upgrade plugins before the next beta, so if you don't want to redo your plugins, wait a bit longer. You'll probably have to redo them at least one more time anyway if you upgrade before the 8.2 Release.
jgreco
Resident Grinch
I'd expect that you'd have to redo them at least one more time anyways regardless.
Similar threads
J
Replies
21
Views
19K
J
Replies
63
Views
50K
G
Replies
264
Views
169K
gcooper
G
